濡变试验机技术有限公司
  • Amsler测试技术
    2022/03/14
实验室建设
  • Creep Rupture Test Machine
    Area of use:
    detecting material behaviour
    material characterisation in the field of power station and turbine technology so that systems can be operated with pressures and temperatures
    long-term tests to design high-temperature parts
    determining the creep and high-temperature behaviour
    consistent mechanical and thermal load
    Photos from MPA Stuttgart (Materials Testing Institute)
    Accuracy:
    DIN EN ISO 7500, class 0.5 / 1
    Size:
    choice of test load between: 1 … 100 kN
    Test fields:
    testing institutes
    research centres
    Specimens:
    round specimens
    flat specimens
    tube segments
    Standards:
    DIN EN ISO 204
    national guidelines from working groups
    Application:
    creep rupture tests, creep tests with long test duration
    relaxation tests
    tests with constant load application
    creep behaviour by measuring with periodical test interruptions
    Frame:
    stable profile load frame with high stiffness mounted on an underframe
    precise test lines can be adapted in any number
    platform for test set-up with space for heating and regulation
    the machine elements are screwed together free of play and are deformation-resistant
    all contact surfaces are machine-finished to achieve the greatest possible parallelism across the whole frame
    mounting plates for alignment and support
    Load:
    deadweight with incremental weights using a lifting system built-in underneath. The highest production precision facilitates consistent load application with guaranteed long-term stabilityt
    Options / Accessories:
    electro-mechanical or hydraulic load unit
    measurement and control of force and strain
    ?PROTEUS“ test software for test control and evaluation
    force and strain measuring system with suitable measuring rods
    high temperature ovens
    tensioning equipment with adapters for differing specimen dimensions
