【求助】(已应助)(急用)求助:文献一篇
文献检索-互助
  • 悬赏金额:50积分状态:已解决
  • 先需要文献一篇,遍寻各处没找到,特需要各位坛友帮助一下,在此谢谢各位!~
    Dutta, S. K., S. K. Basu, et al. (2006).
    "Binding of diclofenac sodium with bovine serum albumin at different temperatures, pH and ionic strengths."
    Indian J Exp Biol 44(2): 123-7.
    http://www.ncbi.nlm.nih.gov/entrez/query.fcgi?cmd=Retrieve&db=PubMed&dopt=Citation&list_uids=16480178
    The study was designed to examine the binding of diclofenac sodium with bovine serum albumin (BSA) at different temperatures (20 degrees, 30 degrees and 40 degrees C), pH (6.4, 7.4 and 8.4) and ionic strengths (micro = 0.1, 0.2 and 0.3) by means of equilibrium dialysis method. The concentration of diclofenac sodium was maintained at wider range from 15 to 900 micromole/l and BSA concentration was maintained at 61.5 micromole/l. The data obtained were interpreted by nonlinear regression method using Graphpad prism software. The analysis showed that the interaction between diclofenac sodium with BSA results in two-site saturable binding. A decrease in association constant was observed with increasing temperature. The average standard free energy change (deltaGdegrees) value was -7.07 (site I) and -4.2 (site II) Kcal/mol. The standard enthalpy change (deltaHdegrees) and the standard entropy change (deltaSdegrees) were -7.8 Kcal/mole, -2.35 cal/mole (site I) and -7.4 Kcal/mole, -10.5 cal/mole (site II), respectively. The negative enthalpy change suggested the binding between diclofenac sodium and the binding sites of BSA were spontaneous and exothermic. The negative value of deltaHdegrees and deltaSdegrees indicated hydrogen bonding and van der Waal's force was the major mechanism for diclofenac sodium and BSA interaction. Increase in pH and ionic strength also caused decrease in association constant of diclofenac sodium and BSA binding.
快乐的小马 2007/04/12
你在北京吗?我知道哪个图书馆有印本的,但是我得不到这个文章的电子的。你要是方便的话,自己去图书馆复印一下就可以了,我记得复印每页是两毛五。
  • 快乐的小马
    第1楼2007/04/12
  • wds408
    第2楼2007/04/12
    这么麻烦啊
    我在长沙啊
    现在急需这篇文章
    这可怎么办???
  • wds408
    第3楼2007/04/12
    小马哥
    没有扫描的吗??
