TD-TF-SPME-GCMS热脱附薄膜固相微萃取分析香烟香气成分
图2 TF-SPME薄膜固相微萃取的挥发性化合物总离子色谱图(TIC)
Area | ||||
No | Name | RI_test | RT_min | [rel.%] |
1 | ISOBUTYR ALDEHYDE | 810 | 5.763 | 0.047 |
2 | PROPANONE | 811 | 5.782 | 0.063 |
3 | FURAN, 2-METHYL- | 868 | 6.59 | 0.007 |
4 | ETHYL ACETATE | 887 | 6.856 | 0.017 |
5 | BUTANONE, 2- | 904 | 7.117 | 0.007 |
6 | FURAN, 2-METHYL-4,5-DIHYDRO- | 908 | 7.204 | 0.010 |
7 | METHYLBUTYRALDEHYDE, 2- | 915 | 7.354 | 0.033 |
8 | ISOVALERALDEHYDE | 919 | 7.441 | 0.163 |
9 | METHANE, DICHLORO- | 931 | 7.688 | 0.030 |
10 | BUTEN-2-ONE, 3- | 950 | 8.079 | 0.007 |
11 | ETHYLFURAN, 2- | 955 | 8.191 | 0.017 |
12 | ETHYL PIVALATE | 963 | 8.355 | 0.013 |
13 | DIACETYL | 983 | 8.766 | 0.067 |
14 | ALDEHYDE C 5 | 983 | 8.771 | 0.030 |
15 | DECANE | 999 | 9.105 | 0.010 |
16 | PENTENONE, 1,3- | 1028 | 9.811 | 0.113 |
17 | TOLUENE | 1049 | 10.319 | 0.230 |
18 | DECANE, 2-METHYL- | 1055 | 10.478 | 0.027 |
19 | FURAN, 2-ISOPROPYL-5-METHYL- | 1060 | 10.604 | 0.007 |
20 | PENTANEDIONE, 2,3- | 1068 | 10.788 | 0.013 |
21 | ETHANE, 1,2-DICHLORO- | 1077 | 11.01 | 0.007 |
22 | BUTYL ACETATE | 1079 | 11.068 | 0.023 |
23 | ALDEHYDE C 6 | 1092 | 11.383 | 0.043 |
24 | UNDECANE | 1096 | 11.46 | 0.053 |
25 | XYLENE, P- | 1135 | 12.611 | 0.017 |
26 | XYLENE, M- | 1150 | 13.056 | 0.043 |
27 | BUTYL ALCOHOL | 1150 | 13.061 | 0.037 |
28 | BENZENE, ISOPROPYL- | 1180 | 13.951 | 0.007 |
29 | XYLENE, O- | 1193 | 14.343 | 0.013 |
30 | PYRIDINE | 1194 | 14.372 | 0.033 |
31 | DODECANE | 1196 | 14.444 | 0.157 |
32 | LIMONENE | 1202 | 14.604 | 0.077 |
33 | ISOAMYL ALCOHOL | 1208 | 14.797 | 0.023 |
34 | BENZENE, PROPYL- | 1216 | 15.001 | 0.027 |
35 | HEXENAL, 2E- | 1227 | 15.325 | 0.053 |
36 | TOLUENE, 4-ETHYL- | 1233 | 15.479 | 0.123 |
37 | PENTYL FURAN-2 | 1236 | 15.552 | 0.037 |
38 | BENZENE, 1,2,4-TRIMETHYL- | 1253 | 16.031 | 0.037 |
39 | STYRENE | 1268 | 16.452 | 0.077 |
40 | TOLUENE, 2-ETHYL- | 1271 | 16.543 | 0.070 |
41 | METHYL TETRAHYDROFURANONE, 2,3- | 1277 | 16.698 | 0.100 |
42 | CYMENE, P- | 1278 | 16.742 | 0.010 |
43 | BENZENE, 1,3,5-TRIMETHYL- | 1292 | 17.124 | 0.210 |
44 | TRIDECANE | 1298 | 17.298 | 0.117 |
45 | BENZENE, SEC.-BUTYL- | 1312 | 17.685 | 0.043 |
46 | PROPANOL, 2-OXO- | 1317 | 17.806 | 0.107 |
47 | CYMENE, O- | 1335 | 18.294 | 0.013 |
48 | STYRENE, ALPHA-METHYL- | 1343 | 18.507 | 0.033 |
49 | METHYL HEPTENONE, 6,5,2- | 1346 | 18.584 | 0.117 |
50 | BENZENE, 1,3,5-TRIMETHYL- | 1350 | 18.696 | 0.040 |
51 | ETHYL LACTATE | 1351 | 18.73 | 0.013 |
52 | DIACETON ALCOHOL | 1375 | 19.383 | 0.077 |
53 | TRIMETHYLTHIAZOLE, 2,4,5- | 1383 | 19.586 | 0.030 |
54 | HEXYL ACETATE, 2-ETHYL- | 1387 | 19.716 | 0.123 |
55 | TETRADECANE | 1398 | 20.011 | 0.090 |
56 | ALDEHYDE C 9 | 1401 | 20.089 | 0.037 |
57 | ETHLENE GLYCOL MONOBUTYL ETHER | 1409 | 20.287 | 0.220 |
58 | OCTEN-2-ONE, 3E- | 1417 | 20.505 | 0.003 |
59 | DIMETHYLSTYRENE, P- | 1450 | 21.356 | 0.053 |
60 | HEXYL PROPIONATE, 2-ETHYL- | 1451 | 21.38 | 0.037 |
61 | ACETIC ACID | 1462 | 21.646 | 0.950 |
62 | PYRIDIN, 5-ISOPROPYL-2-METHYL- | 1473 | 21.941 | 0.040 |
63 | FURFURAL | 1481 | 22.135 | 0.253 |
64 | DOWANOL DPM P.1 | 1489 | 22.362 | 0.037 |
65 | ISOOCTANOL | 1491 | 22.405 | 0.783 |
66 | PENTADECANE | 1499 | 22.599 | 0.113 |
67 | HEPTADIENAL, 2E,4E- | 1508 | 22.836 | 0.023 |
68 | PROPYLENE GLYCOL DIACETATE 1,2- | 1520 | 23.131 | 0.043 |
69 | DOWANOL DPM P.3 | 1531 | 23.387 | 0.107 |
70 | BENZALDEHYDE | 1545 | 23.74 | 0.363 |
71 | BUTANEDIOL, 2,3- P.1 | 1546 | 23.779 | 0.030 |
72 | LINALOOL | 1549 | 23.847 | 0.100 |
73 | PROPANOIC ACID | 1550 | 23.861 | 0.023 |
74 | LINALYL ACETATE | 1562 | 24.156 | 0.003 |
75 | 2-HYDROXYPROPYL ACETATE | 1580 | 24.606 | 1.666 |
76 | BUTANEDIOL, 2,3- P.2 | 1582 | 24.664 | 0.093 |
77 | METHYLFURFURAL, 5- | 1592 | 24.891 | 0.027 |
78 | HEXADECANE | 1598 | 25.056 | 0.150 |
79 | PROPYLENE GLYCOL, 1,2- | 1602 | 25.153 | 10.337 |
80 | PROTOANEMONINE | 1608 | 25.293 | 0.110 |
81 | 1-HYDROXY-2-PROPYL ACETATE | 1623 | 25.631 | 0.720 |
82 | SOLUTOL A | 1630 | 25.791 | 0.073 |
83 | BUTYRIC ACID | 1639 | 26.009 | 0.013 |
84 | MENTHOL | 1649 | 26.231 | 0.203 |
85 | BUTYROLACTONE, GAMMA- | 1659 | 26.478 | 0.117 |
86 | FURFURYL ALCOHOL | 1671 | 26.763 | 0.143 |
87 | ACETOPHENONE | 1674 | 26.816 | 0.153 |
88 | ISOVALERIC ACID | 1680 | 26.962 | 0.023 |
89 | METHYLBUTYRIC ACID, 2- | 1681 | 26.981 | 0.037 |
90 | HEPTADECANE | 1699 | 27.397 | 0.033 |
91 | CETOISOPHORONE | 1714 | 27.735 | 0.090 |
92 | FURFURYL ALCOHOL, 5-METHYL- | 1732 | 28.132 | 0.093 |
93 | SOLANONE E | 1741 | 28.33 | 0.413 |
94 | BENZYL ACETATE | 1747 | 28.471 | 0.033 |
95 | VALERIC ACID | 1749 | 28.519 | 0.057 |
96 | NAPHTHALENE | 1770 | 28.974 | 0.040 |
97 | Benzene, 3-cyclohexen-1-yl-? | 1775 | 29.085 | 0.133 |
98 | CROTONIC ACID | 1789 | 29.404 | 0.073 |
99 | DOWANOL DB | 1805 | 29.747 | 0.073 |
100 | BUTANONE, 1-PHENYL-2- | 1826 | 30.188 | 0.137 |
101 | PHENYLETHYL ALCOHOL, 1- | 1829 | 30.26 | 0.017 |
102 | DAMASCONE, BETA- | 1836 | 30.4 | 0.150 |
103 | DAMASCENONE, BETA- | 1841 | 30.507 | 0.163 |
104 | METHYL CYCLOPENTENOLONE, 3,2,2- | 1849 | 30.691 | 0.070 |
105 | CAPRONIC ACID | 1856 | 30.841 | 0.053 |
106 | COOLING AGENT WS23 | 1860 | 30.908 | 0.173 |
107 | GERANYLPROPANONE | 1867 | 31.058 | 0.207 |
108 | BUTYRIC ACID-3-HYDROXY-2,2,4-TRIMETHYL-PENTYLESTER, ISO- | 1880 | 31.334 | 0.223 |
109 | GUAIACOL | 1882 | 31.377 | 0.013 |
110 | 2,2,4-TRIMETHYL-1,3-PENTANEDIOL DIISOBUTYRATE | 1890 | 31.561 | 26.366 |
111 | NICOTINE | 1894 | 31.634 | 34.021 |
112 | BENZYLALCOHOL | 1896 | 31.668 | 0.543 |
113 | Propanoic acid, 2-methyl-, 2,2-dimethyl-1-(2-hydroxy-1-methylethyl)propyl ester | 1900 | 31.764 | 0.157 |
114 | BHT IONOL | 1924 | 32.258 | 0.593 |
115 | NEOPHYTADIENE | 1929 | 32.354 | 5.392 |
116 | PHENYLETHYL ALCOHOL, 2- | 1932 | 32.408 | 0.277 |
117 | IONONE, BETA- | 1960 | 32.973 | 0.037 |
118 | ALCOHOL C 12 | 1970 | 33.172 | 0.020 |
119 | DIETHYLENE GLYCOL | 1989 | 33.554 | 0.033 |
120 | MALTOL | 1990 | 33.593 | 0.123 |
121 | ACETYLPYRROLE-2 | 1996 | 33.699 | 0.360 |
122 | IONONE, 5,6-EPOXY- | 2016 | 34.086 | 0.037 |
123 | PHENOL | 2027 | 34.304 | 0.047 |
124 | EDULANE, TRANS-7-OXO- | 2031 | 34.376 | 0.187 |
125 | PYRROLALDEHYDE, 2- | 2055 | 34.845 | 0.100 |
126 | FURANONE, 4,4-DIMETHYL-3-HYDROXY-4,5-DH-2(3H)- | 2062 | 34.976 | 0.217 |
127 | CAPRYLIC ACID | 2069 | 35.126 | 0.193 |
128 | PYRROLIDONE, 2- | 2070 | 35.131 | 0.060 |
129 | TRIACETIN | 2086 | 35.445 | 5.728 |
130 | CRESOL, P- | 2103 | 35.769 | 0.003 |
131 | CRESOL, M- | 2111 | 35.929 | 0.007 |
132 | PYRROLE, 2-FORMYL-5-METHYL- | 2133 | 36.34 | 0.043 |
133 | CEDROL | 2148 | 36.606 | 0.007 |
134 | NORSOLADIONE | 2172 | 37.056 | 0.023 |
135 | PELARGONIC ACID | 2175 | 37.118 | 0.107 |
136 | BOVOLIDE | 2181 | 37.225 | 0.020 |
137 | TABANONE P.3 | 2187 | 37.336 | 0.187 |
138 | VINYLGUAIACOL, 4- | 2223 | 37.975 | 0.020 |
140 | TABANONE P.4 | 2231 | 38.124 | 0.327 |
141 | GLYCERIN DIACETATE (DIACETIN) | 2242 | 38.313 | 0.183 |
142 | MASSOIALACTONE | 2252 | 38.497 | 0.300 |
143 | ETHYL PALMITATE | 2259 | 38.632 | 0.010 |
144 | CAPRIC ACID | 2282 | 39.029 | 0.097 |
145 | MALEIMIDE, METHYLETHYL- | 2296 | 39.29 | 0.047 |
146 | PYRANONE, 3,5-DIHYDROX- 6-METHYL2,3-DH-4- | 2302 | 39.387 | 0.350 |
147 | FRESCOLAT MGA | 2323 | 39.74 | 0.057 |
148 | TABANONE P.5 | 2335 | 39.953 | 0.177 |
149 | Nicotyrine | 2361 | 40.398 | 0.070 |
150 | DIHYDRO ACTINIDIOLIDE | 2397 | 41.017 | 0.173 |
151 | BENZOIC ACID | 2463 | 42.091 | 0.023 |
152 | LAURIC ACID | 2494 | 42.603 | 0.020 |
153 | DAMASCONE, 3-HYDROXY-BETA- | 2562 | 43.696 | 0.010 |
154 | MALZOXAZINE | 2600 | 44.301 | 0.010 |
155 | IONOL, 3-OXO-ALPHA- P.1 | 2666 | 45.404 | 0.013 |
156 | MYRISTIC ACID | 2706 | 46.09 | 0.023 |
157 | PALMITIC ACID | 2917 | 50.661 | 0.300 |
Sum | 99.44 |
