PmT DRO | ||
Parameters | Specifications | |
Model | 4000 Series | 4100 Series |
Frequency Range | 3 to 12 GHz | 3 to 12 GHz |
Tuning | Mechanical | Electrical |
Tuning Range,Min. | ±10 MHz | ±5 MHz |
Power Output,Min. | 13 dBm | 13 dBm |
Power Output,Max | 3 dB | 3 dB |
Frequency Accuracy,Max. | 0.1% | 0.1% |
Operating Temperature | -50 to+100 ℃ | -50 to+100 ℃ |
Storage Temperature | -55 to +125 ℃ | -55 to+125 ℃ |
Temperature Stability,Max. | ±0.05% | ±0.05% |
Harmonics,Below Carrier,Max. | -20 dBc | -20 dBc |
Spurious Output Below Carrier,Max. | -60 dBc | -60 dBc |
Phase Noise 10 KHz offset 100 KHz offset 1 MHz offset | @10 GHz -92 dBc/Hz -115 dBc/Hz -142 dBc/Hz | @10 GHz -92 dBc/Hz -115 dBc/Hz -142 dBc/Hz |
Input Voltage | +15±0.5 VDC | +15±0.5 VDC |
Input Current,Max. | 75 mA | 75 mA |
Connector | SMA Female standard | SMA Female standard |
Weight,Max. | 3.0 oz | 3.0 oz. |
Size | See Outline | See Outline |
Order Information | PmT-DRO-4000 Series- Frequency(GHz) | PmT-DRO-4100 Series- Frequency (GHz) |
