型号 | XWSF | ||
输入电压 | 三相四线AC380V±15% | 电流波形 | 正弦波 |
输出电压 | 三相三线AC200V±10% | 驱动形式 | SPWM |
工作频率 | 50Hz-60Hz | 电压调整率 | 0.2% |
基波频率 | 300Hz | 负载调整率 | 0.1% |
伺服负载数量 | 不限 | 电压失真率 | 0.1% |
响应时间 | <1.5us | 抗干扰等级 | B |
最大过载能力 | 2倍额定电流 | 最大输出电流 | 变压器容量≥伺服电机总功率*1.1倍 |
型号 | 容量 | 对应伺服功率 |
XWSF-1 | 1KVA | ≤1KW |
XWSF-2 | 2KVA | ≤2KW |
XWSF-3 | 3KVA | ≤2.7KW |
XWSF-4.5 | 4.5KVA | ≤4KW |
XWSF-5 | 5KVA | ≤4.8KW |
XWSF-5.5 | 5.5KVA | ≤5KW |
XWSF-6 | 6KVA | ≤5.5KW |
XWSF-7 | 7KVA | ≤6.8KW |
XWSF-7.5 | 7.5KVA | ≤7KW |
XWSF-8 | 8KVA | ≤7.5KW |
XWSF-11 | 11KVA | ≤9.8KW |
XWSF-15 | 15KVA | ≤13.5KW |
XWSF-20 | 20KVA | ≤18KW |
XWSF-30 | 30KVA | ≤27KW |
XWSF-45 | 45KVA | ≤40KW |
XWSF-50 | 50KVA | ≤45KW |
XWSF-55 | 55KVA | ≤50KW |
XWSF-60 | 60KVA | ≤55KW |
XWSF-65 | 65KVA | ≤60KW |
XWSF-70 | 70KVA | ≤65KW |
