awpcd
第2楼2007/05/16
DATA ELEMENTS REQUIRED FOR ASSAY VALIDATION
Compendial assay procedures vary from highly exacting analytical determinations to subjective evaluation of attributes.Considering this variety of assays,it is only logical that different test methods require different validation schemes.This chapter covers only the most common categories of assays for which validation data should be required.These categories are as follows.
Category I: Analytical methods for quantitation of major components of bulk drug substances or active ingredients (including preservatives)in finished pharmaceutical products.
Category II: Analytical methods for determination of impurities in bulk drug substances or degradation compounds in finished pharmaceutical products.These methods include quantitative assays and limit tests.
Category III: Analytical methods for determination of performance characteristics (e.g.,dissolution,drug release).
Category IV: Identification tests.
For each assay category,different analytical information is needed.Listed in Table 2are data elements normally required for each of the categories of assays.
还有就是USP附录1225中有说明,但我不清楚像我这种只改变色谱柱,要做哪些验证,是全套还是其中某一个就行
