heatwind
第4楼2007/10/12
So you think my TEM machine was not properly aligned.
you know this machine was just aligned by FEI engineer a month ago.
Before they left, they saved several aligned modes for me to use. If I realigned the HM-TEM beam, do you think it will affect those modes they saved?
Anyway, thank you for your kindness!
mars9tw
第5楼2007/10/13
Since they just aligned it, did you ask them about this problem?
BTW, there is no such a problem in our Tecnai F30.
