1、RPA-C01 碳含量测定仪
RPA-C01 碳含量测定仪是一种基于红外检测原理的新型碳含量测定仪器。样品经高温燃烧后,其中的碳转化成CO2,CO2被引入红外检测池,由于CO2吸收一定量的红外能量,从而引起仪器检测端信号的变化,依朗伯比尔定律,即可计算出样品中的碳含量。仪器相比于传统的化学法,具有快速、准确、无需任何化学试剂等优点,可广泛应用于石油、煤炭、化工等行业中,固体样品的碳含量检测。
主要特点
1. 红外检测及电路系统设计合理,抗干扰能力强,分析结果准确、可靠。
2. 仪器配套数据工作站,操作直观、方便、分析过程中动态显示各项实时数据和分析谱图,设计具有多条曲线储存、重现、比较、打印等功能。
3. 仪器整机设计采用模块化结构、布局紧凑、合理、维护方便。
主要技术指标:
1. 检测范围:0.01~10%
2. 分析误差:a)0.01~0.1% 相对误差≤10%
b)大于0.1%~10% 相对误差≤5%
3. 分析时间:约1分钟
4. 裂解炉功耗:2KW
1、RPA-C01 Carbon Content Analyzer
RPA-C01 Carbon Content Analyzer is a new carbon detector based on the infrared detection principle. The carbon is converted to CO2 which is introduced into the IR detection cell after the sample is pyralyzed. CO2 absorbs a definite amount of energy to resust in the change of detection signal in instrument. Based in thd Lambert-Bill law, the carbon content can be calculated. Compared with the routine chemical analysis,this measurement is mainly based on the conversion of physical amount without any chemical reahent, and has many advantages such as sensitive,speedy and accurate. This analyzer can be widely used in the analysis of sulphur content in gas, liquid and solid samples in the field of petroleum,coal and chemical industry etc.
Main Characteristics:
1. Reasonsble design of detection and electrical system, good anti-interference ability and accurate analytical results.
2. Assembled with a data workstation with viewable display and convenient operation which can display the real-time analytical data and graphs and has many functions as storage reproduction,comparation and print of multi-curves.
3. This device utilizes blocd structure with compact construction
Main Specifications
1. Determination range:0.01~10%
2. Analytical Error: a)0.01~0.1% Relative Error≤10%
b)More than 0.1%~10% Relative Error≤5%
3. Analysis Time:About 1 minute
4. Furnace Power:2kw
2、RPA-100H气中氢含量测定仪
RPA-100H气中氢含量测定仪是由中石化石油化工科学研究院和江苏江环分析仪器有限公司联合研制的一种测量气体中氢气含量的分析仪器。仪器利用选择性氢分离膜从样品气中分离出氢气后进入热导检测器,进行测定。克服了常规氢分析仪由于标准气和样品气气体组成不同而引起的测量误差,仪器具有适应气体范围广,测量线性范围宽,灵敏度高,对进样体积的准确性无要求等优点。仪器的操作步骤,分析谱图,测量结果等由计算机处理后在彩色液晶屏上直接显示,操作简便,直观。可广泛应用于石油化工,化工,食品,化肥,发电等行业。该仪器的测量原理及关键器件已申请国家了明专利。
性能指标:(1)测量范围:1~100%(体%)
(2)单次分析时间:3min
(3)测量精度:a、≤10%氢浓度单位(H2含量1 -10%)
b、≤5%氢浓度单位(H2含量10-20%)
c、≤2%氢浓度单位(H2含量20-100%)
2、RPA-100H Hydrogen-in-Gas Detector
RPA-100H Hydrogen-in-gas Detector is an analytical device for the detection of hydrogen content in gas which is developed by Research Institute of Processing and Jiang Su Jiang Huan Analytical Instrumentation Ltd.Co. This detector utilizes the selective hydrogen separation membrane to separate hydrogen from the gas sample. Then the separated hydrogen is introdrced into the thermoconductive detector to complete analysis. Compared with the conventional hydrogen analyzer which has measurement error resulting from the different components of standard gas and sample gas , this detector has many characteristics such as wide gas range,wide linear range of measurement, high sensitivity,without special requirements for the accuracy of sampling volume etc. After the processing with computer, the operation procedures,analytical graphs and measurement results etc. can bc directly displayed on the color LCD screen and be operated simply . It can be widely used in the petrochemical, chemical,food,fertilizer and power industry etc.The measurement principle and key components has obtained the China patent.
Specifications
(1)Measurement Range:1~100%(v/v%)
(2)Time perAnalysis:3min
(3)Measurement Precision:a、≤10%hydrogen concentration(H2 content1-10%)
b、≤5%hydrogen concentration(H2 content10-20%)
c、≤2%hydrogen concentration(H2 content20-100%)
3、RPA-S03硫含量测定仪
RPA-S03硫含量测定仪是一种基于红外检测原理的新型硫含量测定仪器。样品经高温燃烧,其中的硫转化为SO2和SO3,当条件固定时产生SO2和SO3的比例不变。当SO2引入红外检测池后,由于SO2吸收一定量的红外能量,从而引起仪器检测端信号的变化,根据郎伯一比尔定律,即可求出样品中硫含量。仪器与传统的化学分析方法相比,测定过程主要依据物理量的转换,无需任何化学试剂,因而具有灵敏、快速、准确的优点,可广泛用于石油、煤炭、化工等行业中气体、液体、固体样品含硫量的分析。
主要特点:
1. 仪器的检测及电路系统设计合理,抗干扰能力强,分析结果准确、可靠。
3. 仪器整机设计采用模块化结构,布局紧凑、合理,维护方便。
主要技术指标:
1. 检测范围:0.01~10%
b) 0. 1~10% 相对误差≤5%
3. 分析时间:约1分钟
4. 裂解炉功能:2kw
3、RPA-03Sulphur Content Analyzer
RPA-S03 Sulphur Content Analyzer is a new sulphur detector based on the infrared detection principle. The sulphur is concerted to SO2&SO3 when the sample is pyralyzed. When the condition is stable,the ratio of SO2 and SO3 is fixed. When SO2 is introduced into the infrared detection cell, SO3 adsorbs a definite amount of energy to result in the change of detection signal in instrument.Based on the lambert-bill law,the sulphur content in the sample can be calculated. Compared with the law,the sulphur content in the sample can be calculated. Compared with the routine chemical analysis, this measurement is mainly based on the conversion of physical amount without any chemical reahent,and has mant advantages such as sensitive,speedy and accurate. This analyzer can be widely used in the analysis of sulphur content in gas, liquid and solid samples is the field of petroleum, coal and chemical industry etc.
1. Reasonable design of detection and electrical system,good anti-interference ability and accurate analytical results.
2. Assembled with a data workstation with viewable display and convenient operation which can display the real-time analytical data and graphs and has many functions as storage,reproduction,comparation and print of multi-curves.
3. This device utilizes block stucture with compact construction.
Main Specifications
2. Analytical Error: a)0.01%~0.1% Relative Error≤10%
b)More than 0.1%to10% Relative Error≤5%
阅读1764次
已关注
