RPA-001荧光色层仪
本仪器采用两根吸附柱。其吸附柱、硅胶、指示剂等均为进口产品。方法符合ASTMD1319及GB/T 11132方法的要求。
RPA-001 Fluoresent Chromographic Analyzer
The analyzer is assembled with tow columns. The adsorption columns,silica gel and indicator etc are imported from abroad. The method conforms to the requirements of ASTMD1319&GB/T11132
RPA-002荧光色层仪
本仪器采用四根吸附柱。其吸附柱、硅胶、指示剂等均为进口产品。方法符合ASTMD1319及GB/T 11132方法的要求。
The analyzer is assembled with four columns. The adsorption columns,silica gel and indicator etc are imported from abroad. The method conforms to the requirements of ASTMD1319&GB/T11132
HC系列两用型气相色谱仪
采用快速毛细管色谱分离,检测原理,可以分离分析天然气、原油、各种石油馏份中烃类组成与分布。方发符合ASTM及国标气相色谱分析标准
在环保领域中可以测定水、空气、土壤中各种挥发性有机物污染,符合国际规定各种气相色谱标准。
HC Series Dural-Purpose Gas Chromatograph
This analyzer utilizes rapid capillary chromatography principle for separation and detection to determine the composition and distribution of hydrocarbons in natural gas, crude oil and various oil products. This method conforms to ASTM and China national standard for gas chromatography.
It can determine the volatile organic contaminants in water, air and soil.
高纯气体发生器
在石油、化工、石油化工、环保、卫生、电力、煤炭、商检等众多领域的分析中,都需要采用N2、O2、H2、空气等气体,一般采用钢瓶气,气体纯度及采购、更换较为麻烦。我们的产品:高纯氢气发生器GH-10,低噪音无油空气泵GA-20,高纯氮器发生器GN-30,高纯氧气发生器GO-50,解决了这些问题。
High Purity Gas Generators
In the analysis of petrdeum, chemical, petrochemical, environmental protection, sanitary, bevarage, electric Power, coal and commercial detection, the gases as N2、O2、H2, pure gas are always used. The purity, purchase and replacement are troublesome. Our products, GH-10、GA-20、GN-30、GO-50 , solve these problems.
阅读1068次
已关注
