方案下载应用领域 | 生物产业 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 0 |
The ability to monitor kinetic process occurring on the millisecond timescale has been demonstrated by the simple addition of a stopped flow accessory to the DeltaFlex system. This was operated in the kinetic TCSPC measurement mode and was aided by the use of a high repetition rate excitation source coupled with very low dead time electronics to efficiency collect the data. The data obtained clearly shows the advantage of using the fluorescence lifetime in this case, to obtain obtain kinetics unaffected by sample photobleaching.
颗粒分析+混合氧化石墨烯+分散状态的混合比例
颗粒分析+聚苯乙烯乳胶混合样品+粒径分布
颗粒分析+二氧化硅+CMP浆料质量控制
HORIBA XploRA Nano原子力-拉曼联用系统
HORIBA高灵敏一体式FluoroMax-4荧光光谱仪
HORIBA Fluorolog®-3科研级荧光光谱仪
HORIBA XploRA INV多功能拉曼及成像光谱仪
HORIBA EMGA-Expert 氧氮氢分析仪
HORIBA EMGA-Pro氧氮氢分析仪
HORIBA 离心式粒度分析仪Partica CENTRIFUGE CN-300
HORIBA Fluorolog-QM模块化科研级稳瞬态荧光光谱仪
ViewSizer 3000 纳米颗粒追踪分析仪
HORIBA LabRAM Odyssey 高速高分辨显微共焦拉曼光谱仪
HORIBA LabRAM Soleil™高分辨超灵敏智能拉曼成像仪
HORIBA NANO Raman
HORIBA XGT-9000 X射线显微分析仪
HORIBA Duetta荧光及吸收光谱仪
HORIBA MacroRAM 台式一体化拉曼光谱仪
