Using Atomic Force Microscopy (AFM) for Engineering Low-Scatter Thin Film Optics
2008/06/19   下载量: 59
方案下载
应用领域
检测样本
检测项目
参考标准
The quality of optical components used in complex applications such as lasers, microscopes, and lithography systems, is critically influenced by surface morphology. The majority of these components – lenses, mirrors, beamsplitters, polarizers, etc.– are covered by thin film optical coatings. Hence, important properties of the optical elements such as optical scattering, are significantly affected by the surface microstructure of the thin film coating. With the ongoing trend of today’s optical lithography towards shorter wavelengths (e.g. lithographic objective shifting from 248nm to 193nm), thin film research and industry are facing drastically increasing requirements for low-scatter optics in the UV, and deep UV, spectral region.
方案下载
上一篇 台阶仪在三维形貌表征领域的应用
下一篇 原子力显微镜在隐形眼镜生产中的应用
文献贡献者
相关方案
当前位置: Bruker Nano Surfaces 方案 Using Atomic Force Microscopy (AFM) for Engineering Low-Scatter Thin Film Optics
