方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The crispness of food materials based on the force/displacement behavior and their acoustic nature was assessed using an Acoustic Envelope Detector (AED) attached to the Texture Analyzer, wherein six kinds of biscuits were used: Carr’s Table Water, Crackerbread, Digestive, Dutch Crispbakes, Rich Tea fingers and Shortbread. The force/displacement and acoustic signals were simultaneously recorded during the breakup of biscuits. For each detected acoustic signal, there was a sudden drop in the compression force. The analysis of the force/displacement curve demonstrated the links between the second derivative of force curve and the acoustic event, indicating the energy released through the air of these crack events. The acoustic behavior of the biscuits was assessed in terms of maximum sound pressure level and the number of acoustic events, which were further interpreted as the acoustic events per unit area of newly created surface area and the acoustic event per unit time. The acoustic ranking of biscuits from instrumental assessment was in very good agreement with that from sensory panel tests. The normal integration time (1.25 ms) for the AED was generally effective in detecting acoustic signals for crisp biscuits, but a shorter integration time (0.25 ms) was found advantageous in detecting acoustic signals that occur within a very short time period and gave better differentiation of crisp biscuits.
冲泡饮品开放式粉体测试
亲水胶体产品质地特性
番茄酱流动特性评估
英国SMS超技质构仪 物性分析仪-TA.XT PlusC
包装材料强度质构仪 摩擦系数/剥离强度测试仪
药物制剂多功能物性分析仪 医药分析仪
质构分析仪-物性测试仪Texture Analyser
烟叶梗丝结构仪 烟草质构测试仪 烟草柔韧性分析仪
医药 质构分析仪 物性分析仪- 英国SMS 超技仪器
英国SMS质构仪(物性分析仪)—TA.XT ExpressC
英国SMS 超技质构仪—TA.HD PlusC
英国SMS食品体积测定仪
Calibre C-CELL孔隙组织影像分析系统
英国SMS粉体流变仪
全自动细胞动态培养仪
细胞拉伸仪
Eco Physics氮氧化物分析仪CLD 80/800系列
Eco Physics氮氧化物分析仪CLD 60系列
