方案下载应用领域 | 生物产业 |
检测样本 | 其他 |
检测项目 | |
参考标准 | / |
It is generally understood that chiral compounds have different bioactivities depending upon the absolute configuration of each compound. Some familiar examples include glutamic acid and thalidomide. Lglutamic acid demonstrates the “Umami” taste*1, while D-glutamic acid has a bitter taste, similarly, the R form of thalidomide is a sedative, but the S form has teratogenic activity. Thus, the separation and study of chiral compounds is critical for many reasons. The functionalities of chiral compounds have been studied for the development of advanced molecules for many applications. The study of chiral compounds has spread to several fields such as natural products, pharmaceuticals and other functional molecules, and it can be pointed out that among those studies, the structural analysis of chiral compounds is a very important topic. X-ray Diffraction (XRD), Nuclear Magnetic Resonance (NMR) and Electronic Circular Dichroism (ECD) using UV/Vis light are employed as primary methods for the structural analysis of chiral compounds. In this paper, the measurement of chiral compounds by Vibrational Circular Dichroism (VCD) using infrared light will be outlined. VCD is a method to measure the difference of absorbance intensity between left-hand and right-hand circularly polarized light as shown in Figure 1. It is an advantage of VCD that this method can be applied to almost all organic compounds in the same way as infrared (IR) spectroscopy. In addition, by comparing the measurement results with calculated results by ab-initio molecular orbital calculations, the absolute configuration of the sample can be determined. However, since the peak intensity of VCD spectra are 1,000 – 10,000 times weaker than that of standard IR spectra, spectroscopic instruments with high sensitivity and stability with very small baseline fluctuations are required. The FVS-6000 VCD system has a high sensitivity detector, suitable optical
outlined.
HPLC 中的采样频率、响应时间和柱外效应
基于抗体的药物强制降解研究中聚集物和降解产物的SEC监测
用CD光谱法评估VHH抗体的高阶结构、稳定性和相似性
JASCO圆二色光谱仪CD J-1500
JASCO振动圆二色光谱仪VCD FVS-6000
JASCO圆偏振荧光光谱仪CPL-300
JASCO高效色谱仪LC-4000
jascoRFT-6000傅立叶变换红外拉曼光谱仪
JASCO红外显微镜IRT-7200
MSV-5000显微紫外可见近红外分光光度计
jasco紫外可见分光光度计 V-700
JASCO FTIR-4000傅立叶变换红外光谱仪
JASCO 全自动数字旋光仪P-2000
JASCOFP-8000系列荧光光谱仪
JASCO SFC4000超临界流体色谱仪
JASCONRS5000/7000共聚焦激光拉曼光谱仪
JASCO V-7000系列紫外可见近红外分光光度计
JASCO傅立叶变换红外光谱仪FT/IR-6000
