当前位置: 油墨 > 方案详情
表面,流体中3D表面形貌,速度场,速度矢量场检测方案(粒子图像测速)
检测样品 油墨
检测项目 3D表面形貌,速度场,速度矢量场
关联设备 共3种 下载方案
方案详情
Many materials, such as paints, clay suspensions, concrete or inks, are complex fluids which present non-Newtonian properties. To define their rheological properties and particularly for coarse suspensions (debris mud, sediments…), we need to develop specific devices because of the size of the particles within the fluid to reach the continuum assumption. The study of the inclined plane flows can be a solution as soon as we are able to measure the evolution of the free surface and the surface velocity during the flow. We have developed specific 3D measurements based on stereovision to extract rheological properties of two materials flowing down an inclined flow. First a shear thinning fluid (a polyoxyde ethylene solution) is used to validate the method which is then applied to a viscoplastic material (a bentonite suspension). The comparison of the results with conventional measurements using a rheometer is in good agreement.
关闭
产品配置单
北京欧兰科技发展有限公司为您提供《表面,流体中3D表面形貌,速度场,速度矢量场检测方案(粒子图像测速)》,该方案主要用于油墨中3D表面形貌,速度场,速度矢量场检测,参考标准《暂无》,《表面,流体中3D表面形貌,速度场,速度矢量场检测方案(粒子图像测速)》用到的仪器有德国LaVision 表面PIV、德国LaVision PIV/PLIF粒子成像测速场仪、LaVision StrainMaster材料应变形变成像测量系统。
我要纠错
推荐专场
相关方案
