KEM Application Note No.KCZ-09189Kyoto ElectronicsNo.LN37-09169 No.KCZ-09189 Bromine number Measurement (Coulometry) Bromine number of decene -Abstract一 With MKC-520, measurement of bromine number of decene resulted with goodrepeatability, and it is considered to be practical to use MKC-520. -Equipment- Main unit : Coulometric KF moisture titratorMKC-520Electrode : Twin Pt electrode M-713 Inner cell (#433-0006) -Reagent- Anolyte : mixture of acetic acid 600mL, methanol 260mL,1M-potassium bromide140mL Catholyte : 0.2M-potassium chloride -Method- Pretreatment ① Added 7.007g(Wt1) decene to 100mL flask, and diluted with toluene up to theline and weighed at (wt2:86.605g). ② Added 1mL of solution to 100mL flask and diluted with toluene to the line. ③Dilution ratio was obtained from eq: Dilution ratio=Wt2/Wt1×100=1211 Preparation Added anolyte to titration cell and catholyte to the inner cell. ② Added 1mL sample and performed Pre-Titration to stabilize drift level. Measurement ① Approx. 1.7g sample was measured to determine bromine number of sample. 一Calculation- Bromine index (g/100g):((Data-Driftxt-Blank)/(Wt1-Wt2))xDx0.0001xF Data: measured bromine (ug) Wt1: sample+tare (g) Drift : drift level at start (ug/s) Wt2: weight of tare (g) t: measure time (s) D: dilution ratio (1211) F=1.00 : factor Blank : blank level (ug) -Ambient condition- Room temperature: 21.9℃ Humidity:50% Weather: fine -Measurement parameter一 一Measurement data- [Titration] Method 5 t(stir) 0s t(wait) 15 s t(max) 0s Drift Stop:: Rel 1.00 ug/s Cont. Gain 5.0 Stable 0.5 ug/minStart : Auto [Calculation] Calc. No. 7 Unit :g/100g Weight : Fixed Drift Comp:Auto ***Result *** Sample No. 01-01 Date 2009/05/09 13:48 Titr. Cell No.. 1 Wt1 69.631 g Wt2 67.881 g Net 1.750 g D 1211 Result 1828.9 ug 126.56 g/100g ***Result *** Sample No. 01-02 Date 2009/05/09 14:17 Titr. Cell No. 1 Wt1 68.721g Wt2 66.724g Net 1.997g D 1211 Result 2084.2 ug 126.39 mg/100g 一·Results-一 Run Size Bromine(ug) Conc.(g/100g) Statistics (mg/100g) 1st2nd3rd 1.750 1.997 1.666 1828.92084.2 1726.7 126.56126.39 125.51 Mean SD RSD 126.15 0.56 0.45% -Comment一 Measurement of bromine number by coulometric method requires dilution ofsample. For solvent use toluene which is easy to handle and stable.
关闭产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《癸烯中溴价含量检测方案 》,该方案主要用于其他中溴价含量检测,参考标准《暂无》,《癸烯中溴价含量检测方案 》用到的仪器有MKH-710M容量法库仑法混合型卡尔费休水分仪、MKC-710B卡尔费休库仑法微量水分测定仪、MKC-710S豪华型库仑法卡尔费休水分仪、MKC-710M四通道旗舰型库仑法卡尔费休水分仪。
