HPLC DATA 'SHEET 夕工于了匕少7又儿酸墟锭Quetiapine fumarate fine tablets P130808D Dissolution: Standard solution*'(0.016 mg/mL Quetiapine fumarate) Column :YMCbasic (5 um, 20 nm) 75X4.6mml.D. Eluent :methanol/acetonitrile/(NH4)2HPO4aq *2 (54/7/39) *Dissolve 3.3 g of (NH4)2HPO4 in 1250 mL of waterFlow rate : 1.0 mL/min (adjust the flow rate so that the retention time of quetiapine is about 4 min)Temperature :25℃Detection : UV at 230 nm Injection : 50 uL (Modified condition of The Japanese Pharmacopoeia 16th Supplement I; Dissolution) * Standard solution was prepared from Quetiapine fumarate supplied as a reagent for laboratory use. 色谱条件见谱图
关闭产品配置单
深圳凯米斯科技有限公司为您提供《富马酸喹硫平片中溶出度检测方案(液相色谱柱)》,该方案主要用于化药制剂中限度检查检测,参考标准《暂无》,《富马酸喹硫平片中溶出度检测方案(液相色谱柱)》用到的仪器有null。
