环氧树脂中黏度检测方案(液相色谱仪)
检测样品
环氧树脂
检测项目
黏度
关联设备
共1种
下载方案
Epoxy resins are complex materials manufactured by the reaction of a ‘resin’ with a ‘hardener’. This produces a cross-linked polymer that is extremely strong, tough and may be used to bond materials together. The resin component of the mixture is an epoxide pre-polymer, typically produced by the reaction of an epoxide with bisphenol-A. The resulting short-chain material contains pendant –OH and epoxide functionalities and is polar in nature. The molecular weight of the epoxide chains in the resin is important as this influences the curing rate of the final epoxy resin formulation when mixed with the hardener, however, accurate molecular weights are difficult to obtain due to the complex, inhomogeneous nature of the epoxide polymer chains. Gel permeation chromatography (GPC) is a well-known technique for assessing the molecular weight distribution of polymers, a property that influences many physical characteristics such as the curing time of epoxy resins. GPC viscometry employing a viscometer in combination with a differential refractive index detector has the advantage of allowing the determination of accurate molecular weights for structurally complex polymers and co-polymers via the Universal Calibration approach. Using this methodology, the same molecular weights are determined for samples regardless of the standards used to create the calibration. This application note describes the analysis of two samples of epoxide pre-polymers by GPC viscometry
安捷伦科技(中国)有限公司为您提供《环氧树脂中黏度检测方案(液相色谱仪)》,该方案主要用于环氧树脂中黏度检测,参考标准《暂无》,《环氧树脂中黏度检测方案(液相色谱仪)》用到的仪器有Agilent 1260 Infinity II 液相色谱系统。
我要纠错
