检测样品 糕点/月饼/粽子
检测项目 食品添加剂
参考标准 GB/T 5009.140 饮料中乙酰磺胺酸钾的测定
银牌会员 474 篇解决方案
超星·期北京豫维科技有限公司联系人:水先生电话:18911849923572017,No.6 58 doi:10.7633/j.issn.1003-6202.2017.06.015 二极管阵列-高效液相色谱法测定月饼中的四种防腐剂 宣 伟 (阜阳市食品药品检验检测中心,安徽阜阳 236000) 摘 要:关于月饼中安赛蜜的检测没有明确的前处理方法,而GB/T 5009.140—2003中对安赛蜜的检测使用的流动相较为复杂,本研究参照 GB/T 5009.140—2003 与 GB/T 23495—2009的处理方法,利用106 g/L亚铁氰化钾溶液- 220 g/L 乙酸锌作蛋白沉淀剂处理样品后,过滤上机,经 Diamonsil Cis柱(250 mm × 4.6 mm,5 um)液相色谱柱分离,甲醇十0.02mol/L乙酸铵溶液(体积比5:95)作为流动相,用二极管阵列检测器进行检测。检测波长选择230 nm,各组分之间分离良好,无干扰,且测定相关系数均在0.9999以上,检测最低限0.000450~0. 000 675 mg/ml(S/N=3),样品加标回收率为92.5%~102.5%。结果表明,该方法可用于月饼中防腐剂的检测。 关键词:月饼;高效液相色谱法;防腐剂;二极管阵列检测器 中图分类号:TS213.23;TS202.3 文献标志码:A 文章编号:1003-6202(2017)06-0057-03 Simultaneous determination of four antimicrobial reagents in mooncake by high performance liquid chromatographywith photo-diode array XUAN Wei (Fuyang Food and Drug Inspection Center,Fuyang 236000,China) ABSTRACT:There is no pretreatment method of Acesulfame Potassium in moon cake. But the mobile phase in the detection ofAcesulfame in GB/T 5009.140—2003 is complex. According to GB/T 5009.140—2003 and GB/T 23495—2009, we treatedsamples with 106 g/L potassium ferrocyanide solution and 220 g/L zinc acetate solution as protein precipitants. Detecting thefiltrate. The analysis were performed on a Diamonsil Cig column ( 250 mm×4.6 mm,5 um) with diode array detector usingmethanol and 0.02 mol/L ammonium acetate solution (5:95) as the mobile phase. The results showed that 230 nm was thebest detection wavelength; the separation between the individual components was good with no interference,and the determina-tion of linear correlation were all above 0.999 9;the lower limits were 0.000 450-0.000 675 mg/ml (S/N=3),the averagespiked recoveries range from 92.5% to 102.5%.It was concluded that the method was suitable in the detection of moon cakeproducts. KEYWORDS:moon cake;high performance liquid chromatography;antimicrobial reagents;photo-diode array detector 月饼作为中秋传统美食,其跨地区流通及其常温的贮藏方式决定其货架期一般比较族。因此,一般添加防腐剂用于延长货架期。GB 2760—2014规定月饼防腐剂中安赛蜜和山梨酸的最大使用量不得超过0.3 mg/kg 和1.0g/kg,苯甲酸和糖精钠按照规定不得检出。但是防腐剂超范围、超限量使用现象仍然存在。GB/T 23495—2009规定了月饼等糕点中的苯甲酸、山梨酸、糖精钠处理与检验方法,但是无糕点中安赛蜜的检测方法。目前,关于安赛 蜜的测定仅仅为饮料中安赛蜜的高效液相色谱法,一方面流动相复杂,另一方面也无具体针对月饼等糕点的具体处理方法[2-3]。因此,本研究结合 GB/T23495—2009与 GB/T 5009.140—2003,探讨在GB/T23495 -2009标准规定的高效液相色谱条件下分离该4种防腐剂的可行性,为节省时间、提高效率、避免相互干扰导致结论的误判以及对标准的修订提供参考。 ( 收稿日期:2017-03-01;修回日期:2017-05-10 ) ( 作者简介:宣 伟(1986-),男,硕士,工程师,研究方向为食品质量安全检测。 ) 超星·期北京豫维科技有限公司联系人:水先生电话:18911849923 宣 伟等:二极管阵列-高效液相色谱法测定月饼中的四种防腐剂/2017年第6期 材料与方法 1.1 材料与试剂 仪器: LC-20AT液相色谱仪(日本岛津公司);超声波清洗器(德国ELMA)。 试剂:除特别说明外均为分析纯。苯甲酸、山梨酸、糖精钠、安塞蜜标准液:浓度均为1.0 mg/ml(国家标准物质中心);甲醇,色谱纯;0.02 mol/L 乙酸铵溶液,称取1.54g乙酸铵用水溶解定容至1000 ml,经0.45 p m 滤膜过滤,超声;220 g/L 乙酸锌溶液;106 g/L亚铁氰化钾溶液。 1.2 方法 1.2.1 样品处理 参照 GB/T 23495—2009,称取粉碎的月饼样品2g于小烧杯中,用20 ml水数次清洗小烧杯将样品移多25ml容量瓶中,超声振荡提取5 min,取出后加2 ml 106 g/L亚铁氰化钾溶液,摇匀,再加入2 ml 220 g/L乙酸锌溶液,摇匀,用水定容至刻度。移入离心管中,4000 r/min离心5 min,吸出上清液,过滤后,滤液待上机分析。 1.2.2 色谱条件 色谱柱:Diamonsil C18 (250 mm ×4.6 mm,粒径5 pm)。 流动相:甲醇+0.02 mol/L 乙酸铵溶液(体积比5:95);流动相流速:1.0 ml/min;进样量:20 pl;检测波长:230nm;柱温:35℃。 2 结果与分析 2.1 检测波长的选择 图1~图4为4种防腐剂的色谱图,由二极管阵列检测器在190~800 nm 内扫描。 图1 安赛蜜的色谱图 对比4种物质的吸收光谱图得知,在200 nm以 下流动相有吸收,造成噪音过高,200 nm 以上,安赛蜜在226.67 nm处最大吸收,苯甲酸在223.89nm处最大吸收;山梨酸在252.98 nm处最大吸收;糖精钠在207.24 nm 处最大吸收。波长250 nm 处苯甲酸、糖精钠灵敏度太低不能满足检测需要,为此选230 nm 为检测波长。 图2 苯甲酸的色谱图 图3 山梨酸的色谱图 波长/nm 图4 糖精钠的色谱图 在1.2.2节色谱条件下测定,各个组分的色谱图如图5所示。 由图5可见,峰形及分离效果均比较好,混合标准溶液中的安赛蜜、苯甲酸、山梨酸和糖精钠4种物质能够完全分离,出峰时间分别是 10.146、12.313、17.288、21.330 min。峰的对称性良好,峰与峰之间的分离效果好,无干扰。 2.3 线性范围和检出限 表1为各个组分的线性范围、线性回归方程、相关系数以及最小检出限。按实验方法进行测定,配置上述四种防腐剂的浓度为0.020、0.040、0.060、0.080、0.100 mg/ml,以各组分的浓度为横坐标,峰面积为纵坐标,得到4种防腐剂的线性方程,并按3倍信噪比计算出各组分的检出限,结果见表1。 由表 1可以看出,最小检出限在0.000 450 mg/ml,其相关系数都在0.9999以上,线性相关性强。 表1 线性范围、线性回归方程、相关系数及最小检出限 组分 线性范围/mg·ml-1 线性回归方程 相关系数r 最小检出限/mg·ml-1 安赛蜜 0.020~0.100 Y=4.34913×10x+17 002.5 0.9999901 0.000450 苯甲酸 0.020~0.100 Y=4.764 29×10x+25 926.6 0.9999814 0.000675 山梨酸 0.020~0.100 Y=9.225 81×10x+43350.9 0.999 985 3 0.000594 糖精钠 0.020~0.100 Y=3.112 13×10x+9 214.32 0.999 9902 0.000513 2.4 样品测定回收率 表2为各个组分的样品回收率,回收率在92...5%~102.5%,满足检测要求。 表2 各组分的样品回收率 组分 样品本底含量 加标值 测定值 回收率 mg·ml-1 mg·ml-1 mg·ml-1 % 安赛蜜 0.040 0.039 97.5 0.060 0.057 95.0 0.040 0.041 102.5 苯甲酸 0.060 0.061 101.7 山梨酸 0.040 0.038 95.0 0.060 0.058 96.7 糖精钠 0.040 0.037 92.5 0.060 0.056 93.3 注:“一”表示未检出。 3 结论 在 GB/T 23495—2009标准规定的高效液相色谱条件下,各个组分之间分离良好,无干扰,食品中 的成分复杂、杂质多。标样的出峰时间在10 min后,能够有效地避免食品中的杂质峰,样品在25 min后检测结束,同样有效地杜绝了食品中的杂质对下一个样品的影响。测定的相关系数均在0.9999以上,检测最低限在0.000 450~0.000 675 mg/ml(S/N=3),样品加标回收率为92.5%~102.5%,符合要求,该法可用于月饼中4种防腐剂的同时检测。 ( [参考文献] ) ( [ 1 1] 卫生部.食品添加剂使用卫生标准:GB2760—20 1 4[ S ].北京:中国标准出版社,2014. ) ( [2] 卫生部.饮料中乙酰磺胺酸钾的测定:GB/T5 0 09.140 一 2003[S].北京:中国标准出版社,2003. ) ( 3 中国标准化研究院.食品中苯甲酸、山梨酸和糖精钠的测定高效液相色谱法:GB/T 2 349 5— 2009[S].北京:中国标准出版 社 , 2009. ) ( (责任编辑:赵琳琳) ) 网址: www. yuweichina. com邮箱water com 于月饼中安赛蜜的检测没有明确的前处理方法,而GB/T 5009.140—2003中对安赛蜜的检测使用的流动相较为复杂,本研究参照GB/T 5009.140—2003与GB/T 23495—2009的处理方法,利用106 g /L亚铁氰化钾溶液+ 220 g/L乙酸锌作蛋白沉淀剂处理样品后,过滤上机,经Diamonsil C18柱(250 mm × 4.6 mm,5 μm)液相色谱柱分离,甲醇+0.02 mol/L乙酸铵溶液(体积比5∶95)作为流动相,用二极管阵列检测器进行检测。检测波长选择230 nm,各组分之间分离良好,无干扰,且测定相关系数均在0.999 9以上,检测最低限0.000 450~0.000 675 mg/ml(S/N=3),样品加标回收率为92.5%~102.5%。结果表明,该方法可用于月饼中防腐剂的检测。
关闭还剩1页未读,是否继续阅读?
北京豫维科技有限公司为您提供《月饼中防腐剂检测方案(液相色谱柱)》,该方案主要用于糕点/月饼/粽子中食品添加剂检测,参考标准《GB/T 5009.140 饮料中乙酰磺胺酸钾的测定》,《月饼中防腐剂检测方案(液相色谱柱)》用到的仪器有null。
