当前位置: 其他 > 方案详情
生物假体瓣膜中三维流动结构检测方案(CCD相机)
检测样品 其他
检测项目 三维流动结构
关联设备 共2种 下载方案
方案详情
采用LaVision公司的两台八百万像素CCD相机,加让两块平面反射镜,构成一套等效四个视角的层析PIV测量系统并对在主动脉根的体外模型中经过生物假体瓣膜的三维流动结构进行了测量研究。
    The flow field past a prosthetic aortic valve comprises many details that indicate whether the prosthesis is functioning well or not. It is, however, not yet fully understood how an optimal flow scenario would look, i.e. which subtleties of the fluid dynamics in place are essential regarding the durability and compatibility of a prosthetic valve. In this study, we measured and analyzed the 3D flow field in the vicinity of a bio-prosthetic heart valve in function of the aortic root size. The measurements were conducted within aortic root phantoms of different size, mounted in a custom-built hydraulic setup, which mimicked physiological flow conditions in the aorta. Tomographic particle image velocimetry was used to measure the 3D instantaneous velocity field at various instances. Several 3D fields (e.g. instantaneous and mean velocity, 3D shear rate) were analyzed and compared focusing on the impact of the aortic root size, but also in order to gain general insight in the 3D flow structure past the bioprosthetic valve. We found that the diameter of the aortic jet relative to the diameter of the ascending aorta is the most important parameter in determining the characteristics of the flow. A large aortic cross-section, relative to the cross-section of the aortic jet, was associated with higher levels of turbulence intensity and higher retrograde flow in the ascending aorta.
关闭
  • 1/22
  • 2/22
还剩20页未读,是否继续阅读?
继续免费阅读全文
产品配置单
北京欧兰科技发展有限公司为您提供《生物假体瓣膜中三维流动结构检测方案(CCD相机)》,该方案主要用于其他中三维流动结构检测,参考标准《暂无》,《生物假体瓣膜中三维流动结构检测方案(CCD相机)》用到的仪器有体视层析粒子成像测速系统(Tomo-PIV)、LaVision DaVis 智能成像软件平台。
我要纠错
推荐专场
相关方案
