Atmos. Meas. Tech.,3,91-112,2010www.atmos-meas-tech.net/3/91/2010/ Author(s) 2010. This work is distributed underthe Creative Commons Attribution 3.0 License. K. von Bobrutzki et al.: Inter-comparison of NH3 measurement techniques92 AtmosphericMeasurementTechniques Field inter-comparison of eleven atmospheric ammoniameasurement techniques K. von Bobrutzki12, C. F. Braban, D. Famulari, S. K. Jones, T. Blackall’, T. E. L. Smith’, M. Blomt,H. Coe,M. Gallagher, M. Ghalaieny,M. R. McGillen, C. J. Percival, J. D. Whitehead, R. Ellis, J.Murphy, A. Mohacsi’,A. Pogany8, H. Junninen’, S. Rantanen’,M. A. Sutton, and E. Nemitzl Centre for Ecology and Hydrology (CEH) Edinburgh, Bush Estate, Penicuik, EH26 0QB, UK Leibniz-Institute for Agricultural Engineering, Potsdam, Germany 'Department of Geography, King’s College London, London, UK Energy Research Foundation of the Netherlands, Petten, The Netherland 5School of Earth, Atmospheric and Environmental Science, University of Manchester, Manchester, UK6 'Department of Chemistry, University of Toronto, Toronto, Canada Research Group on Laser Physics of the Hungarian Academy of Sciences, Budapest, Hungary Department of Optics and Quantum Electronics, University of Szeged, Szeged, Hungary 'Department of Physics, University of Helsinki, Helsinki, Finland Received:2 July 2009-Published in Atmos. Meas. Tech. Discuss.: 4 August 2009 Revised: 14 January 2010- Accepted: 15 January 2010 - Published: 27 January 2010 Abstract. Eleven instruments for the measurement of am-bient concentrations of atmospheric ammonia gas (NH3),based on eight different measurement methods were inter-compared above an intensively managed agricultural fieldin late summer 2008 in Southern Scotland. To test the in-struments over a wide range of concentrations, the field wasfertilised with urea midway through the experiment, lead-ing to an increase in the average concentration from 10 to100 ppbv.The instruments deployed included three wet-chemistry systems, one with offline analysis (annular rotat-ing batch denuder,RBD) and two with online-analysis (An-nular Denuder sampling with online Analysis, AMANDA;AiRRmonia), two Quantum Cascade Laser Absorption Spec-trometers (a large-cell dual system; DUAL-QCLAS, and acompact system; c-QCLAS), two photo-acoustic spectrome-ters (WaSul-Flux;Nitrolux-100), a Cavity Ring Down Spec-trosmeter (CRDS), a Chemical Ionisation Mass Spectrometer(CIMS), an ion mobility spectrometer (IMS) and an Open-Path Fourier Transform Infra-Red (OP-FTIR) Spectrometer.The instruments were compared with each other and with theaverage concentration of all instruments. An overall goodagreement of hourly average concentrations between the in-struments (R²>0.84), was observed for NH3 concentrationsat the field of up to 120 ppbv with the slopes against the Correspondence to: E. Nemitz(en@ceh.ac.uk) average ranging from 0.67 (DUAL-QCLAS) to 1.13 (AiR-Rmonia) with intercepts of -0.74 ppbv (RBD) to+2.69 ppbv(CIMS). More variability was found for performance forlower concentrations (<10ppbv). Here the main factors af-fecting measurement precision are (a) the inlet design, (b) thestate of inlet filters (where applicable), and (c) the qual-ity of gas-phase standards (where applicable). By referenceto the fast (1Hz) instruments deployed during the study, itwas possible to characterize the response times of the slowerinstruments. 1 Introduction Ammonia (NH3) plays an important role in atmosphericchemistry. It represents the major alkaline gas and is there-fore important for the neutralization of acidic gases and theformation of particulate matter (Duyzer et al., 1994; Asmanet al., 1998).. Deposition of atmospheric NH3 to ecosys-tem can lead to effects such as eutrophication and acidifi-cation of soils, contributing to forest decline and a decreasein biological diversity (Fangmeier et al., 1994; Sutton et al.,1995; Ferm, 1998). As a consequence, many measurementmethods for NH3 have been developed.Ambient measure-ment of NH3 concentrations is difficult due to several fac-tors: ambient levels vary widely, from 5 pptv in remote re-gions(Janson et al., 2001; Sutton et al., 2001)) to 500 ppbv near sources (Krupa, 2003). Ammonia occurs in gaseous,particulate and liquid phases which add further complexityto its measurement (Warneck, 1988), since the measurementtechnique should be specific to the gas-phase and not mod-ify the gas-aerosol equilibrium which depends on environ-mental conditions (Mozurkewich, 1993). In addition, NH3 is“sticky”and interacts with surfaces of materials, often lead-ing to slow inlet response times (Yokelson et al., 2003). Fi-nally, NH3 is emitted by people, increasing the potential forsample contamination (Sutton et al., 2000b). Currently, bulk denuder techniques are the most widelyused method for sampling NH3 and operate by stripping thegas phase NH3 from the air stream ((Ferm, 1979; Keuken etal.,1988).. The main disadvantages of this manual samplingmethod are the low temporal-resolution, and when high-frequency measurements (e.g. hourly) are needed, the man-power required becomes considerable. Moreover, the manualhandling, including sample preparation, wet-chemical analy-sis and sample storage, increase the chances of sample con-tamination. In the 1980s systems were developed, basedon wet effluent diffusion denuder (WEDD) techniques, tocollect stripping solution at regular intervals into test tubes(e.g. Keuken et al.,1988), this automated the process of sam-ple preparation and extraction, while still retaining the needfor manual off-line analysis. In a next step, in the 1990s theseWEDDs and mist chambers were coupled to NH onlineanalysers in the field (Simon et al., 1991; Simon and Das-gupta, 1993;Wyers et al., 1993; Blatter et al., 1994; Erismanet al., 2001). In parallel, spectroscopic techniques for NH3 were devel-oped, such as the use of chemiluminescence NOx monitorswith NH3 converters (e.g. Breitenbach and Shelef, 1973),Differential Optical Absorption Spectroscopy (DOAS; Gallet al., 1991), Tunable Diode Laser Absorption Spectroscopy(TDLAS; Grisar et al., 1987; Warland et al., 2001) andFourier Transform Infra-Red spectroscopy (FTIR; Galle etal., 2000). While many of these techniques have been de-ployed successfully to measure concentrations and emissionsdownwind of strong sources, it has only been over the past15 years that spectroscopic techniques have gradually be-come sufficiently sensitive and robust for field applicationat typical ambient concentrations (0.1 to 10ppbv). Ap-proaches more recently applied for NH3 measurements in-clude photoacoustic spectroscopy (e.g. Harren et al., 2000;Pushkarsky et al., 2002), Chemical Ionization Mass Spec-trometry(CIMS; e.g. Norman et al., 2007; Nowak etal., 2007), quantum cascade laser absorption spectrometers(QCLAS; e.g. McManus et al., 2002) and Ion Mobility Spec-trometry (IMS; e.g. Myles et al., 2006). Some experiments have been carried out to compare NH3measurement techniques.Wiebe et al.(1990) reported awieqtest of four methods: FTIR, filter-pack, denuders (sim-ple and annular) and a transition flow reactor.r.Williamset al. (1992) conducted an inter-comparison of five in-struments: a photofragmentation/laser-induced fluorescence (PF/LIF) instrument, a molybdenum oxide annular denudersampling/chemiluminescence detection (MOADS) system, atungsten oxide denuder sampling/chemiluminescence detec-tion (DARE) system, a method based on citric acid coateddenuder sampling coupled with ion chromatographic analy-sis (CAD/IC), and a method using an oxalic acid coated filterpack sampling coupled with colorimetric analysis (FP/COL).For selection within theeNNetherlands National Air QualityMonitoring Network (NAQMN)) six analysers were studiedby Mennen et al. (1996): a wet-annular rotating denuder, aWO3-coated thermodenuder, a V2O5-coated thermodenuder,a DOAS system, a photoacoustic monitor and a chemilu-minescence NOx monitor with NH3 converter. In addition,there were smaller inter-comparisons between two instru-ments: a field study on Tenerife by Milford et al. (2000)included an AMANDA instrument (see below) and a dif-fusion scrubber flow injection analyzer (DS-FIA). Fehsen-feld et al.(2002) reported a comparison of a CIMS with acitric acid denuder and a molybdenum oxide (MoOx) con-verter. Nowak et al. (2006) compared two different CIMSinstruments in the field: a NOAA chemical Science Divi-sion (NOAA-CSD) apparatus and the Georgia tech (GT) lowpressure reactor. The development of new continuous measurement ap-proaches has motivated two major inter-comparison cam-paigns in recent years: a laboratory inter-comparison ofgaseous NH with seven instruments were performed bySchwab et al. (2007): a TDLAS, a wet srubbing long-path ab-sorption spectrometer (LOPAP), a WEDD system, an IMS,a photo-acustic absorption analyzer, and a modified chemi-luminescence analyzer.r.TThe emphasis of this short inter-comparison was on the accuracy and time-response of theseapproaches under laboratory conditions while sampling froma common manifold. In addition, Norman et al. (2009) re-alised an inter-comparison of three instruments at a Swissgrassland site: a modified Proton Transfer reaction MassSpectrometer (PTR-MS; Norman et al., 2007) and two wetchemistry techniques, based on a horizontal denuder tech-nique (GRAEGOR; Thomas et al., 2009), and a diffusionmembrane sampler (AiRRmonia; Erisman et al., 2001). Fur-ther, Whitehead et al. (2008) made measurements between aQCLAS,a TDLAS and an AMANDA instrument. The work presented here included eight different atmo-spheric NH3 measurement methods implemented in elevendifferent instruments.,ffocussing on comparison of the tech-niques under typical field conditions. Ammonia was mea-sured over intensively managed grassland in Scotland, be-tween 20 August and 4 September 2008. The field was fer-tilised on 28 August 2008 to stimulate emission from the fieldand test the instrumentation over a wide concentration range,including regimes that are typical for moderately agriculturalmixed land use and also near-sources. The aim was to assessinstrument performance and characterise the instrument re-sponse times. In addition to the description of time-series,weused regression analyses for concentrations over the entire Fig. 1. Intensively managed grassland site (Easter Bush) with instruments, looking from the S field towards the N field. concentration range and, separately, below 10 ppbv to assessthe performance at low concentrations in more detail. Threeof the instruments were also used for micrometeorologicalflux measurements based either on the flux gradient tech-nique (AMANDA,WaSul-Flux) or eddy-covariance (DUAL-QCLAS), but these results will be presented elsewhere. 2 Methodology 2.1 Site description The measurements were made at a micrometeorological fieldsite in Southern Scotland (55°52N, 3°2W, 190 ma.s.l.) onan intensively managed grassland area (Easter Bush), locatedabout 1 km to the west of the Pentland Hills with peaks of upto 500 m (see Milford et al., 2001; Whitehead et al., 2008).The Easter Bush site is divided into two fields, each approx-imately 5 ha, more than 90% of which is covered by Loliumperenne (perennial ryegrass). The dividing line between thefields runs NW to SE, and in the following analysis the fieldsto the NE and SW of the measurement equipment are re-ferred to as N field and S field, respectively. The PentlandHills channel the wind so that on average 60% of the windcomes clearly from the S field and 19% clearly from the Nfield (Milford et al., 2001). Both fields receive the samemanagement and have been used for cattle and sheep graz-ing in recent years. Easter Bush is an intensive flux monitor-ing site ofthe NitroEurope IP measurement programme (Sut-ton et al., 2007) and has hosted several studies on NH3 fluxmeasurements (Milford et al., 2001; Whitehead et al.,2008).The inter-comparison experiment took place from 20 Augustto 4 September 2008 with the instruments placed along theboundary between the two fields (Fig. 1). All instrumentswere deployed with an inlet height of 1.1 m above ground,with the exception of the DUAL-QCLAS (1.95 m), as thiswas also used for eddy-covariance flux measurements. Fertilisation took place on 28 August 2008 on both the Nand S field, with 35 kg N ha- in the form of urea. 2.2 Environmental conditions during the fieldexperiment Figure 2 presents the time-series of hourly data of precipi-tation, temperature and relative humidity. The wind direc-tion and speed are represented by the direction and length ofthe arrows, respectively. The mean wind speed was around3ms-l. Several rain events occurred during the1 campaignwith the maximum amount being 4.9 mmh- on 20 Au-gust 2008.There was no rain during the fertilisation on28 August 2008 and therefore no NH3 was washed into theground immediately after fertilisation (see Sect.3.1). Therelative humidity never decreased below 58%.0.The meantemperature was 12.8°C. Overall, August 2008 was wet inEastern Scotland, receiving about twice as much rainfallcompared with the long-term average (mean since 1961; val-ues for Leuchars; Eden, 2008). This high level of precipita-tion led to the formation of a“pond”near to the measurementsite in the N field. Although the accumulating water waspumped away on several occasions, the associated rottingvegetation is likely to have created an additional and hetero-geneous NH3 source near the instruments, for NE wind direc-tions. The few occurrences of this wind direction were there-fore excluded from the regression analysis presented below. Figure 2 also includes a time-series of NH; aerosol inPM2.5 measured with a MARGA instrument, similar toGRAEGOR (Thomas et al., 2009), except that it deploys on-line cation analysis rather than FIA and a PM2.5 inlet cy-clone, at the Auchencorth EMEP site, 10km south of EasterBush. From previous simultaneous measurements, there isclose (±20%) agreement between NH; concentrations atAuchencorth and Easter Bush. This time-series is includedbecause it is possible that some of the NH3 measurementtechniques deployed here may show some cross-sensitivityto NH aerosol. Ammonium concentrations were below1 ug m-3 except for 30 and 31 August 2008. 2.3 Measurement techniques The characteristics of the NH3 measurement systems de-ployed in the inter-comparison are summarised in Table 1,and can be described as followed. Fig.2. Time-series of hourly data from selected meteorological variables during the campaign. The aerosol NHT concentration was measuredusing a MARGA monitor (see text) at the Auchencorth EMEP site, 10 km south of the Easter Bush field site. The wind panels show bothmagnitude and direction. 2.3.1 Wet-chemistry analysers Two of three wet chemistry instruments deployed (RBD,AMANDA) are based on the denuder principle described byFerm (1979), whereby/ gas phase NH3 is stripped from the airstream through diffusion to the denuder glass walls, withoutcollecting the NH; aerosol phase, since gas molecules dif-fuse quicker than particles to a moistened/acidified tube wall.In a third instrument (AiRRmonia), a diffusion membranewas used to strip the gas phase from the air stream. All threeinstruments were developed by the Energy Research Founda-tion of the Netherlands (ECN,Petten, NL). The instrumentswere housed in weather proof enclosures and placed at themeasurement height, with inlets of <0.1 m length. Annular rotating batch denuder (RBD) In the RBD instrument (Keuken et al., 1988), air is pumpedat 271min-through the annulus formed by two horizontalconcentric rotating glass tubes (with a diameter of 45 mm) and a 25 cm long HDPE (High Density Polyethylene) inlet(12 mm diameter). The glass tubes are wetted with a thinlayer of collecting liquid, which contains 2.0g1-NaOH,3.4ml1-1>98% formic acid and 0.5 mg1- thymol as bio-cide. Ammonia is absorbed into this thin layer of collec-tion solution over a sampling time of 40 min within eachhour, after which the sample (10 to 15ml) is pumped offto an autosampler holding 20 ml test tubes. All sampleswere analysed for NH offline on an NH3 Flow InjectionAnalyser (AMFIA, ECN, Petten, NL), based on analysisby selective ion membrane and conductivity measurement(Genfa and Dasgupta, 2000). For analysis, 0.5 M NaOHsolution is added to the sample, resulting in the conversionof NH; to gas-phase NH3gin solution. As the solutionthen passes a semi-permeable Teflon membrane,NHs per-meates the membrane and is dissolved in a counter streamof deionised water. Here NH is re-ionised to NH. and isdetected by conductivity (Sutton et al., 2000a; Erisman etal., 2001; Milford et al., 2001). This technique is precise Table 1. Summary of the characteristics of the instruments. based on manufacturer specification -based on the statistical standard deviations of the reported mixing ratios during calibration3based on the statistical standard deviations (twice) of hourly data, referenced against AiRRmonia inter-comparison datasetbased on the calibration during the experiment AMANDA and reasonably specific, but it has been shown to be some-what cross-sensitive to selected amines at high concentra-tions (Husted et al.,2000). In addition to NH it is possibleto use the RBD to capture other water soluble inorganic tracegases like HNO3,HCl, SO2 and H202 (Keuken et al.,1988),which would need to be quantified by a different analyticaltechnique such as anion chromatography. The technique of NH3 Measurement by ANnular Denudersampling with online Analysis (AMANDA) was developedby Wyers et al. (1993). The system used here consists ofthree annular wet rotating denuder inlets, similar to that usedin the RBD, located at different heights (0.39 m, 1.07m, and2.20 m). Unlike in the RBD, however, the stripping solu-tion (0.5g1- NaHSO4 containing 0.2 ml1-1 37% HCHo as a biocide) is continuously pumped from the denuders toa common detector block, where the three concentrationsare analysed sequentially by the same selective ion mem-brane/conductivity technique as deployed in the AMFIA. Inthe denuders a constant liquid level is maintained by the useof an independent peristaltic pump, controlled by a conduc-tivity measurement along the denuder. This particular instru-ment has been upgraded with a newer detection block, usingtwo conductivity measurements. One conductivity cell mon-itors the initial conductivity of the deionised water, while asecond conductivity cell monitors the NH content after themembrane exchange. The difference in both readings of theconductivity cells is a measure for the original NH3 contentin the sampled air. This approach takes into account changesin the water quality during longer service intervals. The in-strument reports one concentration gradient every 7.5 min,but the overall instrument response time is limited by theexchange of the stripping solution within the denuder (seeSect. 3.3 below). AiRRmonia The AiRRmonia is a further development of the AMANDAtechnique. As with the AMANDA, it was originally devel-oped by ECN (Energy Research Centre of the Netherlands,Petten, NL), but has been further improved and commer-cialised (Mechatronics Instruments b.v., Hoorn, NL) to pro-vide a sensitive, easy-to-use NH3 monitor (Erisman et al.,2001). Unlike the RBD and AMANDA, the instrument usesa Teflon membrane to strip the NH3 from the airflow into adeionised water flow. The detection system of NH3 is similarto that of the AMANDA, also using the double conductiv-ity measurement. Precision and stability of this instrumentare further improved through the use of syringe pumps forreagents and solutions, which undergo less variation due tochanges in pump tubing and temperature than the peristalticpumps used in the AMANDA. The AiRRmonia inlet con-sists of stainless steel with a length of 5 cm and a diameter of3.2 mm. 2.3.2 Quantum cascade laser absorption spectroscopy(QCLAS) QCLAS is an infrared absorption technique that makes useof the rich spectral absorption region in the mid-infrared, inwhich most species of interest in the atmosphere have re-solvable absorption features. Both laser systems used herewere produced by Aerodyne Research Inc. (Billerica, MA,USA), and operate with the light source of a thermoelec-trically cooled pulsed Quantum Cascade (QC) laser (AlpesLasers, Neuchatel, Switzerland). Their design was similarto the closed path configuration described by McManus etal. (2002). These lasers scan over a narrow range of wavenumbers chosen to contain an absorption feature of the tracegas of interest, which for NH3 is at a wavelength of 10.3 um. Both instruments use astigmatic Herriott multipass absorp-tion cells, to increase the effective path length, while pro-viding a fast spot measurement. They operate at cell pres-sures of around 40 Torr as a balance between minimising linebroadening, maximising time response and achieving goodsensitivity. In the data acquisition protocol chosen for this study, thespectra were recorded and averaged over the data acquisitiontime of one second, with the resulting spectra fitted to knownspectral line profiles from the HITRAN (HIgh-resolutionTRANsmission) molecular spectroscopic database (Roth-mann et al., 1998). In principle, this approach provides anabsolute measurement. DUAL-QCLAS The DUAL-QCLAS uses two separate thermoelectricallycooled pulsed Quantum Cascade (QC) lasers for the poten-tial measurement of two trace gases at different wave lengths.The two beams are brought together (with the pulses sep-arated in time) and directed into either one of two astig-matic Herriott multipass absorption cells where they undergo238 reflections, before leaving the cell and arriving at acryogenically cooled HgCdTe infrared detector. The large(51) cell provides an effective path length of 210 m, whilethe small (0.31) cell provides a path length of 56m. Thelarge cell is used for higher precision measurement applica-tions whilst the small cell (used here) provides the fast timeresponse required for eddy-covariance flux measurements.Data were recorded at a rate of 5 Hz to be averaged up inpost-processing for the purpose of the concentration inter-comparison reported here. Background measurements weremade typically every 15 min and background spectra weresubtracted from the measurements prior to the wave fit. Forthis purpose, NH3 free air was generated using a customizedPd/AL2O3 catalyst heated to 300°C, in an attempt to deter-mine the background at a relative humidity as close to am-bient as possible. The Pd/AL2O3 catalyst has been shownto have a negligible affect on the water concentration of thebackground air (Wert et al., 2002). The inlet was a 2mlength of 6.4 mm (OD) PFA tube,which was co-located withan ultrasonic anemometer (model HS; Gill Instruments Ltd.,Lymington, UK) for the purpose of flux measurements. Ageneral calibration factor of 1.23 was applied to the DUAL-QCLAS data based on the field based calibration. For moreinformation and studies of the DUAL-QCLAS see White-head et al. (2008). Compact QCLAS (c-QCLAS) The c-QCLAS uses a single QC laser and a single cell with avolume of 0.51 and an effective path length of 76 m. Air wasdrawn into the optical cell through a short (<0.1 m) quartzinlet that was heated to 40°C and coated with a hydrophobicsiloxyl coating. The inlet contains a critical orifice that drops the pressure in the optical cell to approximately 45 Torr whilekeeping a constant flow rate of approximately 91 min-. Fol-lowing the critical orifice, the flow is split into two brancheswith 90% of the flow making a sharp turn and being pulledthrough the optical cell. The other 10% is pulled directlyto the pump, relying on inertia to remove more than 50%of particles larger than 300 nm. This design was chosen tominimize surface interactions for gas phase NH3 while re-ducing possible positive artefacts in the measurements fromparticle volatilization. The quartz inlet was connected to theoptical cell via ~3 m and 9.5 mm PFA tubing. Backgroundmeasurements were performed every 30 min by flushing thequartz inlet using dry nitrogen. Standard addition calibra-tions were performed every two hours with a permeation tubestandard, added either into ambient air or dry nitrogen. Thepermeation rate was determined gravimetrically by the man-ufacturer (Kin-Tek) as 100 ng min-1 at 40°C. The rate wasconfirmed as 100±5 ng min- at 40°C by passing a flow ofpermeation tube standard through citric acid filters for 24h,followed by extraction with deionized water and analysis us-ing ion chromatography. 2.3.3 Photoacoustic spectroscopy Two instruments measured NH3 concentration using photoa-coustic spectroscopy. A light source is tuned to an absorp-tion feature of the target species and molecules are excitedto a higher quantum state. Modulating the light source re-sults in a periodic temperature change, giving rise to a peri-odic pressure change that equates to an acoustic signal if themodulation frequency is in the acoustic range. The intensityof the acoustic signal, which can be detected by a sensitivemicrophone, is proportional to the concentration of the light-absorbing species (Harren et al., 2000). Diode laser based photoacoustic system (WaSul-Flux) This new instrument combines near-infrared photoacousticspectroscopy with pre-concentration sampling as describedin more detail elsewhere (Pogany et al., 2008). The instru-ment is built into a 48.3 cm 6U temperature controlled in-strument box and has an additional waterproof housing. Thephotoacoustic detection unit consists ofa fibre-coupled DFBdiode laser light source (FOL15DCWD-A82-19560-A,Fu-rukawa Inc.) with ~40 mW output light power at 1532 nm,and an acoustically optimized photoacoustic cell with anelectret microphone (Knowles, EK 3029) for measuring thephotoacoustic signal. Ammonia is concentrated from thesampled air by a tungsten (VI) oxide coated preconcentra-tion unit. The instrument has three gas inlets and is there-fore suitable for measuring NH3 concentration at three dif-ferent heights above the ground. The sampling lines were6 m long Teflon tubes with 8mm inner diameter, heated to~50°C by self-regulating heating tape and included filterswhich were replaced weekly. The pre-concentration time can be adjusted to match the air concentrations. Here the integra-tion time was varied between 15 and 45 min according to theactual concentration. Before fertilization all three inlets wereplaced at the same height and the reported data are the aver-ages of the three measurements. After fertilization, the inletswere operated in gradient configuration and the reported datarepresent the measurement of the middle height. Nitrolux-100 The Nitrolux-100 (Pranalytica Inc., Santa Monica, CA,USA) is an ambient NH3 analyser that uses resonant pho-toacoustic spectroscopy and a line-tunable CO2 laser to pro-vide continuous or on-demand measurements (Pushkarsky etal., 2003). The excited NH molecules undergo collisionaldeactivation, which converts the absorbed energy into peri-odic local heating at the modulation frequency of the laser.The resulting acoustic waves are detected with minimal in-terferences by other compounds at typical concentrations ina non-polluted atmosphere (Cowen et al., 2004). The instru-ment was originally developed for clean room applications inthe semiconductor industry, but has been more widely usedfor ambient measurements. It is operated with an inlet filterto remove dust and NHt,with a manufacturer recommendedlifetime of three months, while the instrument should be cal-ibrated by the manufacturer every six months. The Nitrolux-100 was calibrated just before the beginning of the inter-comparison (8 August 2008).. The uncertainty associatedwith that calibration was a zero intercept of -0.006 ppbv, alinearity check with R²=0.999 and a system response time(under dry conditions) of 90% in 2 min. The Nitrolux-100was operated with a 4 m and 6.4 mm OD Teflon inlet whichwas insulated and heated to ~35°C. The inlet was shelteredby an inverted plastic funnel. 2.3.4 Cavity Ring Down Spectroscopy (CRDS) Cavity Ring Down Spectroscopy (CRDS) is a direct absorp-tion technique, which uses pulsed or continuous light sourcesand has a significant higher sensitivity than other conven-tional absorption spectroscopy (Berden et al., 2000).TheEnviroSense 1000 Analyzer (Picarro Inc., Sunnyvale, CA,USA) monitors NH3 in air using this approach.! Cavity RingDown Spectroscopy uses a pair of mirrors facing each other.A brief pulse of laser light is injected into the cavity, and itpasses back and forth between the mirrors, while a fractionleaks through the mirror. Ammonia absorbs some of the lightand thus the amount of light in the cavity decreases faster-itmakes fewer passes. A CRDS setup measures how long ittakes for the light to drop to a certain percentage of its orig-inal intensity, and thi1s1 S“rrNingdown time” is used to calculatethe concentration of the absorbing substance in the gas mix-ture in the cavity. Like the Nitrolux-100, the Picarro CRDSuses an inlet filter and is calibrated by the manufacturer sub-sequent (~2 months) to its most recent calibration.1. TThe CRDS was operated with a 4 m and 6.4 mm OD Teflon inletwhich was insulated and warmed with heating tape (~35°C).Again, the inlet was sheltered by an inverted plastic funnel.For detailed information see Rella (2008). 2.3.5 Chemical Ionisation Mass Spectrometry (CIMS) Chemical Ionisation Mass Spectrometry (CIMS) techniquesuse ion-molecule reactions to selectively ionize and detecttrace species of interest in ambient air with high sensitivityand fast time response. The CIMS method uses a reagention to ionise a neutral species, and the product ion resultingfrom this process is identified and quantified by a quadrupolemass analyser. The distinction between chemical ionizationmass spectrometry and other mass spectrometry techniquesis the use of ion molecule reactions for the selective ioniza-tion of compounds of interest in the complicated matrix ofambient air. In the system deployed here, NH3 was detectedusing H+(C3H6O)2 as a reagent ion (Nowak et al., 2007).The configuration of the CIMS deployed here is describedelsewhere (Slusher et al., 2004; Neuman et al., 2006; Kimet al., 2007; Nowak et al.,2007). The instrument sampledair though a 0.1 m long and 9.5 mm O.D. PFA inlet, tem-perature controlled to 40±1°C. Inlet flow was 19.51min-,with 0.881min- being subsampled through a 0.65 mm pin-hole into the ionization region, where reaction of NH3 withH+(C3H6O)2 proceeds.The instrumental signal was cali-brated every hour using a standard addition from a calibratedpermeation tube oven and an instrument background wastaken hourly. 2.3.6 Ion mobility spectrometer (IMS) Ion mobility spectrometers separate chemical substances onthe basis of velocity of gas-phase ions in an electrical field(Eiceman and Karpas, 1994). Ions are introduced into anelectrical field and the time of flight is measured. The sam-ple molecules are first ionized by B-radiation from a 63Nisource. The formation of positive ions is dominated by theproton-transfer reaction (Sunner et al., 1988) from waterclusters to substances that have proton affinity higher thanwater (697kJ mol-1), which includes NH3 (854kJ mol-).The charged ions are pulsed through a shutter grid into thedrift region, were they are separated by mobility and detectedat the end of the drift tube by an electrometer. The instrumentis not very specific and the NH3 measurement can suffer fromthe cross sensitivity of other compounds of similar mobility ifthey also have a proton affinity greater than water, while thequantification can be compromised by competing ion reac-tions. More details on the IMS technique are given in Hill etal.(1990) and Bacon et al. (1998). In this field study the com-mercial ion mobility spectrometer RAID I was used (BrukerDaltonik GmbH, Bremen, Germany). Sampling gas flow was0.41min- and the sampling line was 2 m non-heated Teflontubing.Heating was not applied to avoid contamination from the evaporation of NH; aerosols, although the response timeto the concentration peaks might be improved with a heatedsampling line. 2.3.7 Open-path Fourier Transform Infra-Red(OP-FTIR) spectroscopy Fourier Transform Infra-Red (FTIR) spectroscopy can beused to identify and quantify substances by their molecu-lar absorption of infra-red radiation at specific wavelengths.An open-path configuration permits the estimation of path-integrated average concentrations of a gas species of interestover path lengths of up to 1 km. OP-FTIR has been shownto be a useful tool for the measurement of NH3 from agricul-tural sources (e.g. Griffith and Galle, 2000). In the presentstudy, a MIDAC M4401 portable FTIR spectrometer withStirling cooled MCT detector module was used in conjunc-tion with a 50.8 cm infra-red (IR) source in a bi-static open-path configuration (path length of 102 to 105 m). Both theFTIR spectrometer and IR source were aligned at 1.3 to 1.4 mabove ground. The spectrometer was operated at a resolutionof 0.5 cm and eight sample scans were co-added for eachspectrum. Measured spectra were analysed for NH3 using the NHinfra-red absorption features at 968 cm-l and 932 cm- (ac-counting for interference by H2O and CO2 absorption). Con-centration retrievals were performed using the MALT soft-ware (Griffith, 1996). MALT iteratively computes syntheticspectra (convolved to the spectrometer line shape) from theHITRAN absorption line database (Rothman et al., 1998) un-til the mean-squared difference between the synthetic andmeasured spectra is minimised. The resultant concentra-tions used for the best-fit synthetic spectrum yield the path-integrated NH3 (as well as H2O and CO2) mixing ratios (inppbv) for the measured open-path. 2.4 Calibration and treatment of aerosol components The wet chemistry instruments were calibrated weekly withindividual liquid standards and a common liquid standardwas run on all analytical systems. The CIMS and c-QCLASwere calibrated regularly with their own gas-phase standards.As noted above, the Nitrolux-100 and CRDS were calibratedby manufacturers and operated within the specified calibra-tion intervals. The WaSul-Flux and IMS were calibrated bythe operating groups prior to the campaign by comparisonagainst wet-chemistry reference systems. An inter-comparison calibration (standard addition to am-bient air) from a common NH3 gas cylinder took place dur-ing the campaign. The cylinder was a standard of nomi-nally 21 ppmv NH3 in N2 (BOC, UK). During the exper-iment presented here the actual concentration was deter-mined as 20.2±1.4 ppmv by bubbling the gas through acidadsorption solution which was then analysed for NH; byflow injection analysis, following the procedure described by Table 2. Correlation of hourly NH3 concentrations less than 10 ppbv (z=1.1 m) between each instrument and the NH3-ens. Also shown arethe bias for the entire data range and the data <10 ppbv, as well as the gas and liquid standard biases for all instruments. Instrument Overall Gas Std. Liquid Std. <10 ppb regression bias [%] bias [%] bias [%] Slope Intercept R2 Bias [%] [ppbv] RBD 0.89 -0.33 0.85 -20.1 +5.65 +13.37 +2.62 AMANDA 1.02 -0.08 0.85 +0.62 -0.63 -24.71 +0.85 AiRRmonia 0.83 -0.02 0.90 -17.7 +10.9 -18.3 -2.96 CIMS 0.95 +1.93 0.65 +54.5 -12.9 -0.26 N/A c-QCLAS 0.72 +0.71 0.81 -12.8 -4.02 -23.2 N/A DUAL-QCLAS 0.86 -0.19 0.66 -20.6 -32.1 0* N/A WaSul-Flux 0.81 -0.15 0.85 -22.0 +1.27 — N/A Nitrolux-100 0.42 +3.42 0.52 +2.51 +1.69 N/A CRDS 0.50 +3.14 0.56 +26.0 +5.10 -12.48 N/A IMS 1.15 -0.61 0.87 -2.63 -2.90 N/A Thomas et al. (2009). The concentration range and numberof step increases varied between instruments. A similar cal-ibration scheme is described in Schwab et al. (2007). Foreach instrument a calibration bias from a NH3 gas cylinderand a corresponding measured NH3 concentration (gas std.bias) was calculated (see Table 2). This gas-phase measure-ment was used only as a check for most instruments, exceptfor the DUAL-QCLAS, for which it provided the primarycalibration, yielding a calibration factor of 1.23. As outlined in the instrument descriptions above, thewet chemistry systems strip the gas phase from the samplestream, while the aerosol phase passes through the samplingS tem. The c-QCLAS uses a virtual impactor to preventmost of the particles from entering the detection cell. TheNitrolux-100, CRDS and WaSul-Flux employ filters to pre-vent aerosol components from contaminating the detectioncell. This has the potential to lead to artifacts due to aerosoldynamics on the filter. Indeed, the Nitrolux-100 was initiallyoperated with a used filter and reported elevated NH3 con-centration levels compared with the other instruments (thedeviation correlating with temperature), suggesting that theNH3 originated from NH4NO3 volatilisation from the fil-ter. Following replacement of this filter, the Nitrolux-100measurements were found to agree with the other techniquessharing the same inlet line. The early data were thereforeexcluded from the data analysis. It appears that, for ambi-ent measurements, the filters provided by the manufacturerhave a much shorter lifetime than stated by the manufacturer.The stated lifetime is possibly more appropriate for the cleanroom applications for which the instrument had originallybeen developed. 3 Results 3.1 Time-series analysis Figure 3a and b show the time-series of measured NH3during the inter-comparison period of all instruments, mea-sured at different temporal resolutions (1 min to 1 h). Differ-ent vertical scales were used to present the time-series be-fore (Fig. 3a) and after (Fig. 3b) the fertilisation on 28 Au-gust 2008. The NH3 traces from the instruments at their indi-vidual time resolution (Table 1) are presented in two groupsfor increased clarity, separating wet chemistry analysers andspectroscopic techniques. In addition, the wind direction isindicated at the top of Fig. 3a and b. Before the fertilisation(Fig.3a), there were brief NH3 peaks in the time-series of theDUAL-QCLAS and CIMS of up to 18 ppbv. Except for theseindividual events, the NH3 level measured by all instrumentsranged up to 10 ppbv before the fertilisation event on 28 Au-gust 2008. After fertilisation (Fig. 3b),NH3 concentrationsincreased up to 120 ppbv, with such high concentrations con-tinuing until 29 August 2008 around 14:00. The early NH3peaks and some periods of disagreement coincided with peri-ods when the wind came from the rotting vegetation source inthe N field as indicated by the shaded areas in Fig. 3a and b. Overall, the absolute NH3 concentrations of all instru-ments revealed the same features and agreed closely witheach other.IBy contrast, the different time resolution ofthe instruments resulted in slightly different features of thetemporal NH3 structure. Of the wet chemistry instruments,the 1 minute data of the AiRRmonia analyser shows addi-tional NH3 variations during the fertilisation peak (29 Au-gust 2008), which the AMANDA and RBD failed to cap-ture because of their lower time resolution. Similar differ-ences can be seen in the comparison of the spectrometrictechniques. (a) Fig.3. Times series of NH3 for all instruments (z=1.1 m) with occurring wind direction for the data (a) before fertilisation and (b) afterfertilisation on 28 August 2008. The shaded areas indicate periods during which the wind came from the N field. RBD (red), AMANDA(blue), AiRRmonia (green), Nitrolux-100 (red), CRDS (brown), CIMS (purple),IMS (blue), WaSul-Flux (green), c-QCLAS (cyan), DUAL-QCLAS (orange), OP-FTIR (black). 3.2 Instrument inter-comparison For the regression analysis data from each instrument wasblock-averaged to hourly values in order to match the timeresolution of the slowest instrument (RBD). In addition, winddirections from the sectors 0° to 150° and 310° to 360°wereexcluded from the analysis, due to the heterogeneous sourcefrom the rotting vegetation in the N field. Figure 4a-j depict NH3 concentrations from each instru-ment compared with the ensemble average of made NH3 ob-servations (NH3-ens), together with the results of the linearregression analysis. The NH3-ens was computed as the aver-age over all instruments that were operational at a given time,excluding the OP-FTIR, for which too few data points wereavailable. Additionally, the horizontal error bars on NH3-ens (e) (h) Fig. 4. Scatter plots showing correlation of hourly NH3 concentrations (z=1.1 m) between all instruments and the NH3-ens screened forwind direction (150-310°). The horizontal error bars calculate the statistical standard error. For AiRRmonia, DUAL-QCLAS,c-QCLAS,Nitrolux-100, CRDS and CIMS the vertical error bars mark the estimated accuracy (Table1). The solid line gives the 1:1 line and the dashedline the result of the axis regression. show the statistical standard error (SE) of the different read-ings from the instruments that went into the calculation ofeach value of NH3-ens. Further, the estimated accuracy forthe AiRRmonia, DUAL-QCLAS, c-QCLAS, Nitrolux-100,CRDS and CIMS (Table 1)is shown as vertical error bars. Overall, a high correlation between all instruments is ob-served, with R>0.84. The DUAL-QCLAS, c-QCLAS,Nitrolux-100, CRDS and CIMS comparisons with NH3-enshave a slope <1 (Fig. 4d, e, g, h, i), with the DUAL-QCLASand the CIMS lowest at 0.67 and 0.80, respectively.. TheRBD, AiRRmonia, WaSul-Flux and IMS comparisons withthe NH3-ens have a slope >1, but have negative intercepts of-0.74 ppbv (RBD) to-0.32 ppbv (IMS) (Fig.4a,c, f, j). TheAMANDA instrument was closest to NH3-ens, with a slopeof 1 and an intercept of 0.20 ppbv (Fig. 4b). Relatively highintercepts were observed by the CIMS, CRDS and Nitrolux-100 compared with the other instruments.. IIt is thought thatthe CRDS and Nitrolux-100 intercept might be due to a lo-cal contamination source which was either on the samplingpost, sample tubing (both came from the same batch of tub-ing) or most likely the inlet filters.It should be noted thatfor the IMS, only data from before fertilisation and after thefertilisation plume had diminished could be used, becauseabove about 30 ppbv the IMS becomes strongly non-lineardue to the consumption of the parent ions and the formationof clusters, which shifts the mobility. The consequence wasa reduced dataset, biased towards smaller concentrations. Accurate measurement of NH3 at typical ambient back-ground levels is more challenging. For this reason, the linearregression for periods when NH3-ens <10 ppbv was calcu-lated separately (Table 2). The R against NH3-ens variedfrom 0.52 (Nitrolux-100) to 0.90 (AiRRmonia). The slope ofAMANDA and IMS against NH3-ens were >1 and all otherswere <1, e.g. 0.42 (Nitrolux-100) to 0.95 (CIMS) with inter-cepts from -0.61 to 3.42 ppbv. The highest intercept valueswere measured for CIMS, CRDS and Nitrolux-100 and againfor the latter two inlet/filter contamination are thought to bethe cause. The bias (%) between two instruments is defined accord-ing to Eq. 1, where m is the slope of the regression analysiswhen forced through zero. The biases reported in Table 2 represent the percentage dif-ference of the full range NH3 concentration (overall bias)and the bias derived from concentrations <10 ppbv (10 ppbvbias). The overall bias for all instruments were reasonablysmall, ranging from -12.9% (CIMS) to 10.9% (AiRRmo-nia) except for the DUAL-QCLAS, whereas the 10 ppbv bi-ases showed more variability. Also included in Table 2 isthe bias of a reading based on a calibration through standardaddition from an NH3 calibration cylinder. It turned out notto be easy to provide a common, reliable and portable gas-phase calibration standard suitable for the large range of flowrates of the different instruments. Because these are based on Table 3. Summary of linear regression results of the OP-FTIRagainst c-QCLAS, DUAL-QCLAS and CIMS at 2 min time reso-lution from the data shown in Fig. 5. Slope Intercept (ppbv) R2 c-QCLAS 0.54 4.39 0.97 DUAL-QCLAS 0.82 3.74 0.92 CIMS 0.43 5.37 0.63 standard additions to ambient air, they only reflect the erroron the response (slope) and do not include the intercept. Cal-ibration results were more variable than the slopes derivedfrom the regression analysis and should therefore be treatedwith caution. For the wet-chemistry analysers a liquid intercalibrationwas performed using common 50, 100 and 500 ppbv aque-ous standard on the three analytical systems and the outcomeis again the regression with the measured percentage differ-ence. For the three wet-chemistry instruments the used liquidstandards showed excellent agreement concerning the liquidstandard bias (Table 2). The OP-FTIR was operated manually in the field and thedataset is much reduced compared with the other instruments(9h). Thus, it is not included in the hourly data analysis. In-stead, Fig. 5 compares the OP-FTIR data at 2 min time reso-lution against the other fast response instruments (c-QCLAS,DUAL-QCLAS and CIMS). The data of the OP-FTIR agreed best with the DUAL-QCLAS (Fig. 5) with a slope of 0.82 (Table 3), which wasreading lower compared to the other instruments (Fig. 4d)with the c-QCLAS providing the best match with the refer-ence here. Further, the regression analysis revealed for theOP-FTIR a high intercept of >3.74 ppbv compared with allother instruments. While for graphical representation the analysis of an in-dividual instrument against a common NH3-ens provides adigestible overview over the results, the full information ofthe inter-comparison is only revealed through correlation be-tween each of the eleven instruments with each other.Ta-bles 4 and 5 show the results of the regression analysis ofall hourly data, while Tables 6 and 7 show the results of theregression confined to data points where both instruments re-ported concentrations of less than 10 ppbv. Each of the fourtables contains two separate diagonal parts with informationfor the instruments. For the top half of the table (grey) theregression provided is the vertical axis (row) against the hor-izontal axis (column). Concerning the bottom half it switchesto horizontal axis (column) against vertical axis (row). For example, the regression analysis of the RBD againstthe AMANDA for the entire data range is: RBD=0.86*AMANDA+1.41ppbv, Fig. 5. Scatter plots ofOP-FTIR against c-QCLAS,DUAL-QCLASand CIMS at 2 min time resolution, including regression lines andthe 1:1 line (grey). while the results of the regression analysis of the AMANDAVS.RBD are not included. Although derived from the re-gression fit of y=ax, the bias does not always fully rep-resent a clear picture of the combined effects of the aver-age discrepancy between two instruments specify by slopeand intercept. For example, due to a lack of data and highintercept values for some instruments, the datasets in thesescatter plots showed a distributed appearance and the linearregression line was difficult to draw (Table 8). Thus all fourparameters need to be considered when interpreting the per-formance of two instruments against each other. For the overall data range the slopes of the AMANDA,AiRRmonia, c-QCLAS, WaSul-Flux, Nitrolux-100 andCRDS varied by ±20% with each other (Table 4). For thedata limited to <10 ppbv the slopes between RBD, AiRRmo-nia, WaSul-Flux and IMS were all within ±20% of unity(Table 6). High intercepts were found for correlations ofCIMS, Nitrolux-100 and CRDS with all other instruments(Bold numbers in Tables 4 and 6), with values from 1.60 to6.14 ppbv for the full data range and from 1.22 to 3.92 ppbvfor data <10 ppbv. For the full data range, R² values <0.90were limited for inter-comparisons involving RBD, CIMS orIMS (Table 5). For <10ppbv, an R²>0.80 was achievedfor any comparison between AMANDA, AiRRmonia and c-QCLAS (Table 7). The DUAL-QCLAS (italic numbers inTables 5 and 7) was biased towards lower values, comparedwith all other instruments. Table 8 contains two separate diagonal parts with informa-tion and presents a visual support to the results from Tables 4to 7. The results provided are for the regression of the instru-ment on the vertical axis (row) against the instrument on thehorizontal axis (column) for the entire data range (white). Fig. 6. Comparison of the time-series of the AMANDA (red/dotted)and the c-QCLAS (green) for a 24 h period on 29 to 30 August 2008.The c-QCLAS smoothed concentration c'(t) (blue/dashed) was cal-culated with f=0.08, selected by eye as a fit to the AMANDA data. The grey diagonal part shows the plots for NH3 concentra-tion <10 ppbv and it is to read from the instruments in thehorizontal axis (row) against instruments in the vertical axis(column). For more visibility and detailed information seethe supplemental material (http://www.atmos-meas-tech.net/3/91/2010/amt-3-91-2010-supplement.pdf). 3.3 Characterisation of the instrument time responsesof the slow response instruments For analysing the time response of the different instrumentsetups (including inlets) a short time-series of each instru-ment was compared against data of a well-performing fast-response instrument, for which the 1 min data from the c-QCLAS was chosen. A running mean was calculated fromthe c-QCLAS data as: where c'(t) is the smoothed concentration, c(t) is the mea-sured concentration and f is a smoothing factor defined be-low, which would be unity for an instrument that is equallyas fast as the c-QCLAS. Equation (2) simulates the responseof a concentration measurement which is subject to a mem-ory effect, which may be either due to the turnover time inan air volume, liquid pool or due to adsorption/desorptionin inlet lines. For each instrument f was determined by fit-ting the smoothed c-QCLAS time-series to the data reportedby the instrument. This approach is demonstrated in Fig. 6,where f is adjusted for the smoothed c-QCLAS time-seriesto match the data from the AMANDA. The e-folding time of the instrument was determined ast1/e=1/f min, which is reported in Table 9 together withthe 50 and 95% response times (t50,t95). The correspondingdeviation is also stated. The AMANDA reports 7.5 min data, but it appeared totake 32.2±3.7 min for a 95% response.The replacementof the liquid pool in the denuder appears to limit this timeresponse of the instrument. A similar observation was made Table 4. Inter-comparison of linear correlations between each instrument for the entire data range. Slopes are given in the bottom half andintercepts are indicated by the top (grey) of the matrix. Bold numbers indicate noticeable non-zero intercepts (>1.5ppbv). Intercept [ppbv] o Z o RBD 1.41 0.70 3.65 1.17 1.09 0.55 6.14 3.63 0.10 AMANDA 0.86 一- -1.08 3.51 -0.62 0.34 -0.86 1.82 2.27 0.04 AiRRmonia 0.97 1.12 3.92 0.34 0.57 0.16 2.65 2.93 0.02 CIMS 0.74 0.76 0.65 -2.46 -0.38 -1.07 4.12 1.60 0.78 c-QCLAS 0.86 0.96 0.83 1.09 0.64 0.47 5.73 3.25 0.10 DUAL-QCLAS 0.54 0.69 0.59 0.64 0.65 -1.13 2.46 1.81 0.40 WaSul-Flux 0.90 1.02 0.90 1.06 1.00 1.55 3.09 3.02 0.19 Nitrolux-100 0.77 0.96 0.85 0.97 0.90 1.53 0.92 -0.03 -2.22 CRDS 0.81 0.93 0.83 1.09 1.04 1.60 0.92 1.00 -1.13 IMS 1.12 0.88 1.11 0.30 0.93 0.69 1.11 0.95 0.65 Table 5. Inter-comparison of correlation coefficients and biases between each instrument for the entire data range. Biases are given in thebottom half and correlation coefficients are indicated by the top (grey) of the matrix. Bold numbers indicate high biases (>20%), mainly ofthe Dual-QCLAS. R2 RBD 0.93 0.93 0.82 0.87 0.95 0.95 0.84 0.86 0.80 AMANDA -11.1 0.99 0.76 0.92 0.97 0.98 0.98 0.98 0.90 AiRRmonia -1.77 9.41 0.74 0.91 0.98 0.98 0.96 0.97 0.82 CIMS -18.8 -15.6 -26.8 0.89 0.94 0.79 0.75 0.71 0.58 c-QCLAS -11.7 -5.91 -15.8 1.96 0.97 0.93 0.93 0.93 0.70 DUAL-QCLAS -43.4 -29.8 -38.9 -37.7 -33.0 0.98 0.97 0.91 0.66 WaSul-Flux -8.85 -0.3 -9.50 3.19 1.80 48.3 0.95 0.95 0.82 Nitrolux-100 -12.4 0.33 -9.83 8.00 2.62 65.0 -1.40 0.99 0.57 CRDS -10.7 -0.2 -10.6 14.7 13.8 86.4 -0.12 0.37 0.20 IMS 14.3 -10.9 10.9 -60.8 -5.58 -19.9 15.2 -51.1 -60.5 for the RBD. The AiRRmonia seemed to have the least timedelays in the system: t95 of 14.4±4.0 min closely matchedthe internal measurement cycle of 10 min. The IMS derived with t95=34.9±6.4 min the highest de-lay with reported data of 3 s, but the limited amount of dataqualified this statement. The CIMS and DUAL-QCLAS havesimilar time responses as the c-QCLAS and this approach istherefore not suitable to characterise them further. They aretherefore not listed in Table 9. 4 Discussion 4.1 Overall measurement agreement The instruments tested in the present study revealed goodcorrelation with R2>0.84 for one hour averages comparedwith NH3-ens. It should be pointed out, that the regres-sions show relative performance of the instruments againstNH3-ens (Fig. 4a-j) or against each other (Tables 4, 6,8). They do not demonstrate a functional relationship of adependent to an independent variable. Thus, a consideration Table 6. Inter-comparison of linear correlations between each instrument of data less than 10 ppbv. Slopes are given in the bottom half andintercepts are indicated by the top (grey) of the matrix. Bold numbers indicate noticeable non-zero intercepts (>1.5ppbv). Z o Intercept [ppbv] RBD 0.37 0.48 3.08 1.22 0.48 0.28 3.92 3.82 0.02 AMANDA 1.15 0.20 2.95 1.02 0.34 -0.06 3.75 3.42 -0.09 AiRRmonia 0.85 0.73 2.64 0.84 0.05 0.01 3.26 3.58 -0.14 CIMS 0.71 0.68 0.89 一 -0.62 0.28 -0.81 2.51 1.22 -0.88 c-QCLAS 0.79 0.64 0.86 0.81 0.16 -0.68 3.47 3.46 -0.64 DUAL-QCLAS 0.86 0.70 1.03 0.35 0.78 0.09 3.90 3.91 0.30 WaSul-Flux 0.85 0.77 0.94 0.56 1.03 0.79 3.47 3.75 0.10 Nitrolux-100 0.40 0.40 0.51 0.52 0.53 0.43 0.52 -0.05 -2.22 CRDS 0.25 0.46 0.44 0.69 0.46 0.24 0.58 1.02 -1.13 IMS 1.14 0.93 1.17 0.68 1.15 0.75 1.13 0.95 0.65 Table 7. Inter-comparison of correlation coefficients and biases between each instrument of data less than 10 ppbv. Biases are given in thebottom half and correlation coefficients are indicated by the top (grey) of the matrix. Bold numbers indicate high biases (>20%). RBD — 0.81 0.79 0.37 0.72 0.51 0.77 0.21 0.09 0.79 AMANDA 26.8 0.91 0.40 0.81 0.52 0.90 0.45 0.46 0.83 AiRRmonia -0.46 -22.7 0.55 0.91 0.62 0.85 0.79 0.43 0.73 CIMS 105 66.7 91.6 0.43 0.20 0.54 0.44 0.55 0.40 c-QCLAS 12.6 -14.9 6.66 -31.6 0.63 0.82 0.33 0.27 0.66 DUAL-QCLAS 10.5 -16.8 5.40 -58.5 -16.2 0.62 0.06 0.11 0.46 WaSul-Flux -6.87 -23.7 -5.45 -59.9 -12.3 -17.5 0.62 0.50 0.78 Nitrolux-100 101 12.3 16.6 -1.96 35.7 146 41.8 0.72 0.57 CRDS 107 32.8 46.0 -6.32 45.5 96.3 68.4 1.21 0.20 IMS 14.8 -49.45 12.5 -50.7 -2.33 -12.2 16.0 -51.1 -60.5 一 of an a priori uncertainty would not be appropriate for thisanalysis. Nevertheless, a possible approach of performingregression analysis by using a least-squares fitting with un-certainties of the data can be found in Cantrell (2008). The CIMS, CRDS and Nitrolux-100 revealed elevated in-tercepts compared with the other instruments pointing ata possible contamination of the inlet filters (CRDS andNitrolux-100), inlets or both.The detected results dur-ing this campaign are in line with the studies listed below.Measurements of RBD, AMANDA, AiRRmonia, WaSul-Flux and c-QCLAS were within ±25% for NH3 concentra-tions of 10 to 120 ppbv. It should be noted that, although an attempt was madeto eliminate the effect of spatial heterogeneity, emissionsfrom grazed and fertilised grassland are expected to showsome variability. It was neither possible (though desirable)for all instrument to sample from a common point (e.g. thewet chemistry instruments do not use an inlet tube, whilethe OP-FTIR provides a line average), nor was the use ofa common inlet in the spirit of this experiment, in whichwe wanted to test independent systems with the respec-tive inlets as they would have been operated by the dif-ferent groups in the field.There is some indication thatat times, instruments that were located more closely to Table 8. Linear regression between each instrument for the entire data range (bottom left) and less than 10 ppbv (shaded top right). Z o o o RBD AMANDA - AiRRmonia - CIMS 6 c-QCLAS - DUAL-QCLAS - WaSul-Flux - Nitrolux-100 .. - CRDS .. IMS 一 each other (e.g. WaSul-Flux/AMANDA/RBD/AiRRmoniaand CIMS/DUAL-QCLAS/c-QCLAS/Nitrolux-100/CRDS)agreed more closely with each other, but this observation wasnot consistent. Previous comparison campaigns have already illustratedthe challenges involved in measuring ambient NH3 concen-trations accurately, especially at low concentrations. The re-sults in the study of Wiebe et al. (1990) showed an agree-ment within ±30% for NH3 concentration >1.5 ppbv withtime resolution of minimum four hours for the filter packsand the annular denuders. The five instruments compared by William et al. (1992) yielded an agreement of within afactor of two for NH3 concentration >0.5 ppbv. In detailthe CAD/IC and PF/LIF agreed within 15% for NH3 con-centration of 0.2 to 5.0 ppbv for a time resolution of 2 to8h. The framework of the NAQMN study by Mennen etal. (1996) determined a general applicability for all require-ments for air quality monitoring on one hour sampling. Fur-ther, the DOAS and the NOx converter instruments reachedR²>0.9 compared with the wet-annular rotating denuder,but both were only useful during high NH3 concentrationnear stacks or stables. In the study by Mennen et al. (1996) Table 9. Analysis ofthe response time of AMANDA,RBD, WaSul-Flux, AiRRmonia, Nitrolux-100, CRDS and IMS in comparison toc-QCLAS with corresponding statistical parameters. t1/e t50 t95 (min) (min) (min) AMANDA 10.7±1.3 7.4±0.9 32.2±3.7 RBD 28.7一4.2 19.9±2.9 85.9±12.5 WaSul-Flux 19.1±5.4 13.3±3.7 57.3一16.1 AiRRmonia 4.8±1.4 3.4±0.9 14.4±4.0 Nitrolux-100 3.6±0.8 2.5±0.6 10.9±2.5 CRDS 4.5±1.7 3.1±1.2 13.4±5.0 IMS 11.6±2.1 8.1±1.5 34.9±6.4 the photoaccoustic monitor was eliminated due to high main-tenance demands and because of leaving only 1% useful data.During the campaign of Milford et al. (2000) AMANDA andDS-FIA showed an overall difference of 35% for a samplingtime of 30 min, but with substantial scatter. Fehsenfeld etal. (2002) reported for CIMS and MoOx converter methodR²>0.9 compared with the citric acid denuder (samplingtime minimum two hours). The average concentration differ-ence compared with the denuder was 0.8 for the CIMS and1.75 for the MoOx converter method. Two CIMS instrumentstested during the field study in Nowak et al. (2006) mea-sured R²=0.71 and concentration difference of 17% (timeresolution one minute) with NH3 concentrations from 0.4to 0.13 ppbv. Milford et al. (2009) compared measurementswith three AMANDA systems and a mini-WEDD system.The NH3 measurements showed good agreement betweenthe instruments (<20% difference) for some periods, butwith poorer agreement on some individual days, due to vari-able performance of the automatic wet chemistry detectionsystems. Of particular interest here are the results of the recent lab-oratory inter-comparison study of Schwab et al. (2007), be-cause it followed a complementary approach (being labora-tory based), while including some of the same instrumentmodels tested here. The seven instruments tested during thelaboratory comparison agreed within 25% of the expectedcalibration value. The IMS and Nitrolux-100 yielded biasesof ±25% with slower time response than the TDLAS (sim-ilar to the QCLAS used here). Further, the wet chemical in-struments LOPAP and WEDD worked well in the calibrationtests in view of absolute accuracy of measured concentra-tions, but a disadvantage was the slower time response of theWEDD. In the recent field inter-comparison of Norman etal. (2009) the slopes of hourly uncorrected data of PTR-MS (an alternative CIMS technique using a different ioni-sation scheme), GRAEGOR (based on the same collectionand analytical technique as the AMANDA, but with lower flow rates) and AiRRmonia ranged between 0.78 to 0.97 forNH3 concentrations from 2 to 25 ppbv. During atmosphericconditions favouring condensation in inlet lines, the PTR-MS underestimated NH3 concentrations. The authors pointout the need to put more emphasis on the inlet designs forfuture campaigns. Whitehead et al. (2008) reported thattheir concentration measurements from the QCLAS and theAMANDA instrument correlated well, with R2=0.84. How-ever, the QCLAS underestimated fluxes by 64% comparedwith the AMANDA instrument. 4.2 Instrument specific issues While providing a good response to the concentrations, theNitrolux-100 and CRDS measurements in the present studywere subject to a similar high intercept compared with theother instruments.TThere were two aspects common to theseinstruments: they shared the same sampling line, which mayhave been contaminated, but they also both use inlet filters,exchangedinfrequently(up to 3 months, according to man-ufacturers), which may collect NH4NO3 which then coulddissociate at low concentrations, providing a (temperaturedependent) offset. This process clearly affected the Nitrolux-100 data at the start of the experiment, taken with an old fil-ter, which were discarded from the analysis. This inlet / filterissue may also have affected the regressions of these instru-ments, especially over the low concentration range, as theintercept may not be stable in time. Apart from this issue,both instruments are convenient to operate as they are bothmanufacturer calibrated with long service intervals. The only other instrument using an inlet filter is theWaSul-Flux, which operates on a similar principle as theNitrolux-100. However, its filter was changed weekly, min-imising the effect of NH4NO3 volatilisation. An attempt wasmade to investigate the potential of NH4NO3 interferenceon those instruments that do not remove the aerosol phase.In the c-QCLAS inlet a virtual impactor removes the coarseaerosol fraction. The CIMS does not use a filter and the res-idence within the heated inlet is 0.1 s and thus, the interfer-ence from NH4NO3 volatilisation is expected to be negligi-ble, as noted by Fehsenfeld et al. (2002). Indeed, laboratorytests have shown that NH4NO3 volatilisation only becomesan issue for T>325K. Filters were not used on the IMS andthe DUAL-QCLAS systems either, but the residence time inthe analysis cell of the DUAL-QCLAS is of the order of 0.2 sand laboratory tests have found NH4NO3 interference to benegligible. In the wet chemistry systems aerosols are thoughtto pass the inlet uncollected. Unfortunately, the regionalNH concentration was fairly constant during the campaign(Fig. 2), except for a period which coincided with the fer-tiliser emission peak of NH3, during which NH still madea minor contribution to total NHx. As a consequence, the ef-fect of inlet heating (to 50°C) on NH4NO3 volatilisation inthe WaSul-Flux inlet could not be investigated. The WaSul-Flux performed well against the other instru-ments, but has a relatively slow time response (45 min) at thebackground concentrations. It can achieve a detection limitof 0.25 ppbv at 45 min time resolution (Table 1), which maystill not be sufficient for all applications. Work is underwayto improve the sensitivity further. By contrast, the IMS is highly sensitive, but less specificand affected by competing ion chemistries, which makes itapplicable only to situations of low NHs and where no in-terfering compounds are to be expected. Its comparativelypoor performance over the entire concentration range is mis-leading as concentrations >20 ppbv had to be removed dueto saturation. It shows one of the best correlations with theaverage at the sub-10 ppbv comparison (R2=0.87, Table 2). Threee instruments deployed. jhere (DUAL-QCLAS,c-QCLAS and CIMS) have the potential to provide a fastNH3 spot measurement, of particular interest for aircraftapplications and eddy-covariance flux measurements. Al-though their time response was not characterised here, theyclearly provide faster response than the other instrumentsand previous characterisations has shown response times tobe better than 1 s, depending on inlet design (e.g. Whiteheadet al., 2008). The QCLAS technique (like OP-FTIR) in principle pro-vides an absolute measurement of the concentration. How-ever, without calibration, the instruments turned out to sig-nificantly underestimate the concentration. The c-QCLASwas calibrated at regular intervals in the field with a perme-ation tube calibration source, while a regular zero calibrationbut a one-off span calibration were applied to the DUAL-QCLAS, with average span calibration factors in the regionof 1.3 and 1.2, for the two instruments respectively. This dif-ference in the calibration approach is likely to be responsiblefor the poorer performance of the DUAL-QCLAS during thiscampaign. In addition, the DUAL-QCLAS was set up foreddy-covariance flux measurements, with a relatively longinlet, which may have added further uncertainty. The DUAL-QCLAS sampled air through a 2 m length of 6.4 mm PFAtubing. Owing to the “sticky”nature of NH3, this can havean impact on NH3 measurements (Shaw et al., 1998; White-head et al., 2008). This may therefore partly explain theunder-estimate in the NH3 concentration at the peak concen-trations. Against this possible argument, it should be notedthat the DUAL-QCLAS showed one of the highest R2 values(0.98 for the full dataset), with a small intercept comparedwith other instruments (Fig. 4d and Table 6), indicating asignificant but rather constant slope of~1.2. By contrast, thec-QCLAS was one the better performing instruments testedhere. The CIMS provides a fast, highly sensitive technique andthis was the first field deployment of this particular instru-ment, which showed more scatter than most instruments. Al-though, it should be noted that it is uncertain how muchof this scatter is natural variability and how much is repre-sented by instrumental noise. The instrument was calibrated hourly and the sensitivity of the instrument was (2.5±0.5)Hzppt-1o and the 1o background noise corresponded to45 pptv.IIn a subsequent deployment of this instrument(C. J. Percival, personal communication, 2009), which em-ployed a similar inlet design and throughput, large variabil-ity in NH3 signal was observed on a second by second basis,such variability was not present in the background and cal-ibration cycles, indicating that the inlet is able to respondto rapid changes in the NH3 concentration associated withdifferent plumes and is therefore capturing real, rather thanartificial variability. It appears that, as with the c-QCLASapproach, stability in the instrument response coupled withthe need for a reliable zero and span gas-phase calibrationsource is the limiting factor in improving performance. Thisis consistent with the observations of Nowak et al. (2007),who reported the need for very frequent background deter-minations for an airborne CIMS instrument, especially whentargeting background concentrations. The OP-FTIR instrument averages over a path-length of100 m which possibly limits comparability with the otherpoint measurement techniques. Furthermore, measurementswere made over a more limited concentration range. Yet,the comparison with the other fast-response techniques is en-couraging (Fig. 5). Like the c-QCLAS, the OP-FTIR shouldalso provide an absolute measurement but reports some ofthe lowest concentrations. At very low concentrations, in-strument noise may exceed the signal from NH3, which mayexplain the high intercept (>3.74 ppbv) in comparison withother detection methods. Interestingly, both c-QCLAS andOP-FTIR underestimate the concentration when used in ab-solute (uncalibrated) mode and both rely on the accuracyof the same absorption line information of the HITRANdatabase. All three wet chemistry systems used here are basedon flow injection analysis using a selective ion membrane,which is known to have some cross sensitivity for someamines (Husted et al., 2000). Although probably unimpor-tant here, they may make a more significant contribution inother situations, e.g. of organic animal manure emissions.Using batch sampling and off-line analysis, the RBD is themost “manual"technique included here. It is surprising thatthe RBD performed better (compared with the average) atsmall concentrations than over the entire concentration range(Table 2). This is possibly due to sample carry-over in situa-tions of highly variable concentrations. AMANDA and AiR-Rmonia compared well with each other and, together withWaSul-Flux and IMS (and closely followed by c-QCLAS),achieved the best agreement with each other over the lowconcentration range.AMANDA and IMS read somewhathigher than the other instruments. The excellent agreementon the common liquid standard within ±3% (Table 2) indi-cates that the wet chemistry instruments are stable and easyto calibrate, as long as the collection efficiency can be as-sumed to be 100% and the flow rates are well established.The wet chemistry instruments have the implicit advantage that they do not rely on an accurate gas-phase standard orany absorption cross sections. Further, they provide a morerobust approach to separating gas and aerosol phase. How-ever, they could potentially suffer artefacts from interferinggas-phase compounds in certain situations. The WaSul-Flux instrument was compared against anAMANDA in previous measurement campaigns (Pogány etal., 2009), where a correlation coefficient of 0.98 was foundbetween the photoacoustic signal and the concentration read-ings of AMANDA for concentrations 0 to 120 ppbv, whichagrees with the correlation coefficients for NH3-ens in thiscampaign (0.98, Fig.4f), and the correlation coefficients be-tween WaSul-Flux and the wet-chemistry instruments (0.98for AMANDA and AiRRmonia and 0.95 for the RBD; Ta-ble 5). However, the limit of detection of the WaSul-Fluxinstrument (0.25 ppbv) is currently higher than that stated forthe AMANDA (0.02 ppbv) or AiRRmonia (0.04ppbv). 4.3 Time responses The additional capture of NH3 variations of instruments withhigher time resolution, shown in Sect. 3.1, is consistent withthe observations of Norman et al. (2009). The calculated timeresponse for the instruments in Sect. 3.3 showed higher val-ues than stated by the manufacturers (Table 1). This is par-ticularly true for the AMANDA system for which the actualresponse time was estimated to be 37 min. A similar obser-vation was made for the GRAEGOR analyser, based on thesame horizontal annular denuder design, but using a lowerliquid flow rate (Thomas et al., 2009). Faster response couldbe achieved by further minimising the liquid pool in the de-nuders, or by increasing the liquid flow rate (thereby sacri-ficing sensitivity). For the AiRRmonia, the calculated timeresponse of 14.4土4.0 min time to obtain 95% of the signal isonly slightly slower than the 10 min measurement cycle (Ta-ble 1). The same is true for CRDS and Nitrolux-100 with13.4土5.0 min and 10.9±2.5 min to obtain 95% of the signal,respectively, as compared with instrument recording every6s (Table 1). During the study of Schwab et al. (2007), aTDLAS reached a value near 35 ppbv within 6 min, whereasIMS and Nitrolux-100 had the slowest time response of allthe instruments investigated in their experiment. The sameobservations were made during this inter-comparison, wherethe IMS presented the slowest time response, probably dueto the use of internal materials which are not optimised forNH3 measurements. 5 Conclusions This paper reports an inter-comparison of eleven instrumentsfor measuring atmospheric NH3 at ambient concentrations,representing the largest NH3 inter-comparison under typicalfield conditions to date. The approaches deployed includedautomated wet chemistry techniques, optical, photo-acoustic and mass spectrometric techniques. There were differencesin the concentrations reported, but overall the high correla-tion with R²>0.84 compared with the average of all instru-ments used, is very encouraging. The correlation worsensif only concentrations <10 ppbv are considered. Concentra-tions of RBD, AMANDA,AiRRmonia, WaSul-Flux and c-QCLAS agreed within ±25% for concentrations >10 ppbv.Some reasons for variability were identified:inlet lengthgreatly affects measurement precision and time-response.Where used, inlet filters need to be changed very frequently(e.g. daily to weekly), at much shorter intervals than stated bysome manufacturers. Instruments based on chemical ionisa-tion mass spectroscopy and quantum cascade laser absorp-tion spectroscopy need to be calibrated or at least zeroedfrequently, and the provision of a reliable gas-phase calibra-tion source in the field determines their measurement accu-racy. Wet chemistry instruments show good long-term sta-bility, are housed to operate with very short inlets and theliquid part of the system is easier to calibrate. They providea reliable differentiation between gas-phase NH3 and aerosolNH, which could not be validated for the other instrumentsduring this study. For future inter-comparisons using all in-lets at a single sampling point should be attempted, bearingin mind the logistic constraints when working with a largenumber of sizeable instruments. Not all instruments testedhere are suitable for accurate measurements at concentrations<1 ppbv, while the application of ion mobility spectroscopyis limited to low concentrations (<20 ppbv) and conditionswith no competing pollutants. Despite, recent advances intechnologies, the continuous measurement of NH3 remains achallenging and costly enterprise, in terms of capital invest-ment or running costs or both. Acknowledgements. The measurements were supported by the UKNatural Environment Research Council (NERC) through grant nos.NE/E018505/1 and NE/E018092/1, the UK Department for Envi-ronment, Food and Rural Affairs and its devolved administrationsthrough the Acid Deposition Processes Project and through theEuropean Commission Integrated Project NitroEurope. The firstauthor was recipient of exchange grant no. 2153 of the Nitrogenin Europe (NinE) project of the European Science Foundation.C. F. Braban gratefully acknowledges the loan of the CRDS andtechnical support from EnviroTechnology and Picarro.King'sCollege London gratefully acknowledges the loan of equipmentto carry out this research from the UK NERC Field SpectroscopyFacility. ( References ) ( Asman, W. A . H . , Sutton, M . A., a nd Schjorring, J. K.: Ammo-nia: emission, a tmospheric transport and deposition, N ew Phy-tol. , 139,27 - 48,1998. ) ( Bacon, T., Webber, K., and Carpio, R. A.: Contamination moni- toring f or ammonia, a m ines, and acid gases utilizing io n mobil-ity spectroscopy (IMS), P roc. SPIE-Int. Soc. Opt. E ng., Metrol-ogy, I nspection and Process Control f o r M i crolithography XII, ISBN 0-8194-2777-2,3332,550-559, 1998. ) ( Berden, G ., P eeters, R ., a nd Meijer, G .: C avity ring-down sp e c-troscopy: Experimental s chemes a n d ap p lications, I n t. R ev. Phys. Chem., 19,565-607,2000. ) ( Blatter, A., Neftel, A., Dasgupta, P. K., and Simon, P. K.: A com- bined w et effluent denuder and m i st chamber system for deposi- tion measurements of NH3,NH4,H N O,and NO3, in: Phy s ico- chemical Behaviour of Atmospheric Pollutants, ed i ted by : An -g eletti, G. and Restelli , G. , European Commission, B r ussels,767-772,1994. ) Breitenbach, L. P. and Shelef, M.: Development of a method for theanalysis of NO2 and NH3 by NO~measuring instruments,J. AirPollut. Control Assoc., 23,128-131,1973. ( C antrell, C. A .: T echnical Note: R e view of methods for linear least- squares fitting of data and application to atmospheric chemistryproblems, Atmos. Chem. Phys., 8,5477-5487,2008, http://www.atmos-chem-phys.net/8/5477/2008/. ) ( Cowen, K., S u mmer, A. L., Dindal, A., Ri g gs, K., Willenberg, Z.,Hatfield, J. , Pfeffe r , R. , and Scoggin , K. : Environmental Tech- nology Verification R eport. Pranalytica, I nc. Nitrolux 1 000 Am- bient NH3 A nalyser, ETV, 2004. ) ( Duyzer, J . H., Verhagen, H . L. M., W e ststrate, J. H ., B osveld, F.C., and Vermetten, A . W . M.: The dry deposition o f ammoniaonto a D ouglas f i r forest i n the Netherlands, A tmos. Environ., 29, 1 241- 1 253, 1 994. ) ( Eden, P: Weather log A ugust 2008, R. Met. S., Weather, 63, 11, 322-348, doi:10.1002/wea.347,2008. ) ( Eiceman, G. A. and Karpas, Z.: I on Mobility Spectrometry, CRC Press, Boca Raton, F L, 1 994. ) ( Erisman, J. W., Otjes, R., Hensen, A., Jongejan, P., van den Bulk,P., Khlystov, A., Moels, H., and Slanina, S . : Instrument develop-ment and application i n studies and monitoring of ambient N H3, Atmos. Environ.,35, 1913-1922,2001. ) ( Fangmeier, A ., H adwiger-Fangmeier, A., va n der Eerden, L., andJager, H.-J.: Effects of atmospheric ammonia on vegetation - a review, Environ. Pollut., 86,43-82,1994. ) ( Fehsenfeld, F . C., Huey, L . G ., L eibrock, E . , Dissly,R . , W i lliams,E., Ryerson, T . B., N orton, R., S ueper, D . T., a n d H a rtsell, B.: Results from an informal intercomparison of ammonia mea- surement t echniques, J . Geophys. Res., 107(D24), 4812, do i : 10.1029/2001JD001327,2002. ) ( Ferm,M.: A tmospheric ammonia and ammonium transport in Eu- rope a nd critical l oads: a review, Nutr. Cycl. Agroecosys., 51 , 5- 1 7, 1998. ) ( Ferm,M.: Method for determination of atmospheric NH3, A t mos.Environ.,13,1385-1393,1979. ) ( Gall, R., Perner, D., and Ladstatter-Weissenmayer, A.: S imultane-ous determination of NH3, SO2, NO and NO2 by direct U V - absorption in ambient air, Fresen. J. A nal. Chem., 340, 646-649, 1991. ) Galle, B., Bergquist, B., Ferm, M., Tornquist, K., Griffith, D. W. T.,Jensen, N. O., and Hansen, F.: Measurement of ammonia emis-sions from spreading of manure using gradient FTIR techniques,Atmos. Environ., 34,4907-4915,2000. Genfa, Z. and Dasgupta, P. K.: A Continuous Film-RecirculableDrop Gas-Liquid Equilibration Device. Measurement of Tracegaseous NH3, Anal. Chem., 72,3165-3170,2000. Griffith, D. W. T. and Galle, B.: Flux measurements of NH3,N2O and CO2 using dual beam FTIR spectroscopy and the flux-gradient technique, Atmos. Environ., 34,1087-1098,2000. Griffith,D. W.T.: Synthetic calibration and quantitative analysis ofgas phase infrared spectra, Appl. Spectrosc., 50, 59-70, 1996. Grisar, R., Preier, H., Schmidtke,G., and Restelli, G.: Monitoringof gaseous pollutants by tunable diode lasers, EC Air pollutionReport 3, CEC, Brussels, Belgium, 1987. ( Harren, F . J . M. , Cotti, G., Oomens, J . , a nd t e L i ntel Hekkert, S.: Photoacoustic Spectroscopy, i n: Trace G as M o nitoring, E n cy-clopedia of Analytical Chemistry, edited by: Meyers,R. A., John Wiley & Sons Ltd, Chichester, 2203-2226,2 0 00. ) ( Hill Jr. , H. H., Slems, W. F ., St. Louis, R. H ., and McMinn, D.G.: Ion Mobility Spectrometry, Anal. Chem., 62 , 1201A-1209A,1990. ) ( Husted, S., H ebbern, C. A ., Mattsson, M. , and Sch j oerring, J. K.:A critical experimental evaluation of methods for determination of NH; i n plant tissue, xylem sap and apoplastic fl u id, Physiol. Plant. , 109,167-179,2000. ) ( Janson, R., Rosman, K . , Karlsson, A., a nd Hansson, H . -C.: B i o-genic emissions and gaseous precursors to forest aerosols, Tellus, 53B,423-440,2001. ) ( Keuken, M. P., Schoonebeek, C . A. M., van Wensveen-Louter, A., and Slanina, J. : Simultaneous sampling of NH3, HNO3, HCl, SO2 a nd H202 in ambient air by wet annular denuder system,Atmos. Environ.,22,2541 - 2548, 1 988. ) ( Kim, S . , H uey, L . G . , S t ickel, R. E . , Tanner, D . J . , C rawford, J . H., Olson, J . R ., Chen, G ., B r une, W . H. , Re n , X., Les h er,R., Wooldridge, P. J ., Bertram, T. H ., P erring, A., C ohen, R. C., Lefer, B. L, S h etter, R . E ., A very, M ., D iskin, G .,and Sokolik, I.: Measurement of HO2NO2 in t h e f r ee tro-posphere during the intercontinental chemical t ransport experi- ment - North America 2004, J . Geophys. Res., 1 12, D12S01,doi:10.1029/2006JD007676,2007. ) ( Krupa, S. V .: Effects of atmospheric ammonia (NH3) on terrestrial vegetation: areview, Environ. Pollut., 12 4 ,179-221,2003. ) Lammel, G.: Determination of NH3 and nitric acid using a diffusiondenuder method, Fresen. J. Anal. Chem., 340, 684-686,1991. ( Langford, A. O., Goldan, P . D., and F e hsenfeld, F . C.: A Molyb- denum Oxide Annular Denuder System fo r Gas Phase Ambient NH3 Measurements, J. Atmos. Chem., 8,359-376,1989. ) ( Marcy, T. P., Gao, R. S., Northway, M. J.,Popp, P. J., Stark, H., and Fahey, D . W .: U sing chemical ionization m a ss spectrometry fo r detection of HNO3,H O l, a n d C l ONO2 in the atmosphere, Int. J . Mass Spectrom., 243, 63-70,2005. ) ( McManus, J. B., N e lson, D. D. , Sh o rter, J . H., Zahniser, M. S . , Mueller, A., Bonetti, Y., Beck, M., H o f stetter, D. , and Faist, J. : Quantum cascade lasers for open- and closed-path measurementof trace gases, i n: Diode l asers and applications in atmospheric sensing, edited by : Fried,A., Proc. SPIE 4817,22-33,2002. ) ( McManus,J. B., Sh o rter, J. H., N elson, D. D., a nd Z ahniser, M . S.:Sensors Compact Q u antum Cascade Laser Instrument for Rapid, High Sensitivity Measurements of Trace Gases in A ir, Sensors,2007 IEEE, 1341-1344,2007. ) ( Mennen, M . G., van Elzakker, B. G., va n Putten, E. M. , Uiterwijk, J. W . ,Regts, T. A., van H e llenmond, J., Wyer, G. P.,Otjes, R. P.,Verhage,A. J. L., Wouters, L. W., Heffels, C. J.G. Roemer, F. G., van d en Beld, L . , and T e tteroo, J. E. H.: Evaluation of automatic ammonia monitors for ap p lication in an air q u ality monitoringnetwork, Atmos. Environ., 30,3239-3256,1996. ) ( Milford, C., Sutton, M. A., Allen, A. G.,Karlsson, A., Davison, B. M., J ames, J. D ., R osman, K., Harrison, R. M. , an d Sape, J.N.: Marine a nd land-based i nfluence on atmospheric ammonia a nd ammonium over Tenerife, T ellus B, 52,273-289,2000. ) ( Milford, C., Theobald, M. R ., Nemitz, E ., and S utton, M.: Dy- namics ofNH3 exchange in response to cutting and fe r tilising an intensively-managed grassland, Water, Air, Soil Pollut., 1, 167- 176,2001 . ) ( Milford, C., Theobald, M. R., Nemitz, E. , Hargreaves, K. J., Ho r - vath, L., Raso, J ., Dammgen, U., Ne f tel, A. , Jo n es, S. K.,Hensen, A ., Loubet, B ., Cellier, P., and Sutto n , M . A.: Ammo-nia f luxes in relation to cutting and fertilization of an intensively managed grassland derived f r om a n inter-comparison of gradientmeasurements, B iogeosciences, 6, 819-834,2009, http://www.biogeosciences.net/6/819/2009/. ) ( Mozurkewich, M.: : T he D issociation-Constan t of Ammonium- Nitrate and Its Dependence on T emperature,Relative-Humidityand P article-Size, Atmos. Environ., 27,261-270,1993. ) ( Myles,L . , M eyers, T. P . , and Robinson, L.: Atmospheric NH3 mea- surement with a n i o n m o bility spectrometer, Atmos. Environ., 40,5745-5752,2006. ) ( N euman, J. A . , P a rrish, D . D . , T r ainer, M., R y erson, T. B., Hol- l oway, J. S., Nowak, J. B., Swanson, A., Flocke, F., Roberts,J. M ., B rown, S . S., Stark,H., Sommariva, R., Stohl, A., P el tier, R., Weber,R., Wollny, A. G., Sueper, D. T., H u bler, G., and Fehsen-feld, F. C.: Reactive nitrogen transport and p hotochemistry i n urban plumes over the North A tlantic Ocean, J. Geophys. Res., 111, D23S54, doi:10.1029/2005JD007010,2006. ) ( Norman, M., Hansel, A., and Wisthaler, A.: O2+as reagent ion in the PTR-MS instrument: d e tection of gas-phase a mmonia, I n -tern. J. Mass Spectrom., 26 5 ,382-287,2007. ) ( Norman, M., S pirig, C., W o lff, V., Trebs, I . , Flechard, C., Wi sthaler, A., Schnitzhofer, R., H ansel, A., and Neftel, A.: Intercomparison of ammonia measurement te c hniques at an intensively managedgrassland site (Oensingen, Switzerland), Atmos. Chem. Phys., 9, 2635-2645,2009, http://www.atmos-chem-phys.net/9/2635/2009/. ) ( Nowak, J . B ., H uey, L. G., R u ssell, A . G., Ti a n, D . , N e u-man, J . A., Orsini, D . , Sj o stedt, S. J. , Su l livan, A. P., Ta n- ner, D. J., Nenes, A., E dgerton, E ., and F ehsenfeld, F. C.:Analysis of urban gas phase ammonia measurements from the 2002 A tlanta A erosol N ucleation a nd Real-Time Characteriza- tion Experiment (ANARChE), J. G eophys. R es., 111, D17308, doi:10.1029/2006JD007113.2006. ) ( Nowak, J. B . , N eumann, J. A . , K o zai, K . , H u ey, L . G., T a nner, D . J., Holloway, J . S., Ryerson, T . B ., Frost, G. J.,McKeen,S. A .,and F ehsenfeld, F . C.: A chemical i onization mass s pectrometrytechnique for airborne measurements of N H 3,J. Ge o phys. Res.,112,D10S02, doi:10.1029/2006JD007589,2007. ) ( Pogany, A ., M ohacsi, A., Varga, A., Bozoki, Z . , G a lbács, Z . , Horvath,L., and S zabo,G.: A compact NH 3 detector with sub-ppb accuracy using near-infrared photoacoustic spectroscopy and preconcentration s ampling, Environ. S ci. T echnol., 43,826- 8 30, 2009. ) ( Pushkarsky, M . B . , Webber, M . E. , an d Pa t el, C. K. N. : Ul t ra-sensitive ambient ammonia detection using CO2 las e r-based pho- toacoustic spectroscopy, Appl. Phys. B-Lasers O., 7 7,381-3 8 5, 2003. ) ( Pushkarsky, M. B.,Webber, M. E., Baghdassarian, O., Narasimhan,L. R., and Patel, C. K. N. : Laserbased photoacoustic ammoniasensor for i ndustrial a pplications, Appl. P h ys. B- L asers O. spe-cial issue: Trends in Laser Sources, S pectroscopic Techniquesand T heir A pplications t o Trace G as Detection, 75, 391-396, .2002. ) ( Rella, C.: Picarro’s NH3 a nalyzer for A mbient Air Monitoring, 6. Nationales NH3-Treffen. Hannover, Deutschland, 1 9/20 Novem- ber,2008 3 ) ( Rothmann, L. S., Rinsland, C. P., Goldman, A . , Massie, S. T . , E d-wards, D . P ., Flaud, J. M., Perrin, A., Camy-Peyret, C., Danna, V ., Mandin, J. Y., Schroeder, J., McCann, A., Gamache, R . R ., Wattson, R . B., Yoshino, K., Chance, K. V., Jucks, K. W. , Brown, L. R . , Nemtchinov,V., a nd Varanasi, P.: The HITRAN mo l ecu-lar spectroscopic database and HAWKS (HITRAN atmosphericworkstation), 1 996 Ed., J . Quant. S pectrosc.R a ., 60, 665-710, 1998. ) ( Schwab, J.J., L i , Y., B ae, M.-S., Demerjian, K. L. , Hou, J., Zhou, X., Jensen, B., and Pryor, S. C.: A laboratory intercomparison of real-time gaseous ammonia measurement methods, Environ. Sci.Technol., 41,8412-8429,2007. ) ( Shaw, W. J., S picer, C. W., and K enny, D . V : Eddy correlation fluxes of trace gases using a tandem mass spectrometer, Atmos. Environ., 32,2887-2898, 1 998. ) ( Simon, P . K. a nd D asgupta, P . K. : Wet e ffluent denuder coupledliquid/ion chromatography systems: a nnular and parallel plate denuders, Anal. Chem., 65,1134 - 1139,1993. ) ( Simon, P.K., Dasgupta, P. K., and Vecera, Z.: Wet effluent denuder coupled liquid/ion chromatography systems, Anal . Chem., 63, 1237- 1 242,1991. ) ( Slusher , D. L., P itteri, S. J. , Haman, B . J ., Tanner, D. J ., and Huey, L. G.: A chemical ionization technique for measurement o f per-nitric acid in the upper troposphere and the polar boundary layer, Geophys. Res. Lett., 28,3875- 3 878,2001. ) ( Sunner,J., Nicol, G., and Kebarle, P.: Factors Determining Relative Sensitivity of Analytes i n Positive Mode Atmospheric-PressureIonization Mass-Spectrometry, Anal. Chem., 60, 1 3 00-1307, 1988. ) ( Sutton, M ., F owler, D., Burkhardt, J . K . , and Milford, C.: Veg- etation atmosphere exchange of ammonia: canopy cycling a nd the impacts of elevated nitrogen inputs, Water,Air Soil Po l l., 85,2057-2063,1995. ) ( Sutton, M. A., N emitz, E . , Milford, C., F owler, D., M oreno, J., San J ose, R., W yers, G. P. , Ot j es, R. P., Ha r rison, R. , Hu st ed, S ., and Schjoerring, J. K.: Micrometeorological measurement of net NH3 fluxes over oilseed rape during two vegetation periods,Agric. For. Meteorol., 105,351- 3 69,2000a. ) ( Sutton, M. A. , Dragosits, U. , Tang , Y . S . , a n d Fowler D.: Ammo-nia emissions from n on agricultural sources in th e UK, Atmos. Environ., 34,855-869,2000b. ) ( S utton, M . A., Tang, Y . S . , Dragosits, U., Fournier, N ., D ore, T . , Smith, R . I ., Weston K. J., and Fowler D .: A s patial analysis ofatmospheric ammonia and ammonium in th e UK, The ScientificWorld 1 (S2), 275-286,2001. ) ( Sutton, M. A., Nemitz, E ., E risman, J . W ., Beier, C., ButterbachBahl, K ., C ellier, W. de V ries,P., C otrufo, F ., Skiba, U., Di Marco, C . , J o nes, S., Laville, P . , S o ussana, J. F., L o ubet, B. ,T wigg, M., Famulari, D., Whitehead, J., G allagher, M. W., Nef- tel, A., Flechard, C. R ., H errmann, B., Calanca, P. L., Sch j o- erring, J. K., Daemmgen, U., Horvath, L. , Ta n g, Y. S. , Em - mett, B. A., Tietema, A., Penuelas, J., Kesik, M., Brueggemann, N., Pilegaard, K ., V esala, T ., C ampbell, C . L . , O l esen, J. E . , Dragosits, U ., T heobald, M . R., Levy, P. , Mobbs, D. C., Mil n e, R., Viovy, N ., V uichard N., Smith, J. U . , S m ith, P., B e rgamaschi, P ., Fowler, D., and Reis, S . : Challenges in quantifying biosphere-atmosphere exchange of nitrogen species, E n viron. P o llut., 1 50, 125-139,2007. ) ( T h omas, R . M . , Trebs, I., Otjes, R., Jongejan, P. A. C., ten Brink, H., Phillips, G., Kortner , M., Meixner, F . X ., a nd Nemitz, E . : An automated analyzer to measure surface-atmosphere exchangefluxes of water soluble inorganic aerosol compounds and reactive trace gases, Environ. Sci. Technol., 43(5), 1412-1418,2009. ) ( Tittel, F . K. , Richter , D. , and Fried, A.: Mid-infrared l aser appli- cations in spectroscopy, in: Topics in Applied P hysics vol. 8 9, edited by: S orokina, I . T. and Vodopyanov, K . L ., S pringer-Verlag, 445-516,2003. ) ( Warland, J. S., Dias, G. M., a nd Thurtell, G. W.: A tunable di o delaser system f or ammonia fl u x measurement over multiple plots,Environ. Pollut., 114, 215-221 , 2001. ) ( Warneck, P : Chemistry of the Natural A tmosphere, AcademicPress, New York, 1988. ) Wert, B. P., Fried, A., Henry, B., and Cartier, S.: Evaluation of inletsused for the airborne measurement of formaldehyde, J. Geophys.Res.,107(D13),4163,doi:10.1029/2001JD001072,2002. ( Whitehead, J. D ., L ongley, I. D., and Gallagher, M . W .: S e asonal and diurnal variation in atmospheric NH3 in a n u r ban environ- ment measured using a quantum cas c ade laser absorption spec- trometer, Water Air Soil Pollut. , 183 , 317- 3 29,2007. ) ( Whitehead, J. D ., Twigg, M., F a mulari, D . , N e mitz, E., S u tton, M. A ., G allagher, M. W ., a nd Fowler, D.: E valuation of Laser Absorption Spectroscopic Techniques for Eddy Covariance Flux Measurements of NH3, E n viron. Sci. T echnol., 42, 2041 - 2046, 2008. ) ( Wiebe, H . A., A nlauf, K . G., T uazon, E. C., Winer, A. M., Bier- mann, H.W., Appel, B. R ., Solomon, P. A., Cass, G. R., E llestad, T . G., Knapp, K . T .,Peake, E., Spicer, C . W., a nd Lawson, P. A . :A comparison of measurements of atmospheric ammonia by fil-ter packs, transition-flow r eactors, s imple and annular denudersand F ourier- T ransform Infrared-Spectroscopy, A tmos. E n viron. A-Gen. , 1019-1028, 1 990. ) ( Williams, E . J ., Sandholm, S. T ., Bradshaw, J.D., Schendel, J . S., Langford, A. O., Quinn, P . K., LeBel, P.J., Vay, S. A., Roberts, P. D., Norton, R. B., Watkins, B . A., Buhr, M . P., P arrish, D. D.,Calvert, J. G., and Fehsenfeld, F . C.: An intercomparison of five ammonia m e asurement techniques, J. Geophys. Res., 97 , 591- 61 1 , 1 992. ) ( Wyers, G. P . , Otjes, R . P ., and Slanina, J.: A continious flow de- nuder for the measurement of ambient concentrations and surface fluxes of NH3, Atmos. Environ., 27A, 2085-2090, 1 993. ) ( Yokelson, R . J., Christian, T . J . , Bertschi, I . T . , a nd H a o, W. M.:Evaluation of adsorption effect s on measurements of ammonia,acetic acid and methanol, J. Geophys. Res., 108, 46-49, 2 003. ) Published by Copernicus Publications on behalf of the European Geosciences Union. Atmos. Meas. Tech.,,ww.atmos-meas-tech.net//
关闭还剩20页未读,是否继续阅读?
北京世纪朝阳科技发展有限公司为您提供《大气中氨气体检测方案(氨气分析仪)》,该方案主要用于空气中分子态无机污染物检测,参考标准《暂无》,《大气中氨气体检测方案(氨气分析仪)》用到的仪器有Picarro G2103 超高精度氨气(NH3)气体浓度分析仪。
