KGM KYOTO ELECTRONICSAPDA-0197ov enLMANUFACTURING CO.,LTD. Application Note Determination of ethanolconcentration in disinfectionsolution by Portable Density/ Specific Gravity Meter Industry Instrument Measurement method ChemicalPortable Density/ Specific Gravity MeterResonant frequency oscillation 1. Scope This is an example about determination of the ethanol concentration with volume percent incommercial disinfection solution. The alcohol meter can be used enough for determination of pureethanol concentration on production process. Note: this measurement result does not completely match the label value of disinfection solutionbecause the commercial products contain additives like glycerin, etc. 2. Apparatus ·Portable Density/ Specific Gravity Meter DA-130N 3. Sample ·Disinfection solution 4. Reagent ·Pure water 5. Procedure Place sampling nozzle into beaker.23 Slowly pull the sampling lever with the forefinger. After the icon Eisi s ddiissppllaayyeed, start measurement with [ok/meas.] key. 6.Measurement results Alcohol (wt%) Alcohol (vol%) S.G. (t/t) Density (g/cm’) Temperature (℃) 1 63.8 71.3 0.8843 0.883 19.3 2 63.8 71.3 0.8843 0.883 19.3 3 63.8 71.3 0.8843 0.883 19.3 Mean 63.8 71.3 0.8843 0.883 - SD 0.00 0.00 0.00 0.00 - RSD(%) 0.00 0.00 0.00 0.00 - 京都电子工业株式会社-可睦电子(上海)商贸有限公司电话:021-54488867 电邮: kemu-kem@163. com 上海市徐汇区宜山路333号1201室网址: http://www.kem-china.com 便携式数字密度计测定消毒剂中乙醇的含量-应用说明(英文版) 便携式数字密度计DA-130N测定市面上免洗洗手液(消毒液)中乙醇含量(体积分数)的应用实例。便携式数字密度计DA-130N可用于生产过程中纯乙醇浓度的测定。注: 此测量结果与消毒液标签值不一定相符,因为该产品中含有甘油等添加剂。
关闭产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《消毒剂中乙醇含量检测方案(饮用酒检测仪)》,该方案主要用于消毒剂中生化检验检测,参考标准《暂无》,《消毒剂中乙醇含量检测方案(饮用酒检测仪)》用到的仪器有DA-130N手持式数字酒精计/酒精浓度计、DA-130Nc便携式密度计/比重计、ALM-155高精度乙醇浓度(酒精度)测定仪。
