KGM KYOTO ELECTRONICSMANUFACTURING CO.,LTD.APDA-0196ov enL Application Note Determinationof ethanolconcentrationirindisinfectionsolution by Alcohol meter IndustryInstrumentMeasurement method ChemicalAlcohol meterResonant frequency oscillation 1. Scope This is an example about determination of the ethanol concentration with volume percent incommercial disinfection solution. The alcohol meter can be used enough for determination of pureethanol concentration on production process. Note: this measurement result does not completely match the label value of disinfection solutionbecause the commercial products contain additives like glycerin, etc. 2.Apparatus ·Alcohol meter ALM-155 3. Sample 1))Place sampling nozzle into beaker. 2))Click a button to load sample and start measurement. Alcohol (vol%) at 20℃ S.G. (t/t) Density (g/cm) 1 71.5 0.8832 0.8816 2 71.5 0.8832 0.8816 3 71.5 0.8832 0.8816 Mean 71.5 0.8832 0.8816 SD 0.00 0.00 0.00 RSD(%) 0.00 0.00 0.00 ( 京 都电 子 工业株 式 会社 -可 睦电子(上海 )商 贸 有限公司 电话:0 2 1- 5 4488 867 电 邮: k em u - kem @ 1 6 3.co m ) 高精度酒精浓度计测定消毒剂中乙醇的含量-应用说明(英文版) 高精度酒精浓度计ALM-155测定市面上免洗洗手液(消毒液)中乙醇含量(体积分数)的应用实例。高精度酒精浓度计ALM-155可用于生产过程中纯乙醇浓度的测定。注: 此测量结果与消毒液标签值不一定相符,因为该产品中含有甘油等添加剂。
关闭产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《消毒剂中乙醇含量检测方案(饮用酒检测仪)》,该方案主要用于消毒剂中生化检验检测,参考标准《暂无》,《消毒剂中乙醇含量检测方案(饮用酒检测仪)》用到的仪器有ALM-155高精度乙醇浓度(酒精度)测定仪、DA-130N手持式数字酒精计/酒精浓度计、DA-130Nc便携式密度计/比重计。
