【转帖】转自小木虫的XPS分析数据库及wagner灵敏度因子的查询地址
  • swallowxfy
    2008/01/03
XPS及其它能谱仪
  • 近来发现Wager灵敏度因子的数据不是很全,遂上网搜索一下,收到如下的东东,和大家共享一下:
    http://emuch.net/html/200602/191094.html
    免费的XPS/AES等分析数据库
    作者: westwolf 发布日期: 2006-2-24 查看数: 499 出自: http://emuch.net
    网上资源(综合性):
    http://www.xpsdata.com/
    http://www.uksaf.org/tech/xps.html
    http://www.polymersolutions.com/xps.html
    http://goliath.emt.inrs.ca/surfsci/links.html
    http://www.npl.co.uk/nanoanalysis/
    学习资源:
    http://goliath.emt.inrs.ca/surfsci/xpslinks.html
    http://www.chem.qmul.ac.uk/surfaces/scc/scat5_3.htm
    http://www.chemistry.adelaide.ed ... rel/content/xps.htm
    http://cmm.mrl.uiuc.edu/techniques/xps.htm
    http://www.csma.ltd.uk/techniques/xray_photoelectron.htm
    http://en.wikipedia.org/wiki/X-ray_photoemission_spectroscopy
    数据库(部分已发,见http://emuch.net/bbs/viewthread. ... =1&highlight=):
    http://srdata.nist.gov/xps/
    www.lasurface.com/welfront.htm
    主要软件(部分已发, 见http://emuch.net/bbs/viewthread. ... =1&highlight=):
    http://www.phy.cuhk.edu.hk/~surface/XPSPEAK/
    http://www.casaxps.com/
    http://escalab.snu.ac.kr/~berd/Fitt/fitt.html
    离子溅射产额最新数据:
    (对估算深度剖面分析的厚度和表面刻蚀厚度非常有用)
    http://www.npl.co.uk/nanoanalysis/sputtering_yields.html
    找工作:
    http://goliath.emt.inrs.ca/surfsci/jobs/index.html
    主要公司:
    热电(VG)
    http://www.thermo.com/com/CDA/Category/CategoryFrames/1,,14934,00.html
    PHI ( 或PE物理电子学)
    http://www.phi.com/genf.asp?ID=284
    KRATOS
    http://www.kratos.com/
    主要参考书:
    Practical Surface Analysis -Auger and X-ray Photoelectron Spectroscopy
    D. Briggs and M. P. Seah (Editors), Wiley Interscience, 1990 (2nd ed.)
    Photoelectron Spectroscopy (Springer Series in Solid-State Sciences Vol. 82)
    S. Huefner, Springer Verlag, 1995
    Introduction to Photoelectron Spectroscopy (Chemical Analysis Vol. 67)
    P. K. Ghosh, Wiley Interscience, 1983
    Handbook of Monochromatic XPS Spectra - Vol. 1 - The Elements and Native Oxides
    B. V. Crist, XPS International, Inc., 1999
    Handbook of Monochromatic XPS Spectra - Vol. 2 - Commercially Pure Binary Oxides
    Handbook of Monochromatic XPS Spectra - Vol. 3 - Semiconductors
    Handbook of Monochromatic XPS Spectra - Vol. 4 - Polymers and Polymer Damage
    Handbook of Monochromatic XPS Spectra - Vol. 5 - Miscellaneous Materials
    On-Screen PDF Handbook of Monochromatic XPS Spectra - Vol. 1 - The Elements and Native Oxides, B. V. Crist, XPS International, Inc., 1999
    Modern ESCA - The Principles and Practice of X-ray Photoelectron Spectroscopy
    T. L. Barr, CRC, 1994
    Systematics in the Electronic Stucture of Poly-Valent Liquid Metals Determined by Electron Spectroscopy (Ph.D. Dissertation)
    G. Indlekofer, University of Basel, Switzerland, 1987
    Photo-electron Spectra Induced by X-rays of Above 600 Non-Metallic Compounds Containing 77 Elements
    C. K. Jorgensen and H. Berthou, Munksgaard Publishers, Denmark, 1972
    Handbook of X-ray Photoelectron Spectroscopy
    J. Moulder, William F. Stickle, P. E. Sobol, and K.D. Bomben, (J. Chastain, editor) Perkin Elmer Corporation (Physical Electronics), 1992 (2nd edition)
    C. D. Wagner, W. M. Riggs, L. E. Davis, and J. Moulder (G. E. Muilenberg, editor) Perkin Elmer Corporation (Physical Electronics), 1979 (1st edition)
    N. Ikeo, Y. Iijima, N. Nimura, M. Sigematsu, T. Tazawa, S. Matsumoto, K. Kojima, and Y. Nagasawa, JEOL, 1991
    High Resolution XPS of Organic Polymers - The Scienta ESCA300 Database
    G. Beamson and D. Briggs, Wiley Interscience, 1992
    Practical Handbook of Spectroscopy
    J. W. Robinson, CRC, 1991
    (XPS BE Tables from K. Siegbahn)
    VG Scientific XPS Handbook AdemVG Scientific, 1991 (1st edition)
    “表面分析”, 陆家和等编(清华大学),电子工业出版社.
    主要学术杂志:
    1. Surface and Interface Analysis
    2. Applied Surface Science
    3. Surface Science
    4. Surface Science Spectra
    5. J.Vac.Sci.Technol. A
    6. Vacuum
    7. Langmuir
    8. J.Physical Chemistry B
    9. Surface Letter and Review
    10. Applied Physics A
    11. ………….
    元素灵敏度因子(在线):
    http://www.uksaf.org/data/sfactors.html
    元素结合能(pdf,可下载)
    http://www.xpsdata.com/XI_BE_Lookup_table.pdf
    光电子截面:
    http://xdb.lbl.gov/Section1/Sec_1-5.html
  • 该帖子已被管理者-feixiong5134设置为精华,下面是奖励记录:加10积分,加5声望
  • 该帖子已被版主-feixiong5134加10积分,加2经验;加分理由:很好的资源,希望以后多多提供
  • feixiong5134
    第1楼2008/01/03
    很不错的帖子
    希望以后多多给大家提供一些
    谢谢
  • uncommon681
    第2楼2008/03/22
    谢谢 分享 学习中
  • jphu
    第3楼2008/06/08
    很有帮助,谢谢分享!
  • mypiazza
    第6楼2009/12/14
    很多都打不开了。
    我想找一本书:
    《Handbook of X-Ray Photoelectron Spectroscopy》 1995年出版的。
    不知道哪里可以下载到。
  • benbenzuo
    第7楼2009/12/21
    请问怎么使用呢?
  • sangjing
    第9楼2010/03/01
    非常好的资源,仔细研究下,分析时有很大的参考价值,帮助很大!感谢!
  • pangangchn
    第10楼2010/05/16
    谢谢分享
    对我很有帮助
