【求助】求烯草酮残留分析方法(最好为英文)
  • himhim1984
    2008/05/19
农残检测
  • 求烯草酮残留分析方法(最好为英文)
  • 我在故我思
    第1楼2008/05/19
    楼主,这里有两篇相关烯草酮(clethodim)的英文分析方法摘要,没有下载的权限,您可以先看看摘要,如果需要,可以去文献求助-应助版求助:
    1.LC/MS analysis of cyclohexanedione oxime herbicides in water.
    Marek LJ, Koskinen WC, Bresnahan GA.
    J Agric Food Chem. 2000 Jul;48(7):2797-801
    Abstract:
    A multiresidue method for the determination of alloxydim (methyl 2, 2-dimethyl-4, 6-dioxo-5-[1-[2-propenyloxy)amino]butylidene]cyclohexanec arb oxylate), clethodim (E, E)-(+/-)-2-[1-[[3-chloro-2-propenyl)oxy]imino]propyl]-5-[2-(ethylthio )propyl]-3-hydroxy-2-cyclohexen-1-one), sethoxydim ((+/-)-2-[1-(ethoxyimino)butyl]-5-[2-ethylthio)propyl]-3-hydroxy-2 -cy clohexen-1-one), and two metabolites, clethodim sulfoxide ((E, E)-(+/-)-2-[1-[[3-chloro-2-propenyl)oxy]imino]propyl]-5-[2-(ethylsulf inyl)propyl]-3-hydroxy-2-cyclohexen-1-one) and sethoxydim sulfoxide ((+/-)-2-[1-(ethoxyimino)butyl]-5-[2-ethylsulfinyl)propyl]-3 -hydroxy- 2-cyclohexen-1-one), in water by high-performance liquid chromatography/electrospray/mass spectrometry (LC/ES/MS) is reported. River water and distilled water were spiked at 0.08 and 0.8 microgram L(-1) with all three herbicides, which were then extracted from the water by C(18)-SPE (SPE = solid-phase extraction). The herbicides and metabolites were quantified and confirmed using selected ion monitoring. The percent recoveries of the herbicides from water spiked at 0.8 microgram L(-1) were as follows: alloxydim, 117 +/- 11%; clethodim, 96 +/- 14%; sethoxydim, 89 +/- 13%. There was no evidence of oxidation of clethodim and sethoxydim during the extraction to their respective sulfoxides. The limit of quantitation was <0.1 microgram L(-1). We have shown that we can analyze and confirm three cyclohexanedione oxime herbicides and two metabolites in water by LC/ES/MS. This multiresidue method should also be appropriate for other cyclohexanedione oximes.
    2.Determination of Clethodim and Its Oxidation Metabolites in Crops by Liquid Chromatography with Confirmation by LC/MS
    Susumu Ishimitsu,Akiko Kaihara,Kimihiko Yoshii,Yukari Tsumura,Yumiko Nakamura,Yasuhide Tonogai
    Journal of AOAC INTERNATIONAL
    Volume: 84 | Issue: 4
    Cover date: July 2001
    Page(s): 1172-1178
    Abstract:
    A method was developed for determination of the herbicide clethodim (C0) and its oxidation metabolites clethodim sulfoxide (C1) and clethodim sulfone (C2) in agricultural products. Upon extraction, both C0 and C1 were oxidized to C2 by m-chloroperoxybenzoic acid, and C2 was determined by liquid chromatography (LC). The C2 peak was confirmed by liquid chromatography/mass spectrometry (LC/MS) with electrospray ionization (ESI). Recoveries of C0 from radish, tomato, onion, sweet potato, kidney bean, carrot, cabbage, and lettuce ranged from 91 to 118% following fortification at 0.05–1.0 ppm. The detection limit of C2 in crops was 0.01 ppm (S/N > 3). The fortified samples of onion, sweet potato, kidney bean, and carrot were confirmed by LC/MS (ESI), and the peak of C2 was detected.
  • ningzuoping
    第2楼2013/07/18
    急需烯草酮的残留分析方法,中文的也行
  • 雾非雾
    第3楼2013/07/18
    Determination of Clethodim and Its Oxidation Metabolites in Crops by Liquid Chromatography with Confirmation by LCMS
  • 雾非雾
    第4楼2013/07/18
    LC Multi-Residue Pesticide Standard #5 on Ultra Aqueous C18 by LC-MS/MS
    RESTEK资料,仪器条件可以参考。
    注:暂时搜索完毕。
  • ljb1978
    第5楼2013/07/18
    版面版主很厉害的,几乎所有资料都能提供
