第2楼2007/07/19
MBS Methacrylate-butadiene-styrene 甲基丙烯酸-丁二烯-苯乙烯共聚物
MC Methyl cellulose 甲基纤维素
MDPE Medium-density polyethylene 中密聚乙烯
MF Melamine-formaldehyde resin 密胺-甲醛树脂
MPF Melamine/phenol-formaldehyde 密胺/酚醛树脂
PA Polyamide (nylon) 聚酰胺(尼龙)
PAA Poly(acrylic acid) 聚丙烯酸
PADC Poly(allyl diglycol carbonate) 碳酸-二乙二醇酯· 烯丙醇酯树脂
PAE Polyarylether 聚芳醚
PAEK Polyaryletherketone 聚芳醚酮
PAI Polyamide-imide 聚酰胺-酰亚胺
PAK Polyester alkyd 聚酯树脂
PAN Polyacrylonitrile 聚丙烯腈
PARA Polyaryl amide 聚芳酰胺
PASU Polyarylsulfone 聚芳砜
PAT Polyarylate 聚芳酯
PAUR Poly(ester urethane) 聚酯型聚氨酯
PB Polybutene-1 聚丁烯-[1]
PBA Poly(butyl acrylate) 聚丙烯酸丁酯
PBAN Polybutadiene-acrylonitrile 聚丁二烯-丙烯腈
PBS Polybutadiene-styrene 聚丁二烯-苯乙烯
PBT Poly(butylene terephthalate) 聚对苯二酸丁二酯
PC Polycarbonate 聚碳酸酯
PCTFE Polychlorotrifluoroethylene 聚氯三氟乙烯
PDAP Poly(diallyl phthalate) 聚对苯二甲酸二烯丙酯
PE Polyethylene 聚乙烯
PEBA Polyether block amide 聚醚嵌段酰胺
PEBA Thermoplastic elastomer polyether 聚酯热塑弹性体
PEEK Polyetheretherketone 聚醚醚酮
PEI Poly(etherimide) 聚醚酰亚胺
PEK Polyether ketone 聚醚酮
PEO Poly(ethylene oxide) 聚环氧乙烷
PES Poly(ether sulfone) 聚醚砜
PET Poly(ethylene terephthalate) 聚对苯二甲酸乙二酯
PETG Poly(ethylene terephthalate) glycol 二醇类改性PET
PEUR Poly(ether urethane) 聚醚型聚氨酯
PF Phenol-formaldehyde resin 酚醛树脂
PFA Perfluoro(alkoxy alkane) 全氟烷氧基树脂
PFF Phenol-furfural resin 酚呋喃树脂
PI Polyimide 聚酰亚胺
PIB Polyisobutylene 聚异丁烯
PISU Polyimidesulfone 聚酰亚胺砜
PMCA Poly(methyl-alpha-chloroacrylate) 聚α-氯代丙烯酸甲酯
PMMA Poly(methyl methacrylate) 聚甲基丙烯酸甲酯
PMP Poly(4-methylpentene-1) 聚4-甲基戊烯-1
PMS Poly(alpha-methylstyrene) 聚α-甲基苯乙烯
POM Polyoxymethylene, polyacetal" 聚甲醛
PP Polypropylene 聚丙烯
PPA Polyphthalamide 聚邻苯二甲酰胺
PPE Poly(phenylene ether) 聚苯醚
PPO Poly(phenylene oxide) deprecated 聚苯醚
PPOX Poly(propylene oxide) 聚环氧(丙)烷
PPS Poly(phenylene sulfide) 聚苯硫 醚
PPSU Poly(phenylene sulfone) 聚苯砜
PS Polystyrene 聚苯乙烯
PSU Polysulfone 聚砜
PTFE Polytetrafluoroethylene 聚四氟乙烯
PUR Polyurethane 聚氨酯
PVAC Poly(vinyl acetate) 聚醋酸乙烯
PVAL Poly(vinyl alcohol) 聚乙烯醇
PVB Poly(vinyl butyral) 聚乙烯醇缩丁醛
PVC Poly(vinyl chloride) 聚氯乙烯
PVCA Poly(vinyl chloride-acetate) 聚氯乙烯醋酸乙烯酯
PVCC chlorinated poly(vinyl chloride)(*CPVC) 氯化聚氯乙烯
PVI poly(vinyl isobutyl ether) 聚(乙烯基异丁基醚)
PVM poly(vinyl chloride vinyl methyl ether) 聚(氯乙烯-甲基乙烯基醚)
RAM restricted area molding 窄面模塑
RF resorcinol-formaldehyde resin 甲苯二酚-甲醛树脂
RIM reaction injection molding 反应注射模塑
RP reinforced plastics 增强塑料
RRIM reinforced reaction injection molding 增强反应注射模塑
RTP reinforced thermoplastics 增强热塑性塑料
S/AN styrene-acryonitrile copolymer 苯乙烯-丙烯腈共聚物
SBS styrene-butadiene block copolymer 苯乙烯-丁二烯嵌段共聚物
SI silicone 聚硅氧烷
SMC sheet molding compound 片状模塑料
S/MS styrene-α-methylstyrene copolymer 苯乙烯-α-甲基苯乙烯共聚物
TMC thick molding compound 厚片模塑料
TPE thermoplastic elastomer 热塑性弹性体
TPS toughened polystyrene 韧性聚苯乙烯
TPU thermoplastic urethanes 热塑性聚氨酯
TPX ploymethylpentene 聚-4-甲基-1戊烯
VG/E vinylchloride-ethylene copolymer 聚乙烯-乙烯共聚物
VC/E/MA vinylchloride-ethylene-methylacrylate copolymer 聚乙烯-乙烯-丙
烯酸甲酯共 聚物
VC/E/VCA vinylchloride-ethylene-vinylacetate copolymer 氯乙烯-乙烯-醋
酸乙烯酯共 聚物
PVDC Poly(vinylidene chloride) 聚(偏二氯乙烯)
PVDF Poly(vinylidene fluoride) 聚(偏二氟乙烯)
PVF Poly(vinyl fluoride) 聚氟乙烯
PVFM Poly(vinyl formal) 聚乙烯醇缩甲醛
PVK Polyvinylcarbazole 聚乙烯咔唑
PVP Polyvinylpyrrolidone 聚乙烯吡咯烷酮
S/MA Styrene-maleic anhydride plastic 苯乙烯-马来酐塑料
SAN Styrene-acrylonitrile plastic 苯乙烯-丙烯腈塑料
SB Styrene-butadiene plastic 苯乙烯-丁二烯塑料
Si Silicone plastics 有机硅塑料
SMS Styrene/alpha-methylstyrene plastic 苯乙烯-α-甲基苯乙烯塑料
SP Saturated polyester plastic 饱和聚酯塑料
SRP Styrene-rubber plastics 聚苯乙烯橡胶改性塑料
TEEE Thermoplastic Elastomer,Ether-Ester" 醚酯型热塑弹性体
TEO Thermoplastic Elastomer, Olefinic" 聚烯烃热塑弹性体
TES Thermoplastic Elastomer, Styrenic" 苯乙烯热塑性弹性体
TPEL Thermoplastic elastomer 热塑(性)弹性体
TPES Thermoplastic polyester 热塑性聚酯
TPUR Thermoplastic polyurethane 热塑性聚氨酯
TSUR Thermoset polyurethane 热固聚氨酯
UF Urea-formaldehyde resin 脲甲醛树脂
UHMWPE Ultra-high molecular weight PE 超高分子量聚乙烯
UP Unsaturated polyester 不饱和聚酯
VCE Vinyl chloride-ethylene resin 氯乙烯/乙烯树脂
VCEV Vinyl chloride-ethylene-vinyl 氯乙烯/乙烯/醋酸乙烯共聚物
VCMA Vinyl chloride-methyl acrylate 氯乙烯/丙烯酸甲酯共聚物
VCMMA Vinyl chloride-methylmethacrylate 氯乙烯/甲基丙烯酸甲酯共聚物
VCOA Vinyl chloride-octyl acrylate resin 氯乙烯/丙烯酸辛酯树脂
VCVAC Vinyl chloride-vinyl acetate resin 氯乙烯/醋酸乙烯树脂
VCVDC Vinyl chloride-vinylidene chloride 氯乙烯/偏氯乙烯共聚物
