雾非雾
第1楼2008/06/07
quantification: 定量,量化,强调以数量来表示;
quantitation:定量,测数量【医】
个人认为"the quantification by NMR is corrected by..."和 "quantitation by MS is not absolute" 是合适的
poorlittle
第6楼2008/06/07
第一次遇见quantitate 这字, 好奇, 看了一些字典解释, 择录如下:
quantitate
To measure the quantity of. Esp. with high accuracy and including measurement uncertainty, as in quantitative analysis.
http://en.wiktionary.org/wiki/quantitate
to measure or estimate the quantity of; especially : to measure or determine precisely
http://www.merriam-webster.com/cgi-bin/dictionary?book=Dictionary&va=quantitation
quantify
to determine, express, or measure the quantity of
http://www.merriam-webster.com/cgi-bin/dictionary?book=Dictionary&va=quantify
to assign a quantity to
http://en.wiktionary.org/wiki/quantify
觉得quantitate 指量度, 并强调是精密的量度
quantify 也指量度, 但另外还有一解: to assign a quantity to, 意为量化。 即是将非量值之attribute (属性, 特征)用量值表示出来。 例如用1至10来量化痛楚程度。
As mentioned before, I have never encountered the word “quantitate” (also NMR) and have no idea of its correct usage. The above is for your reference only.
应留意行内的惯用法。
jwei1
第7楼2008/06/08
应留意行内的惯用法。
[/quote]
谢谢大家的帮助!
