Malvern FAQ -- KB000075 Q: How do I find out which software version I have? A: The standard way to find which software version you are currently running is to select Help from the main menu and then About. Your software version will then be displayed. 马尔文常见问题解答——KB000075号 问:如何查明我用的是哪个软件版本? 答:找到你当前所用软件版本的标准方法是:从“主菜单”中选择“帮助”,再选择“关于”,你的软件版本就能显示出来。
