【求助】求助一段中文的翻译
专业英语
  • 校准后的结果确认是依据设备能力与设备的精确度的比对的结果来确定设备是否满足工艺条件要求的过程.
    多谢热心人啦!
  • laurelhuang
    第1楼2008/10/29
    According to the capability and accuracy correlation of the instrument, we confirm the calibration results, in order to make sure the instrument be fit for the claims of the process.
  • qianhu
    第2楼2008/10/29
    The result confirmation of the calibration of equipment is a process to determine the equipment whether meets the technological conditions of the requirments of which is based on the results of the comparation between the ability and precision of the equipment.
