我在故我思
第2楼2008/11/29
楼主,您可以参考一下这篇文献: [url=https://insevent.instrument.com.cn/t/Mp]气相色谱法测定烟草中灭多威残留量[/url]
我在故我思
第6楼2009/01/29
灭多威用GC测定的文献不是很多:
Direct gas chromatographic determination of methomyl (lannate®) with microcoulometric nitrogen detection
I. H. Williams
Abstract:
A microcoulometric method is described for the direct determination of nanogram amounts of methomyl (S-methyl-N-[(methylcarbamoyl)-oxy]thioacetimidate). An all-glass gas chromatographic system coupled to a microcoulometer with a nitrogen-specific cell was used. The column was packed with a mixture of 6% OV210 and 4% OV101 on Gas Chrom Q, as was the glass transfer tube which connected the chromatographic column to the pyrolysis furnace. Some loss occurred but response was linear from 125 to 20 ng and sensitivity was such that 20 ng of methomyl could be readily measured.
http://www3.interscience.wiley.com/journal/112600458/abstract?CRETRY=1&SRETRY=0
Determination of methomyl by using 1-fluoro-2,4-dinitrobenzene reaction and gas-liquid chromatography
http://pubs.acs.org/doi/abs/10.1021/jf60192a029
