无名
第1楼2008/12/19
这个部分没有提到具体测试流程:
9. Toys, equipment and other products for use by a child in learning or play that have had a surface coating material applied to them that contains any of the following substances:
(a) Repealed. [SOR/2005-110, s. 2]
(b) total lead in excess of 600 mg/kg;
(c) any compound of antimony, arsenic, cadmium, selenium or barium introduced as such if more than 0.1 per cent of such compound dissolves in five per cent hydrochloric acid after stirring for ten minutes at 20C; or
(d) any compound of mercury introduced as such.
智慧的弟弟
第2楼2008/12/19
但是就是按照这个东西申请认可的,我看了广州SGS的认可附表。
