【求助】求瓦里安CAIY-50紫外可见分光光度计的原理结构及维护
紫外可见分光光度计(UV)
  • 求瓦里安CArY-50型号的紫外分光光度计的原理结构及维护
    要简洁的说明
    不要一本书啊
  • 祥子
    第1楼2009/02/04
    结构如下:
    这里有个以前别人发的manual,第三章就是讲维护的
    http://www.instrument.com.cn/bbs/shtml/20071002/1006160/
    cary 50采用了非常多的先进技术,大家可以讨论下。特别想希望tutm能给解读下附件。
    特点如下:
    1.最大扫描速度24000nm/分,这意味着 扫描190-1100nm整个波段仅需要3秒钟.
    2.数据收集速度80 点/秒 ,在动力学测量中,能得到完整的数据
    3.测定样品的收光度高达3Abs,所以经常不需要样品稀释
    4.高强度脉冲氙灯仅读取数据时闪亮,所以不会引起光酸样品的降解
    5.高强度脉冲氙灯使之可以使用光束分裂器,不会因为能量损失引起过度的光度噪音,优于样品和参比光束同时被修正,所以不会随扫描速度变化而发生位移
    6.高度聚集的小光斑,使用非常适合用光纤探头,基于上述原因,使用微量池时亦能得到很好效果
    7.Cary 50可以开着样品室盖工作,不受室内光线性的影响
    基本上tutm介绍的所有先进技术都有了。
    看看这7个特点有什么特殊含义呢
    特点1,采用的应该是固态检测器,比如CCD,或者CMOS
    特点2,12.5ms/点,不知道这算不算先进。
    特点4,这就是以前chemweb问过的如何防止光解。
    特点7. 这点不理解,它的详细解释如下
    The Cary 50 is unaffected by room light. You can operate with the sample compartment open or closed, you won't notice the difference. So, if your sample won't quite fit in the sample compartment, it's OK, you can leave the lid off. If you want to keep dust, dirt and room light out of the sample compartment, then you can use the lid.
    不知道大家能不能帮解释下。
    还有一个特点是
    he Cary 50 gets its power from the PC, it is only on when the PC is switched on. This also means that if something goes wrong with the electronics, fixing the problem is as simple as changing the board in the PC.
    它的意思是只要换个板子就行,这有啥好说的呢?
    看了下cary 50的附件,挺玄的,
    附件分Solid Sample Accessories 和Liquid Sample Accessories,固定样品附件啥意思呢?怎么检测固体样品呢?
    附件网址是这里,谁能详细说下吗?
    http://www.varianinc.com/cgi-bin/nav?products/spectr/uv/accessories/c50_accall&cid=KMKNJHIIFI
    下图是一些比色皿
    1号比色皿特点:
    These self-masking cells are stoppered to prevent solvent vaporization.hey can be used with the Cary Temperature Probe accessory which allows monitoring of the solution temperature inside the cell.
    2号比色皿特点:
    This cell comes with a magnetic stirrer bar and features a circular stirring well at its base to accommodate the stirring bar. This ensures that the bar spins easily. The cell is suitable for use with the Cary 1, 3, 4, 5, 100, 300, 400& 500series peltier thermostatted multicell holder which features both peltier temperature control and magnetic stirring.
    3号比色皿特点:
    This innovative design features a lens on the face of the cell to capture more of the incident light.
    上面有透镜,很神奇。
    4号比色皿特点:
    These solid quartz cells offer low volume, short pathlength and excellent heat transfer. We recommend them for use when you have a limited sample volume and either the sample is highly concentrated or you are working in a region where the solvent absorbs strongly. These microcells are also ideal for temperature controlled experiments.
    5号比色皿特点:
    These cells require as little as 2.5 µL of sample.. They have the optimum 'Z' height (the distance between the base of the cell and the centre of the light beam) for the current range of Cary spectrophotometers. The sample can be inserted and retrieved from the cell with a pipette or syringe.
    由于解释的不好,所以没翻译。
  • tutm
    第2楼2009/02/04
    Cary 50 确实是集中了很多现代先进技术的分光光度计。它是和传统结构的分光光度计有很大的不同,不然也不会得创新奖了。
    它的结构nemoium已经有图示了。我没用过这款仪器,但从nemoium收集的资料来看,它应该CCD或PDA阵列型检测器的。
    由于使用高亮度闪光型点状氙灯光源,环境光对其影响微乎其微,一些使用高强度点光源或用光纤导光的分光光度计都是可以在没有“暗室”情况下测试的,特别适用于野外在线测试。
    下午有事离开了,几个小时后回来,看到下面7楼Spain已经作了很精彩的解释。
    另外还想多说几句;
    Cary 50电源取自电脑,这在爱万提司,海洋光学等光谱仪中类似,只要插上USB连接线,电源就来自数据接口。
    这类仪器日常维护比普通分光光度计更简单,仪器中基本没有机械运动部件,灯泡使用寿命很长,所以故障率很低。只是我感觉这样的仪器如果出了故障,基本上不可能由非专业人员使用常规工具进行维修,包括更换闪光灯。
    Solid Sample Accessories,是测试固体样品的附件。
    liquid sample Accessories,是测试液体样品的附件。你理解的没错
  • ajiareal
    第3楼2009/02/04
    Solid Sample Accessories 固体样品池架,用来测量固体样品的反射率透过率什么的。
    流动样品池架应该是配合蠕动泵用的。还可以搭配最后那种比色皿使用。
    没什么玄的,很普遍啊。
  • 祥子
    第4楼2009/02/04
    这样啊。
    tutm 发表:Cary 50 确实是集中了很多现代先进技术的分光光度计。它是和传统结构的分光光度计有很大的不同,不然也不会得创新奖了。
    (待续)
  • 祥子
    第5楼2009/02/04
    Solid Sample Accessories,是指固体样品池架吗?我理解成测试固体样品的附件了。
    liquid sample Accessories,我以为是测试液体样品的附件。
    可能我理解错了。
    ajiareal 发表:Solid Sample Accessories 固体样品池架,用来测量固体样品的反射率透过率什么的。
    没什么玄的,很普遍啊。
  • 祥子
    第6楼2009/02/04
    可能我理解错了。
    没什么玄的,很普遍啊。
  • Spain
    第7楼2009/02/04
    专家来解答
    分析得有道理!
    确切来说是硅光电池为检测器。
    原因在于:采用得是脉冲氙灯,仪器始终检测的是一个变量(室外光线假设为常量),同时,光斑小,能量高,强度集中,室外光线得微小波动不造成影响。
    其实开始最另我惊讶得是这个特点:
    解释:Cary 50仪器没有开关,并且仪器里面没有任何电路板和变压器,仪器通过连接到电脑主板上的集成卡来取电,同时控制仪器运行和采集,从控制系统来说是一个高度集成的系统,从主机来说,是一个及其精简的设计。所以故障率很低。打开仪器,里面只有光路、几个电机和为数不多的线。
    nemoium 发表:这样啊。
  • 祥子
    第8楼2009/02/04
    明白了。就是跟电脑差不多。使用电脑电源,然后安个采集卡什么的。可能还会使用电脑主板,集成显卡,DDR2内存,硬盘。
    现在很多分光光度计,使用做好的电源了。就是外面有丝网的那种,可以有几组电压输出。可以理解为电脑电源。不在自己设计电源板。
    spain 发表:解释:Cary 50仪器没有开关,并且仪器里面没有任何电路板和变压器,仪器通过连接到电脑主板上的集成卡来取电,同时控制仪器运行和采集,从控制系统来说是一个高度集成的系统,从主机来说,是一个及其精简的设计。所以故障率很低。打开仪器,里面只有光路、几个电机和为数不多的线。
  • Spain
    第9楼2009/02/05
    [quote]原文由 tutm 发表:Cary 50 确实是集中了很多现代先进技术的分光光度计。它是和传统结构的分光光度计有很大的不同,不然也不会得创新奖了。
    另外还想多说几句;
    说明:
    1)光源可以客户自行更换,工具不复杂,并且随机器会带过来一些常规的工具。
    2)电脑主机上的控制板客户可以安装更换,修的可能性不大。但是这个控制板类似电脑的网卡,出故障的可能性很小。
  • tutm
    第10楼2009/02/05
    哦,这个仪器我没用过,这种光源在普通使用条件下几乎和仪器是同寿命的吧。我们有一台类似的闪光灯型的分光光度计,用了10年多了,大概测试了10万次以上,用有关检测标样检验,光源和分光系统都没有问题,倒是控制电子线路板换过一块。
    spain 发表:说明:
