welivo
第2楼2009/02/06
RMB:76500.00元
广州市万里河科技仪器有限公司重庆分公司
联 系 人:许全斌 (总经理) 13983782993
地 址:重庆市沙坪坝区三峡广场正升自由康都B栋27-13号
联系电话:023-65302836 65302816(业务部) 65302286(经理室)
传 真:023-65305985
邮 编:400030
邮 箱:wanlihe_xqb@163.com
网 址:www.welivo.com
chriswang111
第4楼2009/02/10
Our company’s homepage : www. justinbdnl.com
We are remarkable semiconductor used tools supplier for Front-end , Back-end & ATE .
We offer a full range of Front-end / Back-end semiconductors processing equipment.
Also we satisfy our customers by provide our services, such as Modification, Refurbish, Parts provide, Technology support, Repair service and so on.
Now we're actively marketing the following Back-End and ATE tools for sale, as below information:
All tools are available for inspection in Korea.
Please contact us if you're interested in.
My Email address: chris.wang@justinbdnl.com
1. Disco DFG840 Back Grinder, 4 sets
@U$45,000.00 per system
@U$40,000.00 per system for packaged deal of 4 sets/package
All tools are located in Korea
2. Disco DFD640 Dicing Saw, 4 sets
@U$38,000.00 per system for packaged deal of 4 sets/package
3. TSK AWD5000A Dicing Saw, 2 sets
@U$38,000.00 per system for packaged deal of 2 sets/package
4. Nitto DR8500 Laminator (Taper), 5 sets
@U$25,000.00 per system
@U$20,000.00 per system for packaged deal of 2 sets/package
5. Nitto HR8500 Tape Remover, 3 sets
6. Takatori ATRM2100 Tape Remover, 2 sets
7. TSK UF200 Probe Station, 1 set
@U$18,000.00 per system
@U$15,000.00 per system for packaged deal of 10 sets/package of UF200S
8. TSK UF200S Probe Station, 15 sets
9. TSK UF200SA Probe Station, 15 sets
@U$19,000.00 per system
10. TSK A-PM-90A Probe Station, 15 sets
@U$6,500.00 per system
@U$5,000.00 per system for packaged deal of 10 sets/package
11. TEL P8 Probe Station, 15 sets
@U$12,000.00 per system
@U$10,000.00 per system for packaged deal of 10 sets/package
12. TEL P8XL Probe Station, 2 sets
@U$15,000.00 per system for packaged deal of 2 sets/package
wxjy17
第5楼2009/03/02
产品简介:NYL-300D手自动可调水泥压力机本机专供测定水泥胶砂抗压强度之用,采用合适的抗压夹具也可以测定砖及石块等建筑材料抗压强度,选用合适的抗折夹具也可进行混凝土抗折试验。电脑全自动控制试验过程,显示、记录、储存、打印试验结果。也可手动加载,互不干涉,是水泥厂、建筑工程单位、产品质量监督检验站、大专院校必不可少的设备。
备注说明:共两箱:主机:780kg 123×80×180cm
控制器+电脑+控制台:100kg 135×68×87cm
本产品执行标准:GB/T 3722 《液压式压力试验机》
产品符合GB/T17671标准要求
技术参数PARAMETERS
最大试验力 300KN
测量范围 0-300Kn
手动 度盘指示0-60kN、0-300kN、0-60kN、0-300kN
度盘分度值 0-60kN时 0.2kN/格 0-150kN时 0.5kN/格 0-300kN时 1kN/格
自动恒速加载时 计算机显示
试验机预热30分钟后,在15分钟内的零点漂移不超过满量程的 ±0.2%
示值相对误差 ±1%
活塞直径×最大行程 Φ125×120(mm)
加载速率(可自行设定) 0.6~9.0kN/s
加载速率误差 ±7%
承压板净距 280mm
承压板直径 φ150mm
外形尺寸(长×宽×高) 1050×800×1500(mm)
包装尺寸 123×80×180/135×68×87cm
毛重/净重 800/880kg
电压功率 380V/1000W
联系人:马晓锋 电话:0510-82711289
