本帖想介绍的是一种新颖可变光径设计的测试部件,也是可以测极高浓度样品的,可以与ATR探头媲美,原名SoloVPE Variable Pathlength Extension。它由美国 C Technologies, Inc.公司近年开发成功,可与瓦里安Cary50配合使用,缺点是只能在实验室使用。
它的基本特性: 光径范围:10微米-15毫米 光径步长:5微米 Variable Pathlength Spectrometer Pathlength range: 0.010 - 15 mm Pathlength resolution: 0.005 mm Pathlength accuracy: +/- 1% at 0.5 mm Pathlength repeatability: > 99% Wavelength range: 190 - 1100 nm Wavelength modes: single / multi point & full spectra Absorbance capability: 1000 times a standard 10 mm cuvette Sample vessels: Materials & volumes to meet various requirements Sample can be retained Fibrette TM: Interchangable, single-use (这个可能不必这样做) Pathlength modes: Scanning & Discrete Software: Dynamic control, powerful & customizable
