才哥
第2楼2009/03/16
原来是SGS发布的。。。。。
为什么不说DEHP、DBP和BBP也可能列入呢?
现在去炒一个去年底的旧新闻,还有断章取义之嫌。
欧盟只是将HBCDD、DEHP、DBP、BBP(而不仅仅是HBCDD)列为优先评估物质,并没有确定何时加入。
COM(2008)809 article 4.7原文:
7. When there is an unacceptable risk to human health or the environment, arising from the use of substances, and in particular the substances listed in Annex III, which needs to be addressed on a Community-wide basis, the list of prohibited substances in Annex IV shall be reviewed using a methodology based on the process set out in Articles 69 to 72 of Regulation (EC) No 1907/2006. Those measures designed to amend non essential elements of this Directive shall be adopted in accordance with the regulatory procedure with scrutiny referred to in Article 18(2).
而附件3里就是上述提到的4种物质。附件4就是RoHS现在管控的6大物质及其限量。
无名
第3楼2009/03/17
有时候市场行销行为会出离实际的技术本位!游戏于两者间,才能算是紧密结合吧!
