【求助】帮忙翻译EP中的一段话
  • dongyuzhang520
    2009/03/16
专业英语
  • 相关物质HPLC检查中,关于梯度程序的:
    1.as mobile phase at a flow rate of 1.5ml/min a double isocratic programme using the following conditions. 红体字该如何理解?
    2.The test is not valid unless the resolution between the peaks corresponding to verapamil and verapamil impurity I is at least 5.0 and verapamil impurity M elutes from the column.
    这个5.0是什么意思?没看明白
    3.Appearance of solution.是指澄清度吗?
    多谢高手解答!
  • 该帖子已被版主-何当奇加3积分,加2经验;加分理由:有效求助
  • dongyuzhang520
    第1楼2009/03/16
    呵呵,刚忘了一句,现补充下:
    4.Disregard any peak with an area less than 0.1 times the area of the principal peak in the chromatogram obtained with reference solution (b)
  • happyjyl
    第2楼2009/03/16
    楼主以后求助时最好把上下文发上来,否则google不到原文的话就难以理解了。
    看了一下BP原文中的表格,double isocratic programme应该是指分两个阶段进行等度洗脱。第一阶段的流动相配比是A:B(63:37),持续22分钟。第二阶段的流动相配比是A:B(35:65),持续8分钟。
    这个5.0是维拉帕米色谱峰和杂质I色谱峰之间的分离度。这句话的意思是说:这个实验有效必须满足两个条件:1.维拉帕米色谱峰和杂质I色谱峰之间的分离度不低于5.0;2.杂质M应从色谱柱上洗脱。
    3.Appearance of solution.是溶液外观,包括澄清和无色两方面。
  • 该帖子已被版主-何当奇加5积分,加2经验;加分理由:应助
  • happyjyl
    第3楼2009/03/16
    In the chromatogram obtained with the test solution: the area of any peak, apart from the principal peak, is not greater than the area of the principal peak in the chromatogram obtained with reference solution (b) (0.1 per cent);
    供试品溶液色谱图中,除主峰外的任何色谱峰的峰面积应不大于对照溶液(b)色谱图中主峰的峰面积(0.1%)。--即单个杂质的限度为0.1%。
    the sum of the areas of the peaks, apart from the principal peak, is not greater than three times the area of the principal peak in the chromatogram obtained with reference solution (b) (0.3 per cent).
    (供试品溶液色谱图中)除主峰外的任何色谱峰的峰面积之和应不大于对照溶液(b)色谱图中主峰峰面积的3倍(0.3%)。--即总杂质的限度为0.3%。
    Disregard any peak with an area less than 0.1 times the area of the principal peak in the chromatogram obtained with reference solution (b).
    (供试品溶液色谱图中)若有任何色谱峰的峰面积小于对照溶液(b)色谱图中主峰峰面积的十分之一,则忽略不计。--即含量低于0.01%的杂质可忽略不计。
  • cristina228
    第4楼2009/03/17
    学习了,向happy致敬!呵呵~~
  • dongyuzhang520
    第5楼2009/03/21
    学习了,谢谢各位!
