pingpingzhu
第5楼2009/05/09
这里我给大家整几篇文献,这些文献也是我向我老大哪里要的.应该有很大的参考价值,我希望大家看完之后,结合自己的实验数据,再到这里总结一下,我想只有各位齐心协力,不久就会整出一个大家都可参考应用的通用方法.在此谢谢各位前辈了.
A review of analysis and environmental occurrence.pdf
Analysis of chlorinated paraffins in cutting fluids and.pdf
Biodegradation of chlorinated parans and long-chain.pdf
Effects of short-chain chlorinated paraffins on soil organisms.pdf
Screening of short- and medium-chain chlorinated paraffins in.pdf
Study of photochemical oxidation of standard chlorinated paraffins and.pdf
极品懒人
第8楼2009/09/16
用这个程序可以出峰,我刚试过没多久。到320得保留时间可以变长
