【求助】(还剩第1篇)求助 英文文献两篇
  • stephanie1984
    2009/04/16
文献检索-互助
  • 悬赏金额:11积分状态:已解决
  • 一、
    作者:J J Kirkland
    杂志:Journal of Chromatographic science
    年份(卷、期):1972,10,593页
    因为自己能力有限,没有查找到原文,也不知道文章题目是什么
    二、
    题目:Carbon-13 CP/MAS NMR study of the structural dependence of urea-formaldehyde resins on formaldehyde-to-urea molar ratios at different urea concentrations and pH values
    作者:I Ssuer Chuang, Gary E. Maciel
    杂志:Macromolecules,
    年份(卷期) 1992, 25 (12), 3204–3226
zhumenjun1984 2009/04/16
[img]https://www.instrument.com.cn/bbs/images/affix.gif[/img][url=http://www.instrument.com.cn/bbs/download.asp?ID=144462]2[/url]
  • stephanie1984
    第2楼2009/04/16
    谢谢,第一篇不知道是不是不好查
  • 大陆
    第3楼2009/04/16
    太老,无电子版,找馆藏途径吧。
    stephanie1984 发表:谢谢,第一篇不知道是不是不好查
  • 54247564
    第4楼2009/04/24
    第一篇只找到了索引,应该是楼主要的,试试馆藏吧
    Bibliographic Information
    High-performance liquid chromatography with porous silica microspheres. Kirkland, J. J.. Exp. Stn., E. I. du Pont de Nemours and Co., Wilmington, DE, USA. Journal of Chromatographic Science (1972), 10(10), 593-9. CODEN: JCHSBZ ISSN: 0021-9665. Journal written in English. CAN 79:87183 AN 1973:487183 CAPLUS
    Abstract
    New totally porous, spherical silica particles of <10 .mu. are superior column packings for high-performance liq. chromatog. ($$lc). These porous microspheres are prepd. in narrow particle size ranges and have been used for liq.-liq., liq.-solid and exclusion chromatog. since both the overall size and internal porosity can be selected and closely controlled. Highly efficient columns of these particles are conveniently prepd. by a high-pressure slurry-packing technique by using stabilized aq. suspensions. Performance of columns of these microspheres are the highest yet reported, with 5-6 .mu. particles producing 23 effective plates/sec for solutes with capacity factors, k' = 12. The performance of the microsphere columns is >1000 times that of classical $$lc systems and equals that of open tubular (capillary) gc columns.
    Indexing -- Section 80-4 (Organic Analytical Chemistry)
    Section cross-reference(s): 66
    Chromatography, column and liquid
    (high-performance, porous silica microspheres as column packings for)
    7631-86-9, uses and miscellaneous
    Role: ANST (Analytical study); USES (Uses)
    (porous microspheres, as adsorbent for high-performance liq. chromatog.)
    Supplementary Terms
    chromatog porous silica microsphere column
  • hstudent
    第5楼2009/04/26
    馆藏有,可以文献传递呀
  • stephanie1984
    第6楼2009/04/29
    谢谢,不过我现在不在学校了,可还有其他的办法可以得到?
