jing12281
第4楼2009/05/07
3,看原文:article33.1:
1. The supplier of a substance or a preparation shall provide the recipient of the substance or preparation with a safety data sheet compiled in accordance with Annex II:
(a) where a substance or preparation meets the criteria for classification as dangerous in accordance with Directives 67/548/EEC or 1999/45/EC; or
(b) where a substance is persistent, bioaccumulative and toxic or very persistent and very bioaccumulative in accordance with the criteria set out in Annex XIII; or
(c) where a substance is included in the list established in accordance with Article 59(1) for reasons other than those referred to in points (a) and (b).
这里面的shall译作必须,也就是说符合下述条件就必须向接受方提供SDS。这是强制性要求。但是显然不能把这句话理解为:假如不符合那些条件,就一定不需要提供SDS。
article33.1: Any supplier of an article containing a substance meeting the criteria in Article 57 and identified in accordance with Article 59(1) in a concentration above 0,1 % weight by weight (w/w) shall provide the recipient of the article with sufficient information, available to the supplier, to allow safe use of the article including, as a minimum, the name of that substance.
这里的理解同上,也就是如果SVHC超过0.1%就必须给客户传递信息,但依然不能理解为不超0.1%就不用传递。如果是这样,那我产品如果评估的结果小于0.1%的话,那我是不是可以不理客户的调查?
所以法规中其实都只是规定了强制提交SDS和强制传递信息的条件,而并没有规定无需提交SDS和无需传递信息的条件。
你需要提交SDS表格并且在45天内通报
