[1] Cheatham M M, Sangrey W F, White W M. Sources of error in external calibration ICPMS analysis of geological samples and an improved non_liner drift correction procedure .Spectrochim Acta, 1993,48B, 48B :487~506 . [2] Doherty W. An internal standardization procedure for the determination of yttrium and the rare earth elements in geological materials by inductively coupled plasma_mass spectrometry .Spectrochim Acta, 1989,44B, 44B :263~280 . [3] Xie Q, Jain J, Sun M, et al. ICPMS analysis of basalt BIR_1 for trace elements .Geostand Newslett, 1994,18, 18 :53~63 . [4] Schonberg G. Simultaneous determination of thirty_seven trace elements in twenty_eight international rock standards by ICPMS .Geostandards Newsletter, 1993,17, 17 :81~97 .
[5] Jenner G A, Longerich H P, Fryer B J, et al. Inductively coupled plasma_mass spectrometric analysis of geological samples: a critical evaluation based on case studies .Chem Geol, 1990,83, 83 :105~118 . [6] Eggin S M, Woodhead J D, Kinslet L, et al. Sample method for the simultaneous and precise analysis of 40 or more trace elements in geological samples by ICP_MS using enriched isotope internal standardization .Chem Geol, 1996,134, 134 :311~326 .
[7] Thompson J J, Houk R S. A study of internal standardisation in inductively coupled plasma mass spectrometry .Appl Spectrosc, 1987,41, 41 :801~806 .
8) Lin S L, He M, Hu S H, et al. Precise determination of trace elements in geological samples by ICPMS using compromise conditions and fine matrix_matching strategy .Analytical Science, 2000,16, 16 :1~6 . 9] Xie Q, Jain J, Sun M, et al. ICP-MS analysis of basalt BIR-1 for trace elements .Geostandards Newslett, 1994,18, 18 :53-63 . 10] Luck J H, Luders V. Determination of Trace Elements in Hydrothermal Calcites by ICP-MS .Mikrochim Acta, 1989,33, 3(3) :329
