wzy1736939 2009/05/18
1200 HPLC Budgetary Quotation Date: 2008-8-12 To: 安捷伦科技有限公司 Attn: 文锐 Tel: 13908170469 Pos Product Number Qty 1 G1310A 1 6861.48 1200单元梯度 1200 Quaternary Pump with Degasser Includes quaternary pump, solvent cabinet, 4 solvent bottles, vacuum degasser and CAN cable. 2 G1328B 1 2008 手动进样器 3 G1314B 1 7379.78 紫外可见检测器 1200 Uv-vis Detector Includes diode-array detector with long-life deuterium and tungsten lamp, CAN cable, no flow cell included. 4 G1314B # 018 1 1283.4 标准流量池 Standard flow cell includes stainless steel flow cell with 10mm path length and 13 microliter volume, pressure tight up to 120 bar. 5 G2170BA 1 6509 二维[url=https://insevent.instrument.com.cn/t/5p][color=#3333ff]液相色谱[/color][/url]软件 HPLC 2D ChemStation Software 32bit For data acquisition, control and evaluation of chromatographic data from one liquid chromatograph. 6 01080-68702 1 126 [url=https://insevent.instrument.com.cn/t/5p][color=#3333ff]液相色谱[/color][/url]验收标样 Isocratic and gradient test sample.Misc. Dangerous Goods (incl Mag. Mat.) 7 01018-22707 1 30.86 泵出口过滤白头,5PK PTFE Frits 5PK 小计:USD 23731 运保费:USD 1186.55 总计:USD 24917.55 国内采购:(RMB) 计算机及打印机: 8000 条款: 1)此报价为参考报价 2)报价有效期为1个月 3)交货期限:收到合同和信用证后45天 4)赠送C18150MM 柱一根
爱杰杰 2009/05/18
需要大约4万美元 ITEM PART NO. DESCRIPTION QTY UNIT PRICE AMOUNT US$ 1 G1354A 1200 Quaternary Pump with Degasser 1 16614.23 16614.23 四元梯度泵,带在线真空脱气机 2 OPTION 030 Active seal wash option 1 949.90 949.90 连续柱塞冲洗 3 OPTION 500 LAN Communications Interface 1 767.05 767.05 LAN 卡 4 G1328B 1200 Series Manual Injector 1 1909.83 1909.83 1200 系列手动进样器 5 G1314A 1200 Variable Wavelength Detector 1 6952.60 6952.60 1200 可编程可变波长紫外检测器 6 OPTION 018 Standard Flow Cell 1 1262.70 1262.70 标准流量池 7 G2170BA HPLC 2D ChemStation Software 1 5973.44 5973.44 二维化学工作软件 8 G2182AA ChemStation GPC data analysis software 1 3369.74 3369.74 GPC 分析软件包 9 01018-22707 PTFE Frits 5PK 1 30.73 30.73 过滤白头 10 0890-1763 1/16"od 0.007"id (0.18mm) 1.5m PEEK tbng 1 24.20 24.20 PEEK 管线 11 0100-1516 Fingertight fitting 1 21.52 21.52 手拧接头 12 79911GF-084 PL aquagel OH 40 300*7.5 8u 1 1518.00 1518.00 PL 分子量分布柱(分子量范围:10K-200K) 13 880995-902 300SBC18 Analytical HPLC 4.6*250 1 496.80 496.80 ZORBAX SB-C18 蛋白分析柱 US$ 39890.74 US$ 1994.54 US$ 41885.28
wzy1736939
第5楼2009/05/18
Date: 2008-8-12
To: 安捷伦科技有限公司
Attn: 文锐
Tel: 13908170469
1 G1310A 1 6861.48
1200单元梯度
2 G1328B 1 2008
手动进样器
3 G1314B 1 7379.78
紫外可见检测器
标准流量池
5 G2170BA 1 6509
二维液相色谱软件
6 01080-68702 1 126
液相色谱验收标样
泵出口过滤白头,5PK
PTFE Frits 5PK
小计:USD 23731
运保费:USD 1186.55
总计:USD 24917.55
国内采购:(RMB)
计算机及打印机: 8000
条款:
1)此报价为参考报价
2)报价有效期为1个月
3)交货期限:收到合同和信用证后45天
4)赠送C18150MM 柱一根
爱杰杰
第7楼2009/05/18
需要大约4万美元
四元梯度泵,带在线真空脱气机
连续柱塞冲洗
LAN 卡
1200 系列手动进样器
1200 可编程可变波长紫外检测器
标准流量池
二维化学工作软件
GPC 分析软件包
过滤白头
PEEK 管线
手拧接头
ZORBAX SB-C18 蛋白分析柱
US$ 39890.74
US$ 1994.54
US$ 41885.28
