walterbai
第1楼2009/07/28
High temperature furnace, Type STE-12 H Version 08 available for 900°C, 1000°C and 1100°C 高温环境试验炉STE-12 H-08
High quality 3-zone split model for easy installation of specimen and extensometer.
三段温区及对开易于装备附件
Both halves of the furnace are hinged on a common axis, which also serves as a swivel mounting for the furnace.
对开式高温炉系列,在同一个轴线上安装方便
Power supplies, the temperature control thermo-elements, and apertures for customer's own thermo-elements are mounted on the furnace's rear side.
电源及热电偶温度控制器在高温环境箱后
Furnace case made from stainless steel.
高温炉炉体外为不锈钢炉壁
The Version 08 can come in various dimensions to suit loadstring.
08系列产品有不同规格尺寸可供客户选择
The furnace features extensometer cut-out.
Technical Data: 技术指标
• 3 zone temperature regulation /3级温度调节
• Rated temperature 100°C to/温度范围 900°C / 1000°C or 1100°C
• Heating rate/ 升温速度 20 °C/min
• Heating zone height/加热区域 300 mm
• Temp. regulation accuracy/温控精度 ± 1-2 °C
• Approx. Dimensions/ 规格尺寸
- Inside diameter/内径 100 mm
- Outside diameter/外径 275 mm
- Height/ 高度 405 mm
- Weight/ 重量 25 kg
