【资料】Handbook of Industrial Water Treatment
  • 环保得忍着等春天
    2009/08/23
专业英语
  • 环保得忍着等春天
    第1楼2009/08/23
    PART Ⅰ Introduction
    Chapter 01 Water Sources, Impurities and Chemistry......................3
    Chapter 02 Environmental Considerations…………………………..13
    Chapter 03 Applying Quality Methods………………………………..20
    PATR Ⅱ External Treatment
    Chapter 04 Aeration……………………………………………………27
    Chapter 05 Clarification………………………………………………..34
    Chapter 06 Filtration……………………………………………………44
    Chapter 07 Precipitation Softening…………………………………...53
    Chapter 08 Ion Exchange…………………………………………….68
    Chapter 09 Membrane Systems……………………………………..100
    PART Ⅲ Boiler Water Systems
    Chapter 10 Boiler Feedwater Deaeration…………………………..106
    Chapter 11 Preboiler And Boiler Corrosion Control………………..114
    Chapter 12 Boiler Deposits: Occurence And Control……………..144
    Chapter 13 Boiler Blowdown Control……………………………….159
    Chapter 14 Boiler System Failures………………………………….172
    Chapter 15 Chemical Cleaning Of Steam Generator Systems…..191
    Chapter 16 Steam Purity……………………………………………..198
    Chapter 17 Measurement Of Steam Purity………………………...207
    Chapter 18 Steam Turbine Deposition, Erosion, and Corrosion…212
    Chapter 19 Condensate System Corrosion………………………...219
    Chapter 20 Fireside Preboiler Systems……………………………..233
    Chapter 21 Boiler Fireside Deposit And Corrosion Control……….241
    Chapter 22 Cold-End Deposition And Corrosion Control………….247
    PART Ⅳ Cooling Water Systems
    Chapter 23 Cooling Water Systems--Heat Transfer......................255
    Chapter 24 Corrosion Control-Cooling Systems...........................260
    Chapter 25 Deposit And Scale Control-Cooling System...............276
    Chapter 26 Microbiological Control-Cooling System....................284
    Chapter 27 Chlorine And Chlorine Alternatives............................300
    Chapter 28 Macrofouling Control..................................................316
    Chapter 29 Cooling Tower Wood Maintenance............................322
    Chapter 30 Once-Through Cooling...............................................327
    Chapter 31 Open Recirculating Cooling Systems.........................334
    Chapter 32 Closed Recirculating Cooling Systems......................353
    Chapter 33 Pretreatment Of Cooling Water Systems...................358
    Chapter 34 Air Conditioning And Refrigeration Systems..............362
    PART Ⅴ Chemical Feed and Control
    Chapter 35 Chemical Feed Systems.............................................374
    Chapter 36 Monitoring And Control Of Water Treatment..............401
    PART Ⅵ Wastewater and Gas Cleaning Systems
    Chapter 37 Wastewater Treatment................................................418
    Chapter 38 Gas Cleaning Systems................................................444
    PART Ⅶ Control Water Analyses and their Interpretation
    Chapter 39 Analytical Methods and Equipment.............................455
    Chapter 40 Expression of Analytical Results.................................459
