sin2008
第2楼2009/09/05
是英文的,是那个什么加州旧金山法案,
原文是
(c)Total Acetic-Acid Immersion Test Based Standard. The Ceramicware Food/Beverage Product must achieve a result of 0.99ppm or less for lead and 7.92ppm or less for cadmium after correction for internal volume when tested under the protocol attached hereto to Exhibit B(the ASTM C927-99 test method, modified for total immersion with results corrected for internal volume).
文中好像提及最后的限制值是经internal volume修正后才得到的,那直接出溶出液的结果没关系吗?不会产生误差?还是我理解不正确?请指点,谢谢。
