zengzhengce163
第1楼2009/10/27
Polymorphism (or crystal polymorphism) is a phenomenon related to the solid state ; it is the ability of a compound in the solid state to exist in different crystalline forms having the same chemical composition. Substances that exist in a non-crystalline solid state are said to be amorphous.
多态性(或多晶性)是与固态物质有关的现象,是具有相同的化学组成固态物质存在不同的结晶形式。非晶形固态物质称为无定形。单质的这种现象的(例如硫),称为同素异形体。
