何当奇 2008/06/05
'Label claim' is defined in the Act as: 'in relation to wine goods, means a claim about their vintage, variety or geographical indication made on a wine label, in a commercial document or in an advertisement, and includes a claim so made about the vintage, variety or geographical indication of wine goods from which they were manufactured.' • Generic name wines, such as Moselle, Claret, Dry Red, Dry White etc., which make no reference in a label statement as to vintage, variety or geographical indication, are not considered 'label claim' wines. 是不是跟药品里面的也差不多?没有注意过药品说明书,不知道具体是怎么说的
yaya91 2008/06/05
是标示吧?药品的说明书或标签上写的规格。内容一般是含某种主药多少mg。
poorlittle 2008/06/05
[quote]原文由 [B]happyjyl[/B] 发表: [quote]原文由 [B]poorlittle[/B] 发表: 看了一些网上资料, 明白其大概意思, 但不知行内的特定用语。 猜 : 成份声称? [/quote] 呵呵,能不能详细描述一下?[/quote] From the meanings of the following information obtained from internet: Not a single product met its label claim—some were close and some ... Label Claim. Per Capsule. Test Result. Per Capsule. Percent of Label ... ineffective, and is used for label claim only. to prove beyond doubt that it meets the label claim of a minimum protein ... Lean Body Mass 60 is lab tested to meet the label claim of potency According to a Consumer Council test,their actual down content, in many cases, was less than the label claim. the test came back 4mg under label claim. ... Knowing what's going into a specific label claim can help you understand the protection that vaccines will provide
闲鹤野云 2008/06/05
标示值????[em0814]
youjian000 2008/06/05
提供一句语言环境: These drugs contents were found to be in good agreement with the label claim values. ‘标签’标示量 ;[color=#DC143C]标称量[/color];标称值 我觉得“标称量”比较好,不知是否对?
何当奇
第8楼2008/06/05
