【求助】(ok)求助文献六篇【完成,多谢】
文献检索-互助
  • 【篇号】1
    【作者】Wei Li and Peiyi Wu
    【文章标题】Biomimetic synthesis of monodisperse rosette-like calcite mesocrystals regulated by carboxymethyl cellulose and the roposed mechanism: An unconventional rhombohedra-stacking route
    【期刊名,年份,卷(期),起止页码】 CrystEngComm, 2009, 11, 2466 - 2474, DOI: 10.1039/b901580a
    【全文链接】http://www.rsc.org/Publishing/Journals/CE/article.asp?doi=b901580a
    【篇号】2
    【作者】Yunhua Liu, Jianfei Mao, Ping Jiang, Zemin Xu, HongyanYuan and Dan Xiao,
    【文章标题】Facile fabrication of Cu(OH)2 and CuO nanoribbon arrays by silver-mediated oxidation
    【期刊名,年份,卷(期),起止页码】 CrystEngComm, 2009, 11, 2285 DOI: 10.1039/b909514b
    【全文链接】http://www.rsc.org/Publishing/Journals/CE/article.asp?doi=b909514b
    【篇号】3
    【作者】Xiaoxiao Yu, Jiaguo Yu, Bei Cheng, and Mietek Jaroniec
    【文章标题】Synthesis of Hierarchical Flower-like AlOOH and TiO2/AlOOH Superstructures and their Enhanced Photocatalytic Properties
    【期刊名,年份,卷(期),起止页码】 J. Phys. Chem. C, 2009, 113 (40), pp 17527–17535
    【全文链接】http://pubs.acs.org/doi/abs/10.1021/jp906992r
    【篇号】4
    【作者】Shaozhen Wang, Qian Wang, Jun Liu, Zhiguo Cheng, Dajie Si and Baoyou Geng,
    【文章标题】Kinetic manipulation of the morphology evolution of FePO4 microcrystals: from rugbies to porous microspheres
    【期刊名,年份,卷(期),起止页码】 CrystEngComm, 2009, 11, 2510 DOI: 10.1039/b907979n
    【全文链接】http://www.rsc.org/Publishing/Journals/CE/article.asp?doi=b907979n
    【篇号】5
    【作者】Xiaoheng Liu, Mohammad Afzaal, Karthik Ramasamy, Paul O’Brien, and Javeed Akhtar
    【文章标题】Synthesis of ZnO Hexagonal Single-Crystal Slices with Predominant (0001) and (000) Facets by Poly(ethylene glycol)-Assisted Chemical Bath Deposition
    【期刊名,年份,卷(期),起止页码】 J. Am. Chem. Soc., Article ASAP
    【全文链接】 http://pubs.acs.org/doi/abs/10.1021/ja906992s
    【篇号】6
    【作者】Yonggang Chang, Jian Xu, Yunyan Zhang, Shiyu Ma, Lihui Xin, Lina Zhu, and Chengtian Xu
    【文章标题】Optical Properties and Photocatalytic Performances of Pd Modified ZnO Samples
    【期刊名,年份,卷(期),起止页码】J. Phys. Chem. C, Article ASAP
    【全文链接】 http://pubs.acs.org/doi/abs/10.1021/jp9050808
  • 知而後行
    第7楼2009/11/17
    提醒一下楼主将此帖修改成悬赏帖
