daxu
第2楼2010/03/19
Fullprof Refinement - Y2O3
Files needed: y2o3.dat; y2o3.cif
Learning Outcomes: This example shows a simple Rietveld refinement of Y2O3 in fullprof. You may have used the same dataset in topas/gsas.
1. Create a new folder and copy the data file Y2O3.dat and the Y2O3.cif files into it. Start WinPlotr and press the EdPCR button. Press cif-PCR, select Y2O3.cif and press ok in the window that appears. The next step is to work down each of the buttons.
2. Press General and type in a title.
3. Press Patterns, Data file/peak shape and select the data file Y2O3.dat. Select X,Y,sigma (XYdata) as data format.
3.1 In Refinement/simulation select X-ray; make sure, the correct radiation/wavelength is chosen.
3.2 Pattern calculation/ peak shape: Select e.g. Pseudo-Voigt (scroll to find this); change the Range of calculation to a reasonable cut-off value. Higher values will result in longer calculation times, too low values will lead to poor fits. Try with a value of e.g. 15*FWHM. Compare the result to that using a value of 2*FWHM.
4. Select the Background Type, chose e.g. 6-coefficient polynomial.
5. You can use Excluded Regions to exclude selected 2theta ranges from the refinement.
6. Return to the main EdPCR window and click on Phases. Type in the phase name, e.g. Y2O3. Select the Method of calculation, e.g. Structural Model (Rietveld Method) for Rietveld, Profile matching with constant scale factor for LeBail fits.
7. Press Contribution to patterns and select X-ray. Select Pseudo-Voigt Peak shape.
8. Press Refinement in the main window. Chose an adequate number of Refinement cycles. Start with e.g. 10 cycles. Tick the parameters you want to refine in the different sections of this Refinement menu. Select a reasonable order for refining the parameters and make sure to gradually increase the number of parameters. Selecting too many parameters in one step will lead to divergence of the refinement. Start this refinement by selecting the lattice parameters, profile parameter W, Scale factor (from the "Profile" box) and the first two background polynomial coefficients (in background box). If you are happy with your selection press OK and save the input file (file/save) u into the same folder as the data file. There is no need to close the EdPCR window. N.B. if you don't click save the PCR file will not be updated.
9. It's might be worth going through the PCR file to check all your changes have been made at this stage. In particular check that all three atoms in the cif file (2*Y and 1*O) have been loaded.
10. Press FP in Winplotr, select input and data file. The refinement will start and inform you about the residuals, chi^2 and the parameter with the largest shift in each cycle. Continue with this data set until convergence is reached. If the refinement diverges, think of a different refinement strategy. Click on "OK" while you want to continue refining and "No" when you're happy.
11. You can look at the refinement by zooming in the winplotr window. A right click returns you to an unzoomed picture.
12. After convergence, reload the input file in EdPCR (File/reload). N.B. if you don't do this you won't get the refined values.
13. Visually inspect the refinement result and think of a strategy to improve the fit. Select additional parameters to refine, e.g. U and V and/or more background coefficients. Save the input file and redo the refinement… Continue until you are satisfied with the refinement result. Regularly check the parameter values to identify fit artefacts quickly. If the parameters have physically meaningless values, think of another refinement strategy. Pretty often, a different order of refining the parameters does the trick. Make sure to reset the parameters to reasonable values before trying out a different strategy.
14. Prior to refining asymmetry parameters, open the PCR-file by clicking on the PCR-button in Winplotr. Manually enter a reasonable cut-off 2 theta value for asymmetry-correction below the flag AsyLim (try different values and inspect the refinement results). Save the PCR and return to the EdPCR window. Reload the input file and sequentially start to refine asymmetry parameters. Make sure that your selection of the peak-profile function is compatible with your selection of asymmetry correction. Some profile functions already have an implemented asymmetry correction.
15. Play with the output options to check, what information is obtained. If you want to do some Fourier-map calculation to e.g., find missing atoms, select Patterns output - Structure factors file (FOU) and tick GFOURIER. You can then use the program GFOURIER to calculate different Fourier-maps.
16. If you exclude the 2 theta region between 0 and 16°, you should finally obtain an Rwp of around 6% and a Bragg-R factor for Y2O3 around 3.5%.
Modified 18-Jun-2009 by John S.O. Evans.
另外,我再把这个网址http://www.dur.ac.uk/john.evans/ ... torial_fullprof.htm
和我精修的结果附上,供大家讨论交流,共同学习~~~
关于y2o3.dat; y2o3.cif 这两个文件,大家可以在我提供的网址里下载,精修结果图见链接http://g.zhubajie.com/urllink.php?id=854077667qc4np6tbinuklm
另外精修的一般顺序为:
scalor->零点矫正->晶胞参数->背底->峰型参数->温度因子->原子坐标、占位等。
