myreebok
第2楼2010/08/27
Robustness (ruggedness) - A measure of a mc thod's capacity to remain
unaffected by small variations in the main parametc rs. Introduction of deliber-
ate variations in the validation process will defint critical parameters in the
method; for example, incubation times and temp xatures, concentrations of
buffer constituents, pH, amount of components tdded, degree and type of
mixing. An assessment of robustness can influence he production of protocols
to ensure that correct emphasis is given to critical an i non-critical parameters or
tasks.
from Analytical Molecular Biology Quality and Validation
czq8
第8楼2010/12/20
1) robust
鲁棒
1.Dyeing control based on robust H_∞ multi-step prediction;
基于鲁棒H_∞多步预测的染色控制
2.Parameter tuning for nonlinear robust controller with high gain observer;
带有HGO的非线性鲁棒控制器及其参数整定
3.Designing method of robust dynamic inversion for 3-D terminal guidance law;
三维末制导律的鲁棒动态逆设计方法研究
2) robust
稳健
1.Study on the Robustness of A Star Pattern Recognition Algorithm;
一种星模式识别算法的稳健性研究
2.Robust Estimation of the Parameters in Damped Exponential Signal Model;
指数信号模型中参数的稳健估计
3.Robust Algorithm for Communication Signal Blind Separation Fourth-Order-Cumulant-Based;
基于四阶累积量的稳健的通信信号盲分离算法
3) robust
抗差
1.P-Q decoupled state estimation algorithm based on robust theory;
基于抗差理论的P-Q分解状态估计算法
2.the influence functions of the Lp estimation (one dimension and multi-dimension ) have been derived and the robustncss of Lp estimation has been analyzed while the observational errors obey the contaminated distribution which the data include the outliers disturbed.
根据M估计理论,导出了Lp估计的影响函数,分析了Lp估计的抗差能力,并用效率来测度估计的优劣、综合抗差能力和效率,指出观测数据中含有粗差的扰动,应用p为[1。
3.Based on the theory of M estimation of the location parameters, the influence functions of L P estimation is educed and the robustness of L P estimation is analyzed in the condition that the observational errors obey the universal distribution (P distribution).
本文根据定位参数M估计理论,导出了LP估计的影响函数,分析了LP估计的抗差能力,同时还推导了LP估计的渐近效率,综合抗差能力和效率,分析了LP估计的优劣性,明确指出,用观测数据中含有粗差扰动的数据和P为(1,1。
4) robust
强壮性
5) robust
稳健的
1.By using the analog cascade elliptic filters desi gn method, and the bilinear method of transforming analog filters to digital filte rs, and the frequency transformation method of digital filters, a simple robust cascading digital IIR filter is designed.
利用级联型模拟椭圆滤波器设计方法、双线性模拟—数字滤波器变换方法和数字滤波器频带变换方法,设计了一种简便、稳健的级联型数字IIR滤波器。
6) robust
鲁捧控制
补充资料:鲁棒性
鲁棒性
robustness
控制系统在其特性或参数发生摄动时仍可使品质指标保持不变的性能。鲁棒性原是统计学中的一个专门术语,20世纪70年代初开始在控制理论的研究中流行起来,用以表征控制系统对特性或参数摄动的不敏感性。在实际问题中,系统特性或参数的摄动常常是不可避免的。产生摄动的原因主要有两个方面,一个是由于量测的不精确使特性或参数的实际值会偏离它的设计值(标称值),另一个是系统运行过程中受环境因素的影响而引起特性或参数的缓慢漂移。因此,鲁棒性已成为控制理论中的一个重要的研究课题,也是一切类型的控制系统的设计中所必须考虑的一个基本问题。对鲁棒性的研究主要限于线性定常控制系统,所涉及的领域包括稳定性、无静差性、适应控制等。鲁棒性问题与控制系统的相对稳定性(频率域内表征控制系统稳定性裕量的一种性能指标)和不变性原理(自动控制理论中研究扼制和消除扰动对控制系统影响的理论)有着密切的联系,内模原理(把外部作用信号的动力学模型植入控制器来构成高精度反馈控制系统的一种设计原理)的建立则对鲁棒性问题的研究起了重要的推动作用。当系统中存在模型摄动或随机干扰等不确定性因素时能保持其满意功能品质的控制理论和方法称为鲁棒控制。早期的鲁棒控制主要研究单劻路系统频率特性的某些特征,或基于小摄动分析上的灵敏度问题。现代鲁棒控制则着重研究控制系统中非微有界摄动下的分析与设计的理论和方法。
说明:补充资料仅用于学习参考,请勿用于其它任何用途。
czq8
第9楼2010/12/20
【转帖】Robust 的译文是真棒还是真棒槌默认分类 2010-11-14 10:53:14 阅读58 评论0 字号:大中小 订阅 .
Robust
请问计量经济学文献中经常出现的 Robust 是什么意思, 不仅请翻译,也请说明含义!谢谢!
作者:xuehe 时间:2007-5-29 10:04:00
第 2 楼
翻译为稳健性检验,数理统计有时称鲁棒检验。关于稳健性检验请看教材吧。
作者:baby8962 时间:2007-5-30 4:43:00
第 3 楼
当大样本的时候,样本越大,有些估计或者统计值就会越趋近于一个点,这种情况叫做稳健,有时候并不会趋近一个点,而是无止尽的在一个范围内呈现出散点,这就是不稳健。
当convergence in paobability 的时候,一般这个家伙就是稳健的呢
作者:iamhappy 时间:2007-5-30 9:09:00
第 4 楼
楼上的把consistency和robustness弄混淆了
作者:shufe007 时间:2007-5-30 10:08:00
第 5 楼
就是看看在不同的条件下(如加入其他变量等)其原有的结果是否稳健(系数符号、大小、显著性等)。
作者:tasteconomic 时间:2007-5-30 16:06:00
第 6 楼
robust译为稳健的,或强健的,或鲁棒的(音译)
含义大致就是估计量比较 稳定
我看的一些文献中,关于robust有两大类,一类是在伍德里奇的书里经常出现的,就是一类统计量,面对未知的假设,这种统计量都是稳定的,都是可靠的。比如异方差稳健估计量
Since testing hypotheses is such an important component of any econometric analysis
and the usual OLS inference is generally faulty in the presence of heteroskedasticity,
we must decide if we should entirely abandon OLS. Fortunately, OLS is still useful. In
the last two decades, econometricians have learned how to adjust standard errors, t, F,
and LM statistics so that they are valid in the presence of heteroskedasticity of
unknown form. This is very convenient because it means we can report new statistics
that work, regardless of the kind of heteroskedasticity present in the population. The
methods in this section are known as heteroskedasticity-robust procedures because they
are valid—at least in large samples—whether or not the errors have constant variance,
and we do not need to know which is the case.
第二类,就是更直观的稳定性,比如最小一乘法min(abs(y-y_hat)),就是比最小二乘法min(sqr(y-y_hat))更为稳健的估计。因为最小二乘法更易受异常值的影响。但最小一乘法是非线性的,也没有最小二乘法那么好的几何解释,所不常用。但从稳健的角度看,最小一乘法是比最小二乘法robust。
作者:baby8962 时间:2007-5-30 19:23:00
第 7 楼
为什么弄混了?
作者:tasteconomic 时间:2007-5-30 21:31:00
第 8 楼
你在3楼说的就是convergence 嘛,呵呵。
因为robust和convergence 有相同的必要条件,就是large sample
作者:baby8962 时间:2007-5-30 23:59:00
第 9 楼
我觉得他们是一个妈妈生的,名字不一样而以两者关联很大。不过robust的解释我是抄的我本科的老师的解释,难得我还记得。
作者:iamhappy 时间:2007-5-31 12:49:00
第 10 楼
如果你的老师是这样解释robustness,那就是他把两个概念弄混了。
另外,robustness并不是一个大样本的概念,更谈不上大样本是必要条件了。
作者:tasteconomic 时间:2007-5-31 13:22:00
第 11 楼
楼上见多识广,但我认为,至少从伍德的计量里看来,heteroskedasticity-robust 是需要大样本为条件的.而且,我只见看过伍德里奇的两本计量经济学教科书涉及到robust统计量.所以我还是大胆主观地判断robust的第一层意思(见6楼)是需要大样本条件的. 另一些书上,比如北京大学的陈家鼎,孙山泽,李东风的<数理统计学讲义>里是举的6楼里的最小一乘法来解释robust,就是我见过的第二层意思.
不知道iamhappy能不能与大家分享你关于robustness的概念,这里是学习交流的版块,大可畅所欲言.
[此贴子已经被作者于2007-5-31 13:24:29编辑过]
[此贴子已经被作者于2007-6-3 1:09:56编辑过]
[此贴子已经被作者于2007-6-3 6:01:45编辑过]
[此贴子已经被作者于2007-6-3 12:41:04编辑过]
[此贴子已经被作者于2008-6-10 22:20:33编辑过]
czq8
第10楼2010/12/20
GB/T 2423.29-1999电工电子产品环境试验 第2部分: 试验方法
电工, 环境试验, 电子
【 标准编号 】 GB/T 2423.29-1999
【 标准名称 】 电工电子产品环境试验 第2部分: 试验方法 试验U:引出端及整体安装件强度
【 英文名称 】 Environmental testing for electric and electronic products--Part 2:Test methods--Test U:robustness of terminations and integral mounting devices
【 发布单位 】 SBTS
【 批准单位 】 国家质量技术监督局
【 发布日期 】 1999-8-2
【 实施日期 】 2000-3-1
【 开本页数 】 15P
【 替代标准 】 GB/T 2423.29-1982
【 引用标准 】 GB/T 2421-1999; GB/T 2423.28-1982 etc.
【 采用关系 】 IEC 60068-2-21-1992,IDT
【 起草单位 】 中国电子技术标准化研究所
