happy水中月
第2楼2010/08/28
下面的链接里面有TOVC的检测文献,你看看色谱条件和你的是否相同
http://bbs.instrument.com.cn/shtml/20080717/1359266/
tsqgc
第9楼2011/02/21
6# is correct, the temperature of cold trap should be higher than or at least equal to the temperature of primary desorption. In addition, maybe the outlet split flow was low.
The time of cold trap holding is to remove all the compounds desorbed from the tubes, so it is better to hold a little longer.
