【分享】索谱隔水培养箱
  • suopuyiqi2010
    2010/09/21
常用设备综合讨论
  • 用途概念:summary
    适用于医疗卫生,医药,生物,化学,农业科学等科研部门进行恒温培养必须的专业设备。
    It is suitable for the scientific research departement in medica health,medicine,biology,chemistry,agriculture etc.and is an necessary specialized equimpent for thermostatic culture.
    产品特点:features
    培养箱水套采用不锈钢氩弧焊制作,经久耐用。
    The incubator·s water-jacket,made of stainless stee by ar gon are welding, is very durable
    微机控温,高低水温报警及超温报警。
    Temperature control by digitar display:when in-incubator temperature exceeds the perset value or when the water level in water level in water-jacket is too high or too low,an acoustooptie will sound automatically.
    不锈钢工作室,隔水式加热方式、温度均匀。
    It adopts stainless steel working chamber and wate-jacket beating mode temperature is even in working cha-mber.
    采用硅橡胶密封及钢化玻璃双层门防泄露装置,观察方便。
    Adopt silicon rubber sealing and toughened glass double-layer door with leakeage-proof device,being easy
    to observe.
    技术参数:Specifications
    技术参数:
    型号:GHP-9050
    产品类型:微电脑普通型
    电源电压:AC 220V±10%/50Hz±2%
    加热方式:水套式Heating water
    控温范围:室温+5-65
    温度分辨率:0.1
    温度波动度:±1
    温度均匀度:±0.2~±0.5
    输入功率:500w
    内胆尺寸(mm):350*350*410载物托架:2块
  • 该帖子已被版主-后知后觉加2积分,加2经验;加分理由:感谢分享
  • 职业游民
    第1楼2010/09/21
    这不是一个广告贴吗?怎么还加分了呢????
